Question about Ovens
Electric heating not working
Checked both limit and control themostats behind elements both ok Checked elemnts both approx 50 ohms power to pcb ok green light on thermostat is on with max temp can hear relay clicking also relay clicks when switching from 500 watt 1000 watt and 2000 watt with power on live feed to relays but nothing on either side of relay
  • Ray Miles
    Ray Miles Mar 31, 2015
    Please note this heater is a Truma Ultraheat in a Caravan
  • Ovens Master
  • 5,323 Answers
Surface burners
are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.
You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
On modern electronic control ranges, the oven temperature sensor
is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons.
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Posted on Apr 17, 2015
4 Suggested Answers
  • 35 Answers
SOURCE: sears electric oven
Replace broil element
Posted on Dec 09, 2007
robotek
  • 1512 Answers
SOURCE: thermador SCD302TB wont heat. first upper, now neither
If it is any help to you, you can get a new controller board complete on ebay for aroung $190. Not much left after that besides elements...
Posted on Mar 01, 2008
  • 794 Answers
SOURCE: My home oven: Jenn Air W30400-C
Hi haiste,
This problem only means that you have a bad ERC that needs replacement. You may order the part from Sears, call them at 1-800-252-1698. Just get your model number ready and they'll help you get the new ERC. Once delivered, it goes with the instruction on how you will replace.
Hope this helps.
Thank you for using FixYa.
Posted on Aug 24, 2011
Maytag Oven. The bake do not heat, the broil is ok. what is the problem ?
Look at the wiring diagram... The manual reset Thermal Limiter Switch (part number 74008715), located on the lower rear insulation retainer can keep both elements from working, not one at a time... I would inspect the back of the bake relay for a burnt/failing solder joint. Swapping the BAKE and BROIL leads is an acceptable test, but if you put the bake leads on the broil and still get no heat: check the control relay. If the broil leads will not heat the bake element, you have a bad element or bad connection. Be sure to do all testing of the elements with at least one wire detached so as not to red a back circuit.
Jun 19, 2016 | Maytag Ovens
Kenmore electric oven bottom element not working
check thermostate control sensor its locate behind the heating element. check continuty .if its fail .replaced correct value.
GKM
Jan 07, 2014 | Ovens
U1442 main oven not heating
If you are sure there is 220v going to unit, it most likely is element or click / control. If you have a ohms meter, you can test the element
Sep 07, 2017 | Neff U1721 Double circotherm Electric Oven
Ge oven jtp18 elements won't heat
The limit switch in a Ge oven usually works or is blown. I would look at the oven sensor located at the back of the oven. It should read approximately 1k ohm at room temperature.
http://www.on-timeappliance.com/ovenrepair.html
Mar 26, 2012 | GE Profile JTP18 Electric Single Oven
Broiler element not working at all. checked element--it's OK. Called a serviceman-- he thought it was an oven sensor--replaced sensor ---no change Electronic clock some times shows a code "F2 ...
you do not say it is electric oven. if so broil element requires 240 vac. may be controlled by relay. Is bake element working? also controls for broil may be different setting if digital panel is in this design. I think same sensor may be used for bake or broil.
you do not say if gas oven, electric oven, single or double oven or if digital panel control, a little more information would help.
if you have digial voltmeter, FULLY disconnect electric power and measure element on terminals. probably less than 15-20 ohms for a good element.
Dec 28, 2010 | Ovens
No heat, either during pre-heat or bake or convection settings. This occurred after performing a self-cleaning function the prior day.
Could be:
1. bake element bad
- this can be checked, power-off, with an ohm-meter
2. temperature sensor bad
- this can be checked, power-off and sensor unplugged with an ohm-meter (should read 1080 ohms @ 70 deg F)
3. control board bad
- we repair these at www.fixyourboard.com
Oct 05, 2009 | Whirlpool GBS277PR Electric Single Oven
Cleaned oven, now baking element not working-element is good-buzz
This F-3 is concerning a Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control.
Solution--
· Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Jun 16, 2009 | GE Profile JTP18 Electric Single Oven
We need to install the lower heating element in the upper oven
ill aasumme that yo can see the elemnet in question, and its not a "hidden bake" elemnet located under the oven floor.. should be an easyrepair, with a little bit of patience. don trush shoudl only take 10 min anyway. TURN OFF POWER> LIVE WIRES TO ELEMENT AT ALL TIMES. REGARDLESS OF UNIT ON OR NOT!!! ther ewill be 2 screws along the bottom of the element holding the elemnt in the unit. after emoving carfully slide the old elemnt out a few inches, slowly pull out, for the wires are still attached to the back of elemnt and you want them to stay there you dont want them to disconnect and fall behind unit, (you will then need to remove the unit form the wall to access htem). so pull slowly espescially if you feel resistance in the wiring. after you getit out far enough simply unplug and plug in the new one reinstalll and you shoud be fine
Nov 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Amana Convection Wall Oven Model AOCS3040 Does Not Heat in any Mode
sure its possible, sounds like you've blown an over limit thermostat behind stove, gets too hot and for safety reasons cuts off unit untill replaced
Feb 11, 2008 | Amana AOCS3040 Electric Single Oven
My Dacor wont heat, broil or convection after self cleaning. No heat but everything else works The bake, broil, and convection elements on my Dacor CPS130 electric wall oven will not heat.  The oven has...
like another person stated-from the front behind the door, take off the 6 screws and the cover by the latch. there is an "oven hi temp limit switch" It is crome with 2 heavy black wires connected to it. On the back side of this is a small red button which will reset the limit switch. I had the same issue (everything worked except the any of the heating elements) and quickly resolved.
Jan 07, 2008 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
