No drum movement door remains locked after drain program
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
New door inter lock
Posted on Apr 14, 2015
5 Suggested Answers
SOURCE: No drum movement during wash/spin cycle, although it fills/drains
brushes need replacing in motor. Usually cheap enough to buy and do yourself.
Posted on Jun 02, 2009
TheMobilian
  • 8220 Answers
SOURCE: I HAVE A FRONT LOADER, WATER NOT DRAINING
Start here0e4f85f.jpg 8a7ddc2.jpg ce6b1cf.jpg88e38f7.jpg d13de4f.jpg .635d190.png
Posted on Jun 15, 2010
blueextc3221
  • 15935 Answers
SOURCE: door locked. drain & spin flashing. time
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
richroth
  • 9472 Answers
SOURCE: Frigidaire LTF2140ES2 stopped working. Door locks then nothing...no water no drum movement just nothing but a hum, them it shuts off
I is this all the time on the LTF2140ES2 models. You will need to replace the door lock assembly. They fail quite often and cause the problem you are having.
Here is a link to the art you need
Posted on Oct 14, 2012
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Are you suppose to be able to move the tub around when you open the door?
Front load washing machine? If it is it depends on what you mean by move the tub around, if it is just spinning then they do this as the drums do not lock when stopped, if you mean there is excess movement on the inner drum then you can check this by holding your hands at opposite sides of the drums just inside the door opening, locate the outer drum at the rear of the door seal and press your fingers against it and with the other hand press the inner drum in the opposite direction. If movement is felt between the 2 drums when pressed in opposite directions then the drum bearings may have failed or the spider shaft may have broken.
Dec 31, 2012 | Washing Machines
Oct 13, 2012 | Washing Machines
Frigidaire FTF2140ES washer does not spin at any speed setting. Tumbles normally during wash and rinse. Pump operates and drains normally during the spin cycle, but drum remains still (no attempt to spin).
Usually on these models it is your door switch that is defective. There are two sets of contacts one too lock the door and the other gives contact for the spin cycle.
Jun 11, 2011 | Washing Machines
The drum stopped spinning, but could still hera motor running. The door was locked; could not unlock to open. After several attempts of unplugging/replugging door could be open.
Is this a dishwasher or a washing machine that you have a problem with.
The drum is usually in a washing machine. The motor you hear running is the drain motor. So this is a normal operation of front loading washing machines. When the drum stops spinning, the drain pump takes away the remaining water and then a timer lock comes into play to make sure the clothes are settled dowm before you can open the door.
So I do not see there is any problem. Please accept the solution if ok else post a comment to confirm the exact problem with your appliance.
Mar 21, 2011 | Dishwashers
I have a Hoover washing machine, its a front loader, I don't have the exact model in front me at the moment. I recently moved house, and yesterday after re-plumbing my washing machine, I put the washing...
If water remains in the drum after the drain cycle, the unit will not go into the spin cycle. There may be a couple of reasons for your problem.
Make sure the drain hose is raised above the machine hose outlet to create a siphon effect. The drain hose needs to have a loop in it to work correctly. You can tie a string around the hose and hook it on the water valve creating a loop in the hose. Raise the loop of the drain hose so the top of the loop height is at the center of the washer drum.
Apr 06, 2010 | Hoover AI130 Front Load Washer
Front door on washing m/c will not open after washing cycle completed... I've ensured that all water has been drained, but the door remains locked?!?
some machines have a electrical and presure lock most machines you have to wait 2 mins for it to open ,unless it has a cable on it then it has a **** switch witch goes to the moter or pulley whitch spots the door opening when the drum is moving you need to tell me the make and model number
Jun 27, 2009 | Washing Machines
Candy CNA 145 stops
Found that pipe leading from the drum to the filter was blocked. Machine at first appeared to be draining but on closer inspection was not draining fast enough. Machine now working perfectly. Hope this helps anyone who may have a similar problem.
Jul 27, 2008 | Washing Machines
Water won't heat; door won't open at the end of cycle
I drain water from drum and read out say's open door and you hear door release active but door will not open.
Oct 07, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
