I want reset tonner chip plz help me
SOURCE: tonner and cartridge clogged wont print dark
Why do you say it's the toner? Likely the PCU (photoconductor) needs replacing, or laser optics, etc.
If it's not a 'blinking toner light' that won't go away, but rather light copies for no apparent reason, then replacing the PCU is the most likely cure.
SOURCE: how can I reset the
On this model, you cannot. It will lock you out when the chip reports you have reached the maximum pages, or when the printer toner sensing laser reaches the contact on the other side because the toner level in the cartridge is too low to block it. You can replace the chip if you can find one online, or I have access to the chips if you need one. The other issue is that if it has locked you out, it means that the toner is close to low and may only print 10 more or 100 more pages by just replacing the chip, so this may not be a cost-effective solution for you.
SOURCE: how to reset my tonner chip without any instrument
Have you done refilling recently ? If so besides
refilling the cartridge with toner there is a chip in it that you
should change so the printer will know that a new cartridge is installed.
Regards,
FixYa
SOURCE: How to fix error replace/print
You will be wasting money buying just a chip. The toner and all is in the cartridge. Normally when the replace message comes on, the cartridge is shot.
SOURCE: my samsung printer model is
This is a link to view how to reset: http://www.youtube.com/watch?v=Qzc9JImUcak
This is a link to download firmwares (version 1.13, 1.16, and 1.18_fix) and download software to update firmware files to printer: http://dox.abv.bg/files/listtree
MOST IMPORTANT:
1. Push 8 times button MENU then OK to print a report and view your version of firmware
2. REPLACE FIRMWARE VERSION 1.13 ONLY WITH 1.13_fix
3. REPLACE FIRMWARE VERSION 1.16 ONLY WITH 1.16_fix
4. REPLACE FIRMWARE VERSION 1.18 ONLY WITH 1.18_fix
5. REPLACE FIRMWARE VERSION 1.21 ONLY WITH 1.18_fix
6. DO NOT REPLACE FIRMWARE VERSION 1.23, I DON'T HAVE FIRMWARE VERSION 1.23
IF YOU REPLACE FIRMWARE VERSION WITH WRONG VERSION A "SCANNER ERROR" OCCURS AFTER SEVERAL MONTHS WHICH MEANS YOUR SCANNER MATRIX IS BURNED OUT AND MUST BE REPLACED
GOOD LUCK!
