Question about Bissell Big Green Deep Cleaning Machine Professional Grade
Water us coming out of the flow indicator on my Bissell big green deep cleaning machine. Nothing is going into the dirty water tank
  • 3 Answers
SOURCE: my bissell deep cleaner wont
do you mean the little red spinning thing?try unscrewing the clear cover , lift the red thing out and check for hair etc.then put it back together. worked for me, hope it helps.
Posted on Jul 31, 2008
SOURCE: my little green machine won't spray the solution but it will pick
We had the same problem. After dissassembling the whole machine we could not find a clog or any other obvious problem. The manual suggests priming the pump by putting the solution reservoir in and out a few times. This did not help much. What did work was to raise the unit up a few feet above the trigger while depressing the holding the spray trigger. (That is, use gravity to fill the tube.) After solution was flowing freely, we turned the machine on and it seems to spray fine again.
Hope this helps
Posted on Jul 22, 2009
  • 18 Answers
SOURCE: 1672 BIGgreen Wet/Dry Vacuum: my bissell 1672 big green machine has stopped spra...
Refer to the discussion at the other thread: http://www.fixya.com/support/t3309646-pump_motor_sounds_like_running_but_not
You will need to remove the top domed lid to access the working parts. Refer to http://www.fixya.com/support/t3543424-two_top_sections_held_together
Examine the water lines to ensure they are attached to the pump. If you feel you can do so without shocking yourself on any exposed electrical connectors, try disconnecting the inlet hose. Buy a two-foot section of the same size hose from the hardware store and connect it to the pump inlet. Plug in2_bing.gif the unit (be careful!!!) and use the pump switch to see if it draws water. Then try reconnecting the inlet and connect the outlet to the new hose to see if the pump pulls water from through its suction tube and will pump through the new hose.
Posted on May 25, 2010
heatman101
  • 43501 Answers
SOURCE: Bissell Proheat Problem
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
hfjk
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: Bissell ProHeat 8910 wont spray water or solution
heatman101
sgb
My machine will spray from the hose attachment, but not when I am doing floors.
Check Flow Indicator Filter under the Flow Indicator. Turn Indicator cap counter-clockwise, remove rotor. Filter is under rotor and pulls out. Clean filter. Additionally, check LINT FILTER in the clean water tank cap. Check you User's Guide if you have more questions or call the Bissell Consumer Care at 1-800-237-7691 The other thing you can do in this case is reseat the tank. It may be blocking the housing connection but the sprayer connection is smaller and open. Cleaning the filters after each use though is recommended.
Dec 06, 2015 | Bissell ProHeat Pet Upright Deep Cleaner,...
Bissel carpet cleaner not sucking up dirty water why ?
Sounds like a clogged filter. Try cleaning the Flow Indicator Filter (turn Flow Indicator cap counter-clockwise to remove it, lift out rotor and filter under it. Clean filter and reinstall in reverse order); Check and Lint filter on the Heater tank Cap. All filters are recommended to be cleaned after each use. Bissell Consumer Care number is 1-800-237-7691
Nov 24, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
Cleaning fluid leaking out and machine not suctioning up water
First thing is clean the filters: Heat tank filter on the tank cap, and then the Flow Indicator Filter (turn the Flow Indicator Cap counter-clockwise and remove, lift rotor and filter out. Clean filter and reinstall in reverse order) Consumer Care # 1-800-237-7691
Aug 16, 2015 | Bissell ProHeat Pet Upright Deep Cleaner,...
My Bissell Big Green barely sprays any water.
Check you User Guide and see where the filters are. They usually have have a filter under the flow indicator. Turn the Flow Indicator cap counter-clockwise to remove it. Lift out the rotor and the filter is under it. Remove it and clean. Reinstall in reverse order. I don't know anything about the specific machine you have but I know they have a flow indicator from other comments I've read so it's worth the try.. Hope that Helps.
Jul 22, 2015 | Bissell 86T3 Big Green Clean Machine
Bissellshmpooer is not sucking back dirty water
You may have clogged filter. Check your User's Guide for filter locations. Generally there is one under the Clean Water Tank cap (looks like a screen) and if your unit has a Flow Indicator there will be one under it. Just screw the Flow Indicator Cap off and the filter will be under a small rotor. Bissell Consumer Care is at 1-800-237-7691. Hope that helps.
Oct 07, 2014 | Bissell 94Y2 Lift-Off Deep Cleaner Carpet...
Bissell Lift off Cleaner - Big tank does not fill with dirty water- Clogged?
Check and clean the filters. Check you User's Guide or call the Consumer Care at 1-800-237-7691
Jul 31, 2014 | Bissell Lift-Off Deep Cleaner 94Y2
Why is water coming out of flow indicator?
any thing that is put together can leak , and will eventually
Nov 08, 2013 | Bissell Big Green Complete All-In-One...
Bissell Carpet Cleaner pro heat- water doesnt come out
The screw that is located in the center of the handle, that holds the assecory hose holder must be tight. My screw was missing, put one in and cured the problem. Sounds stupid but it worked. Got this idea off the Bissell web site. Also if you have a pump belt it may need replacing.The cover is on the side of the machine. Go to the Bissell web site and look up by your model # and name of machine. There are several quick fixes that you can do yourself. Why pay for expensive repairs when the Bissell site will help you for free. Good luck.
Jun 28, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell Big Green Deep Cleaning Machine Professional Grade Logo
238 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
