Question about Paul Frank Paul PF254 Frank Projection Clock Radio
The light from the projector that shines the time on the ceiling does not come on.
I can't find a place for a new bulb or a battery to make the light come on so I can see the numbers on the ceiling
I can't get my Vivitek projector a d952hd model to show light anymore - it is only 6 months old and I doubt it is the bulb as it looks new and the image had not diminished at all in recent weeks - we...
hi,
All projectors have self dioganisng function. If there is any malfuction inside the projector it will indicated by the LED blinking. You have to inspect how many time the LED blinks or which LED lights condinuosly. LED meas the power light or the lamp light. Then only anybody can suggest you a better solution.
ok
Jun 21, 2011 | Vivitek D825MX DLP Projector
My projector has gone completely blurry and extremely dim. I have no idea what's caused it. It still seems to be able to project the right colors...just very dim and blurry. Is it the bulb (my bulb has...
either the optical parts close to the lamp are getting old and heat affected, or the focus lens system is dirty etc.
switch off the unit and disconnect the power.
remove the lamp. remove the cover off the whole projector.
get a 50w halogen lamp (like in the ceiling of the house) and connect it to a 12v supply.
Then carefully put it into the cavity where the lamp normally goes. and shine it in the direction that the lamp normally shines. be carefull not to burn yourself and the bits inside.
check the strength of the light as it goes through the various sections of the optical path.
see where the brightness seems to drop right off. see if there is any components that seem to degrade the light strength.
this may give you a clue as to where the problem lies. you can then decide what the next step is.
tell us how you go.
Mar 03, 2011 | Epson EMP-TW600 LCD Projector
Projector been in storage for 20 years - fitted new bulb and rubber drive belt C. All working but light not shining through lens. Any ideas please?
Old film projectors had a spinning disk with cut-outs in the light path (looks like a fan, but flat). This blocked the light when the film was moving between frames, then let it shine through when the film was stationary. It sounds like this disk has become stuck or is not being driven (another belt?).
Jan 15, 2011 | Cameras
Projector light does not shine. (Power is on, bulb
I will assume from your description that the projector is powered on and you can look in the rear vents and see the lamp illuminated, yet the light does not shine on the screen.
The Ektapro 9020 and most of the Ektagraphic line of projectors are equipped with a "dark shutter". What that does is keep the screen dark unless a slide drops into the gate. At that time the sensing circuits trigger and open the shutter, allowing light through the slide & onto the screen.
Dec 16, 2009 | Kodak Ektapro 9020 Slide Projector
Replcing bulb
There is lamp cover at bottom of projector, unscrew it, take it off, you will see Lamp inside that also fixed with screw, unscrew it and take it out, place new lamp and put thing in same way.
Jun 09, 2009 | NEC MultiSync LT280 LCD Projector
No light projects.
Try resetting the projector by pressing and hold the two Keystone buttons, then turn ON projector. Hold down the two Keystone buttons for 15 seconds, then turn OFF projector.
Turn ON projector, the new lamp should strike.
Mar 11, 2009 | InFocus ScreenPlay 4805 Multimedia...
Infocus X1 lighting problem
Well there are only a couple of things that could cause this problem. However considering this all started when it was mounted consider the possibility you may have used screws that are too long and are is/are subsequently shorting something out.
Cheers
Oct 14, 2008 | Apple InFocus X1 Multimedia Projector
My projector won't come on.
I answered this question many times. This is caused by a failed color wheel sensor. It faile gradually, first the lamp flickers, sometimes go dim for no good reason. Finally the lamp will not strike and you will get two red warning lights. I am factory trained and I stock the redesigned senor.
Aug 30, 2006 | HP vp6320 Multimedia Projector
Paul Frank Paul PF254 Frank Projection Clock Radio Logo
87 people viewed this question
Top Paul Frank Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Paul Frank Audio Player and Recorder Expert? Answer questions, earn points and help others
