Question about Seagate Barracuda 7200.10 (ST3750640AS) 750 GB SATA II Hard Drive
How can i to connect a hard drive sata with sata to ide adapter on biostar u8668d motherboard?
Motherboard biostar u8668d hard drive sata seagate barracuda 7200.12 750gb 1.25 gb sdram
  • 3,462 Answers
You will need to purchase a serial ata adaptor card for pci slot with support for sata 1/2/3 I believe. Try ebuyer.com
Posted on May 28, 2015
mdsaeed67
  • 849 Answers
SOURCE: Sata drive not detected
just no other solution except upgrading BIOS properly
Posted on Oct 27, 2008
SOURCE: disk manager for seagate 160 gb sata barracuda hard disk
windows xp setup not creat the partation.
and not show the tha harddisk,but harddisk are showing the bios setup.
my system is ACER ASPIRE tower Casing.
Posted on Mar 12, 2009
SOURCE: Seagate SATA 80GB Master Drive and Seagate IDE 80GB Salve Drive
Dear,
You have to make IDE drive as slave. For this put the jumper to slave in IDE drive. Possibility of CMOS battery is rare, but you can confirm it by checking your system time in BIOS. If system time is ok then there is no problem in CMOS battery and you need not to replace it.
Thanks,
Rakesh Kumar
Posted on Jul 23, 2009
graysand
  • 558 Answers
SOURCE: Seagate ST3500630AS SATA 500 GB hard Drive
You will have to send it to a data recovery company in order to retrive the data sounds like the circuit board failed therefore the drive is not receiving power.Usually if this board is good you would hear the drive spin up.
Good luck
Posted on Oct 04, 2009
Testimonial: "Very helpful! Thank you!"
lserni
  • 466 Answers
SOURCE: Seagate Barracuda 7200.9 SATA driver problem
If the laptop is also XP, the drive should be recognized without problems. Sometimes this may not happen if the disk is unusually partitioned (could happen if you manually dual-booted it with Linux, for example). Verify the enclosure is working properly and has enough power supplied to, and that it appears in Device Manager. If all this applies, the enclosure must be considered working and the problem might be in the partitioning or disk access.
In XP Pro, do Start > Run Command > DISKMGMT.MSC and press OK. See whether the disk appears (if it doesn't, it's the enclosure, or its drivers - or the disk was dying and is now dead, but that's not very likely), select the NTFS or FAT32 partition - ignore any others - right click and mount the unit as drive, say, G.
If it doesn't work but the partition is found, you may need a more powerful tool such as Paragon Partition Manager.
See also here:
http://support.microsoft.com/?scid=kb%3Ben-us%3B307889&x=12&y=12
Posted on Nov 25, 2009
Is a ide a hard drive
You should check what kind of hard drive is using your computer. If it has less then 5 years probably hard drives are sata.
watch this tutorial
Instructions on USB To SATA IDE Adapters Cables
How to connect SATA devices in PATA IDE only PC system
Modding Guide Inline SATA Connectors
How to connect an IDE drive to SATA motherboard
Jul 22, 2015 | Hard Computers & Internet
Hello, What is the largest hard drive I can upgrade too for my Biostar 330G? Can I use a SATA and install a IDE hard drive as my slave backup? Thank you. Remi
As I recall, this model has one IDE channel on, which typically powered an optical drive. The manufacturer claims that it supports one IDE drive, in theory, you could set the IDE HDD on the second connector of the IDE cable (secondary slave), however, it may be that the Bios will not recognize this.
My own thoughts would be, as this has 2 SATA ports, to leave the IDE connection alone and for the Optical drive and put another SATA HDD on the other SATA connector.
If you need to use the IDE drive, you can get an IDE to SATA adapter and that would enable you to use it connecetd to the SATA connector
As to capacity, I'd assume it would run any size of HDD
Jun 23, 2011 | Biostar iDEQ 330G (IDEQ330G) Barebone
Hi, I tried to install a new Seagate 500GB HD on my windows XP system, I also used a bridge card to adapt the drive, as my system is IDE, the new Seagate is SATA, no jumpers on this drive. Problem is once...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps don
Feb 25, 2011 | Seagate 500GB SATA HD 720016MBSATA3G 500...
How do i convert my hard drive for my lap top they have different plug ins
Was your old hard drive a 44 pin IDE drive (PATA)? Then you need a 7 pin SATA to 44 pin IDE converter module. Unfortunately, I can't suggest any - most take up enough space that they can't be fit into a laptop case behind the hard drive. Some connect to the IDE cable; others connect to the IDE port on the motherboard. They are more useful for the small format desktop cases (home theater PC).
I wish that I could be of more help. 2.5" IDE drive are still available; this might be a more effective solution than finding an adapter that will fit inside the laptop.
Sep 23, 2010 | Seagate Momentus 54006 (ST9250315AS) 250...
HP dc5100MT motherboard
Based on what I have read about the HPdc5100MT motherboard it only supports SATA hard disk. Not sure how you are able to use a 80GB IDE.
See configurations from HP at this website. All hard drives are mentioned as SATA.
Jun 06, 2010 | HP Compaq dc5100 Microtower PC Desktop
Windows setup does not see sata drive K8VGA-m
Good day sir, if your hard drive is bad it cannot be detected, but lets review first several reasons why it cannot be detected by your motherboard;
  • check the master / slave setup, if youre hard drive is sata, this is not applicable.
  • check your connection, both data and power cable, to and from the hard drive. (ribbon ide cable or red sata data cable)
  • Still cannot be detected? try to reset your CMOS setup by using the cmos battery jumper. after reset, review the CMOS settings, and enable your IDE/SATA drives. test again.
  • Stiil doesn't work? bring it to a friend who has a PC and try to test your hard drive to any available good PC, to check if your drive is bad.
If your hard drive is good, chances are your motherboard IDE/SATA part is bad, you may need to buy a PCI to SATA/IDE card. connect this card to any available PCI slot, connect your hard drive. hope this helps.
Oct 01, 2009 | Biostar K8VGA-M Motherboard
Need correct hard drive for Biostar GF7100P-M7S
This isn't even a question plus its a silly post overall. SATA is a proven technology that is much faster and just as stable as UDMA.
Jan 03, 2009 | Biostar GF7100P-M7S Motherboard - v6.0,...
A acquaintance gave me a Seagate drive with Sata connections. (Baracuda 7200.7) My Motherboard has IDE connections hawever the Power Supply has 2 Sata power connector. My question is; Does someone make...
yes you can connect sata hard drive, but first you have to install a pci sata card, into the pci slot of *********** board
if you like the solution please rate it
Oct 14, 2008 | Computers & Internet
P4vmm2 mobo
The P4VMM2 ver 5.0 has no SATA connectors so to connect a SATA drive to ihe IDE channels you would need an adapter.
May 10, 2008 | EliteGroup P4VMM2 Motherboard
SATA problem during windows install
try other memory or if you have 2 dimms take one out and try same to both dimms
Jun 30, 2007 | Biostar M7NCD ULTRA Motherboard
Seagate Barracuda 7200.10 (ST3750640AS) 750 GB SATA II Hard Drive Logo
151 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
