Question about Honda 13 Hp 4000psi 4gpm Pressure Washer Ez4040 Pump
Honda 4000 motor runs great, pump not preasuring up water changed pump and no change, shaft from motor into pump was good felt like it was under compression but still no preasure
  • 6 Answers
The pressure relief valve could be stuck open or faulty. The check valves may be stuck or plugged up. Try thoroughly clean these parts and see if that helps.
Bob
Posted on Apr 02, 2015
Johnson 115 V4 no push and no oil alarm but plenty of oil
Probably the oil pump. check oil type/viscosity
Aug 27, 2017 | Boating
MY ACCORD HAS 119,000 MILES ON IT AND I HAD THIS WORK DONE ON THE CAR. 1. TUNE UP 2. RAIDIATOR FLUSH 3. TRANS SERVICE 4. BELTS CHANGED THE CAR RUNS GREAT BUT I AM BEING TOLD TO HAVE THE TIMING BELT CHANGED...
well that is how I always sell a timing belt job also. The water pump is driven by the timing belt and it is very labor intensive to replace. I always replace the water pump also because you have to remove the timing belt to replace. I have had people refuse the water pump, and have to spend the same labor dollars a few months later when the pump went out. Even if not leaking it is always good insurance to replace the pump with the timing belt but is not a must just good idea.
Nov 12, 2010 | 2004 Honda Accord
My timeing is set but my water pump is not working i took the piece out the spark pug wire cables go to out when change the rear main seal when i put that piece the spark pug wire cables back the water was...
your waterpump is belt driven....if your belt is on correctly and the pump is still good it will work. the belt spins the pully, the pulley spins the shaft, and the shaft spins the impeller. the impeller "pumps" the water through the motor. I would loosen the belt and see how much play there is in the shaft of the pump. the old grab and wiggle approach. if it moves a lot then it needs replacing.
Mar 20, 2010 | 1996 Honda Accord
What else needs to be changed when doing a timing belt on a 1999 honda accord? and about how much should it cost?
Technically, nothing else needs to be changed when replacing a timing belt, however it is recommended or suggested to replace the timing belt tensioner and water pump while doing the belt. These items are only accessable when doing a timing belt. The cost should be under $100.00
Jan 22, 2010 | 1999 Honda Accord
2003 kia rio- water pumps
I would follow the mechanics recommedations. I think he's taliking about the cam and crankshaft seals. Yes the water pump should be replaced as well. The pump that sprays windshield washer fluid onto the windshield is called the windshield washer pump. The water pump is on the engine and pumps water (coolant/antifreeze) through the engine to the radiator and heater core.
Oct 29, 2009 | 2003 Kia Rio
No high preasure at nozzle
Try starting the washer up without a nozzle clicked in and purging water through the pump, shut it down and install the nozzle and restart, if the motor lugs then it is making pressure, if the pump squirts water out of the by-pass immediately and or constantly it may be a stuck bypass and not a bad pump.
May 26, 2009 | Psi 2500 Mobile Pressure Washer 5hp Honda...
1979 Honda CX 500 runing hot
those bikes were known to have bad water pumps.you have to remove the motor from the frame to get to it.
Mar 29, 2009 | 1987 Honda CBX 250
Honda 13 Hp  4000psi 4gpm Pressure Washer Ez4040 Pump Logo
168 people viewed this question
Top Honda Plumbing Experts
Matt Olenzek
Matt Olenzek
Tony Crow
JonSnell Electronic
JonSnell Electronic
Are you a Honda Plumbing Expert? Answer questions, earn points and help others
