Question about Sunbeam Food Mixers
How to disassemble mixmaster heritage series model 2351
Wife inadvertently reversed beaters and tried to use. Now the beaters will not engage.
  • 1,602 Answers
Try the following sites
www.eserviceinfo.com/equipment_type/model###
www.freeproductmanual.com/manufactures_name/model###
www.info.com/manuals
www.s-manuals.com/manufactures_name/model###
at the browser type the following information
sunbeam disassemble procedures for make/model ###
you could look at www.youtube.com/disassembling mixmaster model 2351
Posted on Mar 31, 2015
Beaters are hitting each other and jamming up
One of the beaters had jumped a gear. I understand they are nylon gears. My wife's had the same trouble. I unplugged the mixer, removed the bowl and install the beaters if you can to see where they are touching. They were two cogs off. I grapped the left (red) beater firmly and twisted it to the left. It took a couple tries and turning on the motor (with out beaters) to find the spot where they had skipped. In the end the left beater jumped back one then two teeth and now the beaters aline properly.
This will happen again with heavy dough, etc. now that the teeth are worn in that spot. Use a bread machine for the heaver dough. IMHO
Dec 12, 2012 | Sunbeam 2346 Heritage MixMaster Series...
I have a Sunbeam Mixmaster 2351 Heritage Series that the speed dial control numbers fade. Sunbeam replaced my mixer but want to prevent the same problem for reoccurring, Any suggestions?
I would propose to solution to your problem,
one. Try getting some clear contact and cutting a a square or circle a little more than the size of the dial. Removed the dial if possible and later clear contact over the surface.
Two. Get some clear nail polish and cover the markings on the dial with thin coat.
Warning warning warning!!! (Test the nail polish on a surface that is not exposed, for example underneath) to make sure that the nail polish does not react with the surface of the mixer.
Regards
Trevor
Feb 15, 2012 | Sunbeam 2346 Heritage MixMaster Series...
Middle better comes loose
Try placing some "braces" rubber bands around the shafts of the beaters. This should tighten the hold of the shaft with the mixer and keep them more straight.
Dec 15, 2009 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam Mixmaster Heritage Series Model 2350 speed problem
The speed control on the back is simply a variable resistance potentiometer, the same thing that controls the volume on older amplifiers. The output current to the motor is supplied by the printed circuit board in the bottom of the unit. This allows gradual increases in speed to avoid over-torquing the motor on speedup. Even the poshy-posh-posh mixers do this.
At least it still works. The most common problem is the cheap plastic drive gears that strip out with a mild cookie dough, this jams the beaters together and requires burial-at-dumpster.
Dec 14, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Instructions for Sunbeam 2350 Heritage Series Mixmaster
Go to sunbeam.com, select "kitchen", then select "customer service", then "instruction manual", then "stand mixers", scroll down to model #
Nov 23, 2008 | Sunbeam 2350 Heritage Series Mixer
Regarding the Sunbeam Mixmaster (model 2346): How do I remove the front cover of the mixer so that I may reallign or replace the beater gears?
Pry the beater release button out with a screwdriver. There are two screws underneath it and one under the motor housing between the the beater holes. This will allow you to remove the chrome front cover, but not the motor and drive assembly. Getting to the part that contains the gears requires complete disassembly of the mixer. It is not designed for service, and requires patience and a variety of tools to disassemble.
It has a metal worm gear and plastic drive gears. If the beaters are out of alignment, then one or both of the plastic gears are stripped and the mixer is junk. Repair plus shipping costs equals the price of a new mixer. This is the weak point of these mixers and a fundamental flaw in an otherwise robust and sturdy design. It is definitly not the same mixer *********** bought 30 years ago.
Jul 18, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam mixmaster heritage series
http://www.repairclinic.comThis is a helpful website with an 800 number and they are good about helping with the fix.
You probably have to replace worn gears and or bearings.
Feb 20, 2008 | Sunbeam 2370 MixMaster Series Stand Mixer
Food Mixers Logo
391 people viewed this question
Top Sunbeam Food Mixers Experts
Jerry Greenberg
Jerry Greenberg
Tony Vallette
Tony Vallette
Level 1 Expert
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
