Question about Samsung LN40A550 LCD TV
I have a samsung lcd tv that powers on has sound but the picture is fuzzy and has no colour . What would be the component that needs replacing for this ??
  • 83 Answers
Hello. Before you start replacing parts, make sure your connections are correct. It sounds like you have connected a composite source to a component input. Composite is three RCA plugs, a yellow for all of the video, and a red and white for audio left and right channels. Component is five RCA cables, green, red and blue for video, and red and white for audio. if composite is connected to a component input, the picture will be black and white with squiggly lines all through it.
Posted on Apr 01, 2015
  • Samsung Master
  • 670 Answers
Hi Israel,
With fuzzy picture please open the menu. If the menu is normal, the Tcon and LCD panel are ok and there is every possibility of the fault being due to bad main board. If the menu is also affected, look into the Tcon board and the panel. First the Tcon board. And before doing all this please check the connectors between main board and Tcon and Good luck.
moto34
  • 155 Answers
SOURCE: Samsung LCD Tv
Try this:
Access menu service by press on your command, with your TV OFF:
INFO + MENU + MUTE + POWER ON
Then you should get access to Service Menu.
The last item says: RESET
This will do a reset to the TV.
Make no harm.
WARNING: If when on service menu you feel tempted to "screw" on anything FIRST take note on ALL you change! You can compromise the TV ...
Posted on May 03, 2008
SOURCE: Samsung LTN1765 has blinking green power indicator, but no picture or sound
Try replacing C51, a 10 microfarad 16v. surface mount electrolytic. It's near IC23 on the upper center of the board.
This part had high ESR on a couple of sets I serviced which
kept the power supply from starting.
Posted on May 10, 2008
  • 718 Answers
SOURCE: how hard it is to replace by yourself main board Samsung LN-T4065
You need to do some more diagnosing of the problem. If you get sound and change channels take a bright flashlight and place it again the screen. Look for an image around the edge of the flashlight.
If you see an image that means the LCD controller board (TCON) is probably good.
The problem is probably one of three causes;
1) Inverter board is bad
2) CCFT (cold cathode fluorescent light) are bad.
3) Power to the inverter board is bad. You can also check the connectors.
Posted on Mar 30, 2009
  • 26 Answers
SOURCE: samsung LN32A330J1N LCD T.V has no picture when powered on
I have a LN32A330 with a cracked screen. I can sell you boards tha you may need or maybe i can purchase your non working set.
Please email me, tracy_tangen@hotmail.com. You may need your power supply repaired. I am able to repair it for you if needed.
Posted on Jan 27, 2010
jrweighing
  • 183 Answers
SOURCE: I have coloured vertical lines on my 40-inch
is the screen full of vertical lines? It sounds like your Tcon has gone faulty but...there is hope. Firstly, only if you are competent with electrics follow the procedure bleow, else get a qualified tv engineer to inspect your tv.
Remove the back cover on the tv.Looking in from behind, check the power supply which is the board connected to the mains power lead. Check the capacitors, making sure none of them have bulging tops.These are the components shown below.
The caps shown below are an example of faulty caps, with their tops bulging.
This model of tv is prone to this condition, and if you have any bulging topped caps, replace them.
Next check the Tcon LVDS lead connection. The Tcon is the board located top centre of the screen and is enclosed in a metal plate.It has a lead connected to it that goes to the main board. Clean the connector at the Tcon.Be very careful though because the connection is fragile. It can be removed by gently squeezing in either end of the connector and gently pulling outwards.If these procedures are not successful, replace the Tcon.
Posted on Mar 07, 2010
Samsung flat screen tv no picture sound only, I have checked all connections and remote still same problem.
The T con board is faulty. It is the board with flat ribbon cables going to the bottom of the screen. It is not hard to replace this board. You can get one from here:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Jan 01, 2016 | Samsung Televison & Video
I have a Samsung model UN60EH6003F with sound but no picture. What part do I need to repair this?
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 23, 2015 | Samsung UN60EH6003F 60-Inch 1080p LED-LCD...
Hi I have a 46" Samsung lcd and the picture colours are all gone luminous like. All bright colours and fuzzy. It was working fine one day and in the middle of a program it just happened and idea what the...
Sounds like T'Con board fault. Contact any service technician to replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 03, 2014 | Televison & Video
Why is the picture on my tv fuzzy.
Sep 28, 2014 | Samsung LN40A550 LCD TV
My Samsung LCD TV slowly flahses colours, each about 2-4 seconds
hi,
your lcd is in test mode. you may try off the power. press and hold menu + source + power on.
this should go back to normal mode.
Apr 01, 2010 | Samsung LA40M81/BDX 40 in. LCD TV
Samsung LCD cm07 good then bad picture, powers off and on
well this could be a power supply issue try this web site they could have the part www.discount-merchant.com
Ness
Jan 05, 2010 | Samsung HLN5065W 50" Rear Projection...
The picture is very fuzzy (pixelated) when you first turn power o
this problem occurs usually in the power supply change or check the power supply borad
Dec 18, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Picture goes off after a while
Call 1-800-Samsung to set up a warranty service call. They will repair it in your home if they send a Samsung Field Engineer. You probably have a bad Main bd.
Jul 01, 2009 | Samsung 32 in. LCD Monitor TV
46" LCD TV
Have you try the other inputs?
I would suggest to try all the other inputs and if you're still getting a black and white picture then that would mean a defective main board. If your TV is less then a year old, still cover under manufacturers warranty.
Let me know if you need further assistance.
Jan 02, 2009 | Samsung LN32A550 32 in. LCD TV
Samsung LN40A550 LCD TV Logo
113 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
