Question about Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block
Briggs Stratton 5hp I/C starts ok, runs, but will not rev
Model 132232, type 0322-01, Pulsa Jet Carb.(Mechanical governor), remote throttle on rotavator. The engine starts with choke, but will only idle on the fastest 'Run' setting and will idle without choke when warm. The throttle shaft on the carb body oscillates on its own, pulsing the revs at idle. When I spotted this I found that if I operate the throttle spindle manually at the carb body, I can make the engine rev fully and without any misfire or smoke. The engine stood unused for 3 years and the things tried so far are - - Checking governor and throttle spring and linkages. Difficult to see, but I think they are all there and connected correctly. - New spark plug, oil and air filter - New petrol - Throttle cable adjusted - New diaphragm and cleaned accessible passageways with diaphragm cover removed - Checked choke works as it should with air filter removed - Removed and cleaned idle needle valve and jet - Looked at lots of internet posts This is the Atco Merry Tiller model where the remote throttle connects to the engine below the fuel tank close to where the governor shaft exits the engine. Rather not strip the carb until all other possibilities explored, particularly as it runs ok when throttle on carb body is turned directly. Any advice welcome please. Pete
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
My money is on a partial blockage of the main jet or the passageway to it. You're having to force it to run through the idle jet by fully choking the incoming air. There's not enough gas coming in with the choke open to allow it to run.
I'm thiniking total carb disassembly, carb cleaner and an air compressor combined with a ton of patience will take care of the issue.
Posted on Apr 01, 2015
  • Pete Go
    Pete Go Apr 01, 2015
    Thank you Tractor Man .... spot on, I will try that when time permits and update the thread. :)
  • 6468 Answers
SOURCE: This mower will start but not smooth could armature magneto bee the problem???
check the valve adjustment if overhead valves
Posted on May 29, 2012
rycgl
  • 1545 Answers
SOURCE: Bolens MTD push mower with B&S 4.5HP
This is probably not a blown gasket issue. A bad head gasket can allow oil to enter the cylinder head/combustion chamber if it's not sealing off the valve area. A simple suggestion is to check on the engine opposite the carb side for the oil/crankcase breather. It will have 2 screws holding it onto the block. It has a type of filter media in it that traps excessive oil and oil vapors from the engine. It is also connected by a tube to the air filter housing. When you tipped, you probably put too much oil in the breather and it was inducted over to the air filter/carb intake side.
Clean or replace the breather after checking it and also make sure you haven't overfilled the Briggs with oil and only use SAE 30 in the engine. Muti-viscosity isn't recommended in summer unless you run synthetic, then it is OK.
Please vote on this solution.
Posted on Sep 05, 2010
Testimonial: "Thank you - sounds like excellent advice and I'll sure let you know what I find."
  • 30 Answers
SOURCE: I have a Craftsman Yard Man 6.5hp push mower with
Have you checked the choke that it is off after you get the engine started,the black smoke is definitely from the choke, if you take the carb off and check that the needle closes when it should,as one can easily do an adjustment by bending the float/tab,rgds
Posted on Sep 25, 2010
2strokeJim
  • 577 Answers
SOURCE: after the engine began hunting i cleaned out the
did you replace you diaphrams or just clean them, does it have a float bowl or just diaphram? sounds like during all you cleaning you did'nt adj the tab to the needle, therefore diaphram is not opening needle which is not giving gas to the carb. tab should be flush with carb body and when you push on it needle should move to open and let fuel in, good Luck
Posted on Apr 28, 2011
SOURCE: adjusting governor/throttle briggs and stratton
there should be a little screw to help adjust your idle try that..counterclockwise to add more idle, clockwise to slow idle..
Posted on Apr 26, 2012
Need a throttle linkage diagram for a briggs & stratton engine model 9S502 type 0620-B1
David, This is what I found in google search for B&S carb. linkage diagram, you can also do a search because there are lots more.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Linkage Spring replacement on Briggs Stratton Quattro 4 HP Murray Lawn...
Repairing Lawnmowers For Profit Part 61 Governor Spring Help
briggs and stratton governor linkage diagrams Google Search
briggs and stratton carburetor linkage diagrams Google Search
Jun 10, 2016 | Briggs & Stratton Garden
Pulsa-jet adjustable carb I need a diagram
I'm not able to post a diagram,but I can give you some info-you'll need to-replace the rubber diaphram/gasket if it hasn't been replaced in the last 2 years remove the hi &lo speed needles,give it a cleaning with spray carb cleaner,put it back together,start with needles 1& 1/4to 1 1/2 turns out.it's a basic,simply designed carb.Ah for the good old days!Find a chiltons small engine repair manual for a diagram
.[hint] start w/a full tank
Jan 22, 2013 | Garden
Tight throttle spring on briggs ok?
I do that on people's mowers when they come in not running fast enough. If they are running too fast I stretch them a little and even cut the end off the spring and reshaped the end to get the right speed. Yes you can do this but be sure you do not over rev the engine or you will ruin it.
May 01, 2017 | Briggs & Stratton Garden
98 model craftsman,17.5 hp,redone carb,all linkage good,not sucking air,idles great,won,t rev up,govenor broke inside engine?thanx,confused
Probably not the governor, most likely it is in the carburetor. The main or the high speed jet circuit is likely obstructed.
Jul 22, 2011 | Briggs & Stratton Garden
Motor runs wide open when set @ slow speed
It could be that the governor spring has become disconnected or has broken on an end where it hooks onto the throttle linkage. If the spring is OK & throttle linkage is not binding it could mean the governor drive inside the engine has failed preventing the governor from operating correctly. You may need to take the engine to a mechanic to fix the problem.
Sep 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
10 hp briggs runs at high speed, govenor don't seem to be working
One possible cause for this problem is debris,sticking,or frozen linkage between the governor and the throttle butterfly. Depending on the make and model of your engine it will either be a mechanical governor that has a arm that goes down into the case or a air vane governor that is behind the recoil shroud of the engine. Move all the linkage that connects between the governor and throttle and speed lever to make sure it doesn't bind or sticks. If it does pray a little silicone or wd 40 spray on it to help reduce friction. Also on air vane governors they can become stuck from debris that inhibits it from moving make sure there is nothing in the way of the governor. If all of the linkage is working properly and you still have the issue try adjusting the the fuel mix screws and the high rev. settings on the throttle lever (if equip.).
Jan 29, 2010 | Parks Optical 13.5hp Briggs And Stratton...
Honda IZY engine hunts. I mean the speed pulses rhythmically!
Just adjust the idle speed control/Fuel air screw located pointing downward on the bowl of the carb,Just start the engine,idle up high and turn the screw until it levels out and runs smooth.
May 31, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs  Stratton Lawnmower Lawn Mower Short Block Logo
431 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
