Question about Beam Industries 2775 Serenity Plus Central System Vacuum
Switch in serenity plus canister is arcing and is stuck in the on position. Can this switch be replaced easily? I'm pretty mechanically inclined. jim
Switch arcs with power on. System power cord currently unplugged from wall outlet. Unable to turn power switch to off position. When power is on system cuts out. It's definitely the switch. Switch should be a fairly easy fix. Do you agree or is there special instructions I need to know. Jim
  • Jim Johnson
    Jim Johnson Apr 10, 2015
    I got tried of waiting for help. I took off the top of the canister and disconnected the switch and took it out. I ordered a new switch. Don't know why the experts could tell me what I just told you. Jim
5 Suggested Answers
  • 147 Answers
SOURCE: The system was turned on manually to vaccum out
It is possible that it is a bad switch/circuit board on the unit. If your unit is less than 7 years old that should also be covered by warranty (manufacturer) however an in home service, should you require someone to come to the house will not be covered.
Posted on Nov 03, 2010
  • 147 Answers
SOURCE: The Vaccum is not turning
you can test this out by taking a small metal spoon and with the bottom side of the spoon insert it into the vac outlet on the wall. you want to touch the two metal pins inside the vac outlet to test if the unit is the problem or the hose is the problem.
If the unit starts, the hose should have a 3 year warranty on it. I recommend you have your nearest beam dealer check it out.
If the unit does not start, it has a 7 or 10 year warranty, the circuitry should be replaced. Again have your nearest beam dealer check it out.
good luck
Posted on Nov 06, 2010
SOURCE: Stops Immediately. We have a Beam Serenity model
The Relay Control Board in the 2100 is bad. Replace and it should work just fine.
Posted on Feb 06, 2011
small6363
  • 18424 Answers
SOURCE: Need owner's manual for beam serenity plus 2775
download manual here > http://www.beamvac.com/usa/support/manuals.aspx
Posted on Mar 13, 2013
System not working when switched on.Observed 3 amp fuse blown. Replaced with 13 amp fuse and switched to manual. Sparks and noise coming from one motor. ? brushes or motor need replacing.
Fuses blow for a reason. It's never a good idea to replace a fuse with a higher amp one. House fires can easily be started this way.
As for the motor, at this point the whole motor will need replaced.
Jan 15, 2011 | Beam Industries 2900 Serenity Plus Central...
How do I remove the canister ?
grab hold of the two grips on the left and right, left is towards the back and right is towards the front. you will be twisting the pail (right side) from the standard 3oclock position to the 5 oclock position there. the cannister should just fall off the bottom then.
if your meaning the cannister from the wall....
disconnect the pipe going into the side of the machine, unplug the machine remove the 2 low voltage wires from the side and then lift the machine up and off the wall.
Good luck.
Nov 06, 2010 | Beam Industries 2775 Serenity Plus Central...
The system was turned on manually to vaccum out the car and now the only way to turn it off is to unplug it (i.e. pressing the switch on the vaccum canister to auto from manual does not turn it off). Bad...
Nov 03, 2010 | Beam Industries 2775 Serenity Plus Central...
Motor will not start
You appear to be describing a case of motor brushes worn out. They may be replaced on some motors, but if there is damage to the motor armature (the rotating part the brushes contact) rhe brushes mayu not last long.
Mar 11, 2010 | Beam Industries 2775 Serenity Plus Central...
When running, metal parts are banging around. Cleaned filter but nothing in there. Can it be the weights in the bag?
Do not run the vac again. If the banging is coming from the top of canister portion, you likely have a blown top bushing or lower bearing or both in the motor itself.. Either way the motor can usually be rebuilt by an experienced tech, or if you are very mechanically inclined, otherwise a new motor will be required. You should determine the cause in case you have a damaged filter
Sep 25, 2009 | Beam Industries 2900 Serenity Plus Central...
I have a Henry 200 and the red on/off switch is stuck in the on position can it be fixed
Well... It probably can't be fixed, but it can easily be replaced. Depending where you are, spares are usually readily available. If you need more guidance, please post here again, and I'll see what I can do to help. Good luck!
Mar 03, 2009 | Numatic HHR-200 Henry Hound Bagged...
Cannot shut vacuum on hose
Will the main unit operate if you switch to manual operation. If so, then it could be that the PC board has a stuck relay and you will have to replace the PC Board. Could be the switch inside the handle. You take your hose to your local dealer and or someone that you know that has a beam system and plug it in and see if it works or not. If it does, then it is in the main unit, if it doesn't. then there is a problem with the hose or switch asm.
Nov 21, 2007 | Beam Industries 2775 Serenity Plus Central...
Beam Industries 2775 Serenity Plus Central System Vacuum Logo
63 people viewed this question
Top Beam Industries Vacuums Experts
Beamvacman
Level 1 Expert
Thatvacguy.com
Are you a Beam Industries Vacuum Expert? Answer questions, earn points and help others
