Question about Stihl Garden
My Stihl HT 75 pole pruner pulls the shaft out of the clutch housing when I extend it out. Any suggestions on the problem?
  • Stihl Master
  • 1,807 Answers
Sounds like the drive shafts have been put the tube the wrong way, or something is missing from the inner shaft.. I've attached the breakdown manual so you can check.
http://www.mediafire.com/view/ouuv979oehvbm0w
Posted on Jan 05, 2016
STIHL pole saw 101
Hi Little Bird
Chances are that the clutch needs servicing or replacement.
Here's a link that explains:
http://www.lilredbarn.net/Stihl-HT-101-Pole-Pruner-Clutch-s/29554.htm
Cheers
Jun 06, 2016 | Stihl HT101 Pole pruner
Changing drive shaft
You should be able to just pull it out, it just slides into the clutc drum. It be stuck from rust, speay some WD-40 on it an let it set for a while, also try tapping on the clutch drum lightly with a hammer as you pull on the shaft.
Jan 27, 2014 | Stihl HT101 Pole pruner
Echo ppt-266 pole chainsaw will not cut with the pole extended
A very common problem is that the tip of the drive shaft breaks off. If it cuts with the pole retracted and won't cut with it extended, than the drive shaft is pulling out at the clutch end or at the head. Try loosening the screws where the pole goes into the cutting head, stand the unit straight up and twist the cutting head to see if it drops down even just a little bit. After trying that, loosen the screws where the pole goes into the engine assembly and twist it there also. If this doesn't work, remove the pole at the engine end and pull the drive shaft out to inspect the ends of the shaft. Good Luck. George
Oct 20, 2013 | Echo 12 in. 25.4 cc Bar Telescoping Gas...
I CAN'T REMOVE THE SPLINED SHAFT FROM MY STIHL HT101 POLE PRUNER.
Take it to an authorized repair center. Not what you want to hear but its better that way. It is a complicated ordeal that if you aren't trained for you can do damage to the shafts
Nov 01, 2012 | Stihl HT101 Pole pruner
Stihl HT 75 pole saw throttle induces stop
If it dies when you hit the throttle, put a kit in the carb and clean it.
Oct 16, 2012 | Stihl Chainsaw Pole Pruner Ball Bearing Ht...
My stihl pro series pole pruner will not start
Is it getting fuel? Is there spark? Is there compression?
May 15, 2012 | Stihl Chainsaw Pole Pruner Pinion Gear Set...
Garden Logo
301 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
