Question about Building Materials
I have a porch which is double glazed in aluminium. The door is sagging at the lock side. Can you help me align it please. Thank you.
  • 611 Answers
SOURCE: drivers side door is sagging
you could try some door shims in the hinges
Posted on Jun 22, 2008
  • 1861 Answers
SOURCE: driver side door lock
Pull the door panel & replace the electronic lock solenoid.
Not easy, but this is what you need to do.
Posted on Sep 09, 2008
  • 148 Answers
SOURCE: How do we adjust an aluminium door?
the door has a cam that has to be adjusted to force the pin up
call a local glass company and ask them where the adjustment is located
there is usually some type of access plat near the bottom of the door frame close to the hingee on the inside close to the bottom
Posted on Jan 06, 2009
  • 140 Answers
SOURCE: door sag
Hello, you need to replace the hinge pins and bushings. Just take a hammer and knock the hinge pins out and put the new pins with bushings in the hole and tap it into place. Some vehicles have a locking ring on the bottom of the hinge pin just knock it off with your hammer and a screwdriver. They don't have to be replaced but, if you want the dealer sells those too. Good luck and any questions please ask.
Posted on Jan 23, 2009
dragonsthatk
  • 547 Answers
SOURCE: Installing upvc french doors and frame
you only want 1/8 th inch all the way around the door make sure to level hinged sides and shim them in make sure to constantley look by opening and closeing door that you have 1/8th all the way around
Posted on Feb 11, 2009
How do i align my frigidaire front loading washer door?
Thank you for your post, friend!
I understand that you're asking how to align the front door of your Frigidaire washer. I would recommend having a professional come out to your appliance, some of these intricate parts do require precision and patience. I hope this is helpful. -Matt
Sep 07, 2014 | Frigidaire Washing Machines
DISSASEMBLEY OF A DOUBLE PANE GLASS WINDOW TO REMOVE WHITE FROST GLAZE BETWEEN THE PANES?
How to Replace Double Glazing in uPVC WINDOWS Cheaply replace blown double glazed window panes in uPVC windows following this video. You just need to look for a local double glazing supplier. Look in local directories for uPVC or Glass manufacturers or suppliers, or use the Internet. Some also deliver to your door. Save a fortune by doing it yourself! Go to this youtube video: https://youtu.be/hyn8BQXgquE or search on google for "comeinhandynow double glazing"
Sep 07, 2012 | Home Fencing
I have moisture between the panes of large fixed glass window. Is there any way to remove that moisture?
Jul 26, 2011 | Garden
Drivers side door sags towards truck gradually so it is out of alignment by about 1/8-1//4 of an inch and will not shut
Probably your hinge pins and bushings are worn out.Most parts stores sell hinge pin kits and the door spring compressor for removal of the door spring.You may also need some help door is heavier than you might think.
Apr 17, 2011 | 1991 Buick Century
Our back door (double glazed with locks at top, middle and bottom) has become permanently locked from the inside. It would appear that the lock at the top has bolted shut. (We have safestyle doors and...
Hi, W/D here.
Easy fix. Your upper locking bar has slipped. While someone is holding the door handle in the open position, you'll need to push the upper lock bolt back far enough to get the door open. You can slide it back carefully with a screwdriver or knife, a little at a time, while holding slight tension on the door with the handle. OK, door's open. Remove the inner door lock cover plate. The lever and locking knob will come off with it. Remove the mortise cover plate, on the edge of the door. Insert a small, thin bladed into the upper alignment slot in the lock behind the mortise cover plate, and loosen the upper allen screw behind the inside lock cover plate. Use the screwdriver to engage a slot in the locking bar, and raise or lower the bar until you have it level with the alignment slot. Tighten the allen screw.
Sometimes, the bar is so far out of alignment that you will have to gain access to the other end of the bar, in order to raise or lower it. This is done by removing the plastic cover on top of the door, and using needle nosed pliers to move the bar.
This should fix you up.
Best regards, --W/D--
Jan 28, 2011 | Locks & Locksmithing
95 chevy blazer 4 door. driver door started to sagg slightly, shortly after the interior light wont go off without pulling the fuse. then the power door locks wont work. Ive heard when door is shut it must...
with the door sagging it may not be pushing button in far enough to shut light off or aligning with button right.Replace bushings in door.The fuse is probably the same one for light and door locks.
Sep 18, 2017 | 1995 Chevrolet Blazer
Driver door won't close 1999 ford contour
Drivers side door will not close because, it might have dropped out of alignment and is sagging down slightly!!! or if it has electric door locks, and someone in the family has failed to mention door locks were activated while that one door was still open!!! now lock mechanism has passed it's normal stopping place and is now stuck, therefore already locked and not allowing door to close all the way!! you might try disconnecting battery then try jiggling the lock, and hope silenoid didn't get burned out, open passenger door and look at lock latch, then check drivers side lock latch!!! if your lucky lock latch should unlock when battery is hooked back up. i have seen this problems happen often on older vehicles!!! especially on cars or trucks that have been in fender benders.........body shops know what to check for, they fix problems like this often!!!!! Good luck!!
Dec 13, 2010 | 1999 Ford Contour
Refridgerator door sags
Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
Good Luck!
Sep 15, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Nov 26, 2008 | Locks & Locksmithing
Building Materials Logo
759 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
