Where your handbrake consul is is there a little black button with white dot on it mine works when i switch it on mine located near floor of consul
You need to run a continuity test
on the DVD player first, to see if
it has any bad connections inside.
If that is okay then a bad fuse or
a problem in the wiring.
SOURCE: 2005 Chrysler Town & Country Radio & DVD problem
I had the same problem.
Open the front hood and go to the fuse box under (right next to the battery).
Replace the 20A fuse labeled RDO/Power
I am sorry that the owners manual does not even mention this.
SOURCE: 2003 chrysler town and country speedometer quit working
It is the speedometer that doesn't work? What problem do you have? Does the transmission shift or is it stuck in 2nd?
SOURCE: fuse for stereo/cd in chrysler town and country minivan
Its in the box next to the battery and i had the same problem.The fuse is on the first line top.
Thanks
SOURCE: Just bought 2005 Chrysler Town and Country and no
Naturally you could get them from Chrysler parts, if you want to save, go to radio shack and let the associate there check out the jack and he can come up with an inexpensive solution.
