Microwave Ovens Logo
R
Ryan Boeur Posted on Mar 31, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where to start in troubleshooting?
Hello, my microwave has died out of warranty, only used for 3 months, and was heating a small bowl of pasta when it quit. It is completely dead. Where should I start in troubleshooting it? I haven't worked on a mocrowave before, but I have fixed SMPS and other line voltage electronics. Any help would be appreciated.
  • Ryan Boeur
    Ryan Boeur Apr 01, 2015
    I'd like to add that the main fuse was blown when I removed the cover.
  • Ryan Boeur
    I replaced the main fuse and it started working again, tried it with a bowl of soup. Is it likely the fuse blew due to poor airflow around the microwave?
Dan Apthorp
Level 3:
  • In Master 2,824 Answers
  • Posted on Apr 01, 2015
Dan Apthorp
In Master
Level 3:
Answers
2824
Questions
0
Helped
889945
Points
7391
There should be a fuse some where in the works. Mine quit and I replaced a fuse and is ok now.
  • Ryan Boeur
    I replaced the main fuse and it works again, still curious as ot the cause of the fuses demise, though.
I have the cuisinart 14 cup food processor. I have not used it in probably 6 months and today decided to make a pie crust. Everything is ready to go and when I press ON nothing happens. I made certain...
Sometimes mating the bowl to the base does not depress the indented safety start button at the front of the base. This can happen more often if you pre-assemble the bowl and lid before mating to the base. Sometimes also the plunger rod in the bowl (that pushes the indented safety button) gets fouled with debris and does not slide nicely up and down. You may have to clean that area.
Test the safety button .... take the bowl off and take a small screwdriver to depress the button while activating the start lever. BE CAREFUL ... since the center drive cylinder will spin. If the motor turns on and drive cylinder rotates then the problem is how the bowl was mated to the base. If the motor does not turn on ... then it could be the motor/wiring/switch.
Helpful?
Good luck with your troubleshooting
1helpful
2helpful
Hello, I have the whirlpool microwave oven, Model ...
logic board needs replacement if it cannot be reset.
Microwave taking much longer to heat food
The microwaves are produced by what is known as a KLYSTRON TUBE. Like anything, early failure is possible. There is also the possibility that the transformer or electronic circuit providing the correct voltage to the KLYSTRON has failed, either from over-use, manufacturing defect, or leakage from the KLYSTRON enclosure, which creates heat.
With microwaves being as CHEAP as they are, replacement should not be an issue.
Sharp microwave losing cooking power
If the supply voltage is low it will take long time to heat foods. The second reason is the Magnetron. Since it is in the warranty period you can call at the sharp authorised service center. They will do it free of coast.
Erratic microwave heating
Your magnetron is failing.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing [email protected]
Microwave shuts off about 10 - 30 after starting to heat an item. Display flashes PF. Which I figure is power failure. Unit is 5 months old and has very little use. Model WES1130DM1WW purchased at...
It should have a one year warranty, right? If so, Westinghouse should take care of it for you.
Contact Westinghouse Small Kitchen Appliances at 800-245-0600 or 800-947-3745 or see http://www.saltoninc.com/contact/contact.html
We're happy to help and we appreciate your thoughtful rating of our answer.
No heat
COINCIDENCE? Yes... :) So go buy another one, it'd probably be cheaper than getting the bad one repaired.
Geno
Top In Microwave Ovens Experts
vince
Are you an In Microwave Oven Expert? Answer questions, earn points and help others
