Question about Celestion Audio Players & Recorders
How to connet celestion crossover .tq - Celestion Audio Players & Recorders
Hello Guys,Can you please help? can I replace the sub woofer on my sony home theatre system DAV-DZ231 with a Celestion sub woofer s10
Presumably, the Celestion subwoofer is self-powered in which case it would connect to an RCA subwoofer output on your Sony system if there is one.
Oct 30, 2014 | Audio Players & Recorders
How do I set up a Celestion S10 Subwoofer...
OK
Voltage is relevant to where you live in the world. America it's 110. Europe mostly 220.
What you're asking is a very deep and complicated question.
I'm attaching a link with some articles.
What I suggest is that you find an upper end audio store and ask a 20 audio head to set up your system for you. Subwoofer Setup and Calibration for Best Bass
Apr 12, 2014 | Celestion S10 Subwoofer
Replacement tweeters
TIP
Why not go for replacement diaphragms for the ones you have ?
Its not realy difficult to do it yourself
celestion a2 tweeter blown or not
http://reconingspeakers.com/product-category/diaphragms/celestion-diaphragms
Jul 26, 2013 | Celestion A2 Speaker
Tweeter not working
Check the continuity of the removed tweeter with a VOM meter (I use an original Heatkit MM-1 available on eBay for $20) and do the 1.5 volt battery click & scratch test mentioned above.
Celestion A3 tweeters (also used in the A1 and A2 speakers) or the replacement diaphragms are no longer available from Celestion. A1 speakers show up regularly on the United Kingdom eBay website for $300 or less and are small enough to economically ship to the USA. You would also end up with a midrange spare speaker (assuming it is the same as in the A3 cabinets)
The part number for the A series 3 bar tweeter is T4969/P. The 3 bars refers to the 3 bars in the casting to protect the dome. I got this number from the box of my spare tweeter I have the earlier 1 bar castings in my A3's.
Go to www.ersatzteil-versand.at do an "artikelsuche" (article search) for the number T4969/P and something extremeley similar shows up except that they list the manufacturer as Onkyo. The part number and description are so similar to what is printed on my spare tweeter box it would be worth 81 euros to see what shows up.
I have designed an adapter plate for either a Scan-Speak Revelator Tweeter D2904/710002 4 ohm, 1" soft dome, 70 mm diameter magnet, $220 or a Vifa D27TG35-06 6 ohms, 72 mm diameter magnet, 91 db, $37.50..Both are available from:
http://www.speakercity.com/ in Burbank, CA
I only modeled the front flange of the tweeter to save time. I have not built any of these yet but the price would probably be $400 for a pair of adapter plates and speaker flange modifications. But when you are done you would have replaceable tweeter for a long time to come. The 2 protective bars are drawer handles available for $3 each.
Other possibilities are:
http://www.audioloudspeakers.co.uk/boultons.shtml voice coil rewinding in the uk
http://www.speaker-repairs.com.au/coils.htm voice coil rewinding in australia
http://www.speakerex.com/diaphragms_new.html in Florida can rebuild the woofer and replace the midrange but no longer have the 4 ohm diaphragm for the tweeter.
If you want the drawings (and 3D geometry file necessary for the machinist to make the curved edges) for the adapter plate and tweeter flange modification contact me at mercedes280se-4@yahoo.com
Feb 11, 2010 | Celestion A3 Speaker
ONE LAN CONNETION AND THREE COMPUTER
Sure you can
In fact the wireless router is your best bet for multiple systems to connect to the net.
As per crossover wiring you can interlace the computers via using their USB ports.
Jul 27, 2009 | NAD L40 CD Player
I need to buy a replacement woofer and tweeter
http://www.usspeaker.com/homepage.htm
http://www.speakerdoctor.com/diaphragms.html
both these companys deal with celestion speakers,for replacments go to usspeaker,to have the originals repaired go the speaker doctor.both have 800 #'s.now which to do is a matter of money.also make sure you don't have a blown crossover(its rare for the high & low freq drivers to go at once)this is usualy crossover related.happy hunting.hope this helps.thanx for using fix-ya!!! p.s.(please tell me you did'nt try best buy:) :) :) HAPPY HOLIDAYS!!!!!!!!
Nov 29, 2008 | Celestion A1 Main / Stereo Speaker
My behringer FBQ 1502 produces static sound even there is no input conneted.plz help me because there is no technical support here in our country
shut down all neon lamps and check---------change your input and output cables and check------make power cord direct connection to your equalizer-----not share with other home appliance.
Aug 02, 2008 | Behringer FBQ6200 Home Equalizer
71 people viewed this question
Top Celestion Audio Players & Recorders Experts
 Grubhead
Grubhead
Robert Rankin
Richard Lindsey ...
Are you a Celestion Audio Player and Recorder Expert? Answer questions, earn points and help others
