Question about Sharp EL-1197P Calculator
How do I set the calculator to round down? - Sharp EL-1197P Calculator
Why does it round up when you put figures in?
Find the switch on the calculator that has an
"up arrow 5/4 down arrow" . If it is set to the up arrow, it will always round up.
Nov 15, 2014 | Sharp Office Equipment & Supplies
HOW DO I SET THE DECIMAL ON SHARP EL-1197PIII?
Up Arrow: Answer is rounded up
5/4 key: Answer is rounded off
Down arrow: Answer is rounded down
The decimal will float if the calculation is multiplication or division
If the decimal selector is set to F then the answer is always rounded down
Aug 26, 2014 | Sharp EL-1197PIII Calculator 12-Digit...
How to round numbers up or down on ti-84 plus silver edition
The calculator is programmed to round up oe down as the case may be. Just select the number of decimal digits you want to keep and the calculator will perform the necessary rounding.
Open the MODE screen. On the line that says FLOAT select the number of digits. you want to keep.
Dec 12, 2012 | Texas Instruments TI-84 Plus Silver...
EL-531X I NEED TO GET IT TO QUITE ROUNDING MY ANSWER
Hi Jennifer,
This may be because of your settings. To change them press SET UP, then select 0 for FSE. Press the down arrow and choose 3 for NORM1 - the calculator should now stop rounding off your answers.
Sep 25, 2012 | Sharp El-531x Scientific Calculator Green...
I have a Casio MS-8TV calculator and want to change the VAT rate to 20% (usage in UK), please. Val
How do I program tax rate into my calculator?
Non-printing models (also applies to HR-8TE printing calculator):
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Printing models (except HR-8TE):
1. Have calculator in "print" mode
2. Press [CA]
3. Hold [SET/%] key for about 3 seconds
5. Press [TAX+]
6. Press [SET/%]
^Top I am having a problem registering the ClassPad 300, it keeps telling me my product key is wrong.
Enter only the numerals, not the letters.
^Top What features do our calculators have?
The attached chart shows comparisons of the different calculator models. This includes graphing, scientific and printing calculators. download the chart here
^Top What is the [F CUT 5/4] switch or [DEC] F, 0, 2 button for?
The HR-8TE/HR-8TM have a [DEC] key with F, 0, 2, and 5/4 over it, while many other calculators models have a switch labeled [F CUT 5/4].
The button or switch can control rounding off to a certain number of decimal places. F is floating point (no F indicator on screen), 0 rounds off to 0 places after decimal point, and 2 rounds off to 2 places after decimal point.
The 5/4 applies to either the 0 or 2 modes, and describes the type of rounding off that is performed. The calculator will round down if the digit after the one you are rounding to is 4 or lower, and round up if the digit is 5 or higher.
^Top What is the [5,4,3,2,1,0 ADD (2)] switch used for?
This switch is used to determine how many decimal places your answer is displayed in.
ADD (2) is often used for monetary calculations, so that it is not necessary to enter the decimal point. It is automatically placed two decimal places from the end for cents. For example, entering 123 will display as 1.23.
^Top Why do I get 111.1111... when I calculate 100+10%?
This is a markup on price procedure. The formula is as follows:
Markup%=(Markup Price-Cost)/(Markup Price)
^Top Why do I get the wrong answer when doing a percent calculation?
Make sure that you are following the correct procedure.
Adding 10%: 200 [×] 10 [%] [+]
Subtract 10%: 200 [×] 10 [%] [-]
^Top What tests are calculators permitted for?
AP Calculus requires a graphing calculator.
Any graphing or scientific calculator is permitted on the following as long as it does not have a QWERTY keyboard, electronic writing pad or a pen-input/stylus-driven interface:
PSAT/NMSQT, SAT I
SAT II Math, IC & IIC
AP Statistics (graphing expected)
AP Chemistry
AP Physics
May 27, 2011 | Casio Parts Cash Register PC Desktop
The calculator is rounding all of my results. I think this is a feature made active by the 5/4 button but I can't seem to turn it off.
You cannot. You must choose either round up, round down or round off (5/4) position, and then set the decimals switch. You would usually use round off (5/4) and decimal set to 2.
Apr 05, 2011 | Canon P170-DH Calculator
My calculator is rounding to nearest whole number. How do I fix this?
You should move the rounding switch on your calculator. It has three options: an up arrow on the left side (for rounding up) a 5/4 sign in the middle (for rounding off) and a down arrow on the right side (for rounding down). borbalint.png
You may also have to move the decimal point selector switch to set the decimal point position.
Mar 15, 2011 | Canon P23-DHV Calculator
It keeps adding up to one decimal place...I want exact calculations. How do I do that???
You must have accidently set the calculator to round your answers. To fix this, click the MODE key, scroll down to FLOAT, and click ENTER.
Mar 03, 2011 | Sharp EL738C Scientific Calculator
Whenever I try to add or subtract a number with a decimal in it, when I press the + or - key, it rounds the number I entered either up or down to the nearest whole number.
You have the calculator set to round everything in the display to zero digits after the decimal point. To change this, press SHIFT [DISP] and then a digit representing the number of digits you want to the right of the decimal point.
Nov 09, 2010 | HP 10bII Calculator
I must of hit a button, now my calculator rounds all my numbers how do i fix that?
There should be a switch that has 5/4 on it. This is the rounding switch. Place it in the Up position to round all numbers up, 5/4 to round down when the next digit is less than 5 and round up when 5 or greater, and the down position to always round down.
Feb 26, 2010 | Basix BX-PC102 Calculator
Sharp EL-1197P Calculator Logo
43 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
