Question about Ideaworks WiFi Antenna Booster - Long Distance Wireless up to 1/2 Mile Away by
Why wont work because says drivers wont load due to previous instance
1. VIDEO FILES TAKE MUCH TOO LONG TO LOAD.....EG. A 5 MINUTE VIDEO FILE CAN TAKE 12 TO 15 MINUTES TO LOAD. 2. i CANT SEEM TO GET ANY AUDIO HELP!!!
Try "K-Lite Codec" pack to help with your audio problem. This should help unless there is a problem with your audio driver. It may be worth checking this in Device Manager. The loading time may be due to your graphics card, or lack of it. If you are not using a graphics card then all of the decoding of your video file is being done by your main processor, and in these instances the more memory your system has the better. You don't say if you are laoding the file from hard drive or the internet. If it is the internet then the previous hardware limitations apply, but it may just be your internet bandwidth. Try downloading from the internet to your hard drive first before playing. This may save your media withdrawal system. Hope this helps.
Apr 04, 2011 | Dell Dimension 3000 PC Desktop
I have a compaq presario v2000 , the previous owner had deleted drivers and programs from this laptop. we tried to download drivers but the sound/media, the wireless soes not work. some drivers wont load....
I assume that the problem with the modem is due to the missing drivers. Here is the official link for you to download the missing drivers. In case of not using Windows XP change the first line at Windows 2000. Note that officially this laptop in not windows 7 compatible.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 22, 2010 | Computers & Internet
Problem installing broadcom netxtreme gigabit NIC in windows server 2003 R2 standard, the driver doesn't load, error code 38
Determine Correct Driver Click Here
1: Uninstall any unwanted programs.... (make sure/Try to Clear your Hard Drive more than 50% as free)
2: Update virus software
3:Restart Computer IN Safe Mode
4: Run Virus Scan
5: Restart in Safe Mode
6: Uninstall Existing Driver Software From Device manager
7: Restart computer in normal mode
8: Start>Run> type %temp% and hit run.
9: Delete all files in this folder....
10:Restart Computer
11: DEFRAG
13: Restart COmp.
14:Install Driver
>Troubleshooting for Error 38
The error message for this error appears as: "Windows cannot load the device driver for this hardware because a previous instance of the device driver is still in memory."
This error occurs when a previously loaded driver is preventing the new driver from loading. To fix this error follow these instructions.
  • Reboot Your PC
  • Open the Device Manager and in the device Properties box, select the General tab.
  • Properties Uninstall(Right Click Mouse) / Disable(In Property)
  • Restart PC
  • reinstall /enable
  • Once you have followed the instructions throughly, reboot your PC
Hope this make you Better Conclusion....Thanks for Using FixYa.....
Apr 21, 2010 | Computers & Internet
Computer does not recognize camera Emachine runing win 7
I assume you have tried to find the Win7 driver otherwise it wont work.
If not available try the Vista driver if available.
Ensure you do NOT plug it in till driver is loaded and remove previous drivers.
Dec 30, 2009 | AlphaVision Alphacam PLUS Webcam
My Phillips web cam doesnt work anymore. BTW I have a Japanese Windows XP When trying to load my driver the it loads up to about 44 percent and then stops. install shield wizard says component transfer...
Good day sir/maam, if the driver does't finish loading, means that the CD or the CD drive is the culprit. try to use the CD on another PC. copy the files to a flash drive (just make sure you get a good copy). then bring the copy to your PC. load the driver again.
If still wont load. problem with the XP, reinstall your XP again. scan your files with antivirus and also all your flash drives. Reinstall your driver. just make sure your PC is virus free.
Oct 08, 2009 | Computers & Internet
Acer dvd drive not being recognised
go to device manager uninstall your dvd then try again
Sep 30, 2008 | Acer Aspire 5610-4648 Notebook
Acer aspire 5920 notebook and the 5 in 1 sd card reader
sure...I'd say you need to do a system restore to a previous point, or get new sandisk drivers from their site
Jun 12, 2008 | Computers & Internet
Webcam wont load
If the two (cam + laptop) have not worked together before, it might be due to drivers problems. Most drivers are very OS specific. In some instances Vista has been known to have USB and/or compatibility issues. On the otherhand XP sometimes requires that you uninstall the old drivers, reboot before (re)installing new drivers, reboot before installing the hardware and allow autodetect and auto install.
If the two (cam + laptop) have worked together before and now doesn't, it might be due to hardware problems such as the cord, the cam itself or the USB port of the laptop. If your other USB devices works, then USB port(s) can be ruled out. You can verify that the camera works buy installing it in another PC.
You can verify OS compatibility of your camera as well as updated drivers at the Logitech website. Additionally, you can check for Microsoft updates/patches and fixes like this USB patch for Vista.
Should you need additional information, pls post back with your cam's brand/model, your laptop's brand/model and your OS version.
Hope this be of help. Good luck and kind regards.
Jan 13, 2008 | Logitech Webcam
Ideaworks WiFi Antenna Booster - Long Distance Wireless up to 1/2 Mile Away by Logo
480 people viewed this question
Top Ideaworks Radio Communications Experts
eradiostore
eradiostore
Are you an Ideaworks Radio Communication Expert? Answer questions, earn points and help others
