TV Volume problems, it's Low and won't go Hi
Just started with Volume problems, it's Low and won't go Hi, or The Volume works and after sometime the Volume goes low, even If I press High Volume the static goes high but Volume stays low. Any help would be appreciated, note TV Is like over 20 years old
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
Check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Posted on Apr 01, 2015
Volume bar stands at 200 every time i start my Samsung LCD
set the volume down extremely low power the tv down by plugging out and put on again should be then at set volume,the tv's now days have memory so it should start up at volume preset
Dec 21, 2013 | Samsung LN-S2651D 26 in. LCD Television
2002 Ford Focus SE. Low beams won't go on sometimes. Hi beams work no problem. Turn back to low, they stay on for a few seconds then turn off. Should I be looking at the headlight switch on the da
I would start at the headlight switch check your ground wires and connections at the light themselves also check the bright dim switch
Aug 27, 2012 | 2002 Ford Focus
Sansui sv-2012 tv volume is very low and suddenly increase
Hi srinivas_327,
This is common for some sansui televisions,
All you need to do is to go in the audio settings and turn "ON" the AUTO volume option .
This will help all your channels to have a similar volume , so you won't be surprised by sudden increase in volume.
Hope this helps ...:)
May 10, 2011 | Televison & Video
Volume making humming noise when on
there is a bad ground.
the hum you are hearing is ac getting into the audio.check all the rca plugs on the set are plugged in all the way.do not run them close to a power bar either.
sometimes a second unit with it's own volume is hooked up to the tv and then the tv volume is up too high because the other box is turned down.if there is a unit hooked up,turn it's volume up ,and the volume on the tv down,otherwise the tv will amplify the residual noise.cheers,ed
Jul 04, 2009 | Proscan 32LB30H LCD TV
Volume control for model TXD1972
This may sound stupid but try this turn the volume knob to high and low continously for a few seconds sometimes the contacts become dirty and just a little movement back and forth quickly repairs it. I said SOMETIMES.
Sep 04, 2008 | Samsung TXD1972 19" TV
Volume controls dont work when using remote
I would start by trying other codes on the universal remote. Sometimes codes will only work part of the remote such as the numbers or channels but not volume. Your motorola cable remote sounds like it may only need a good cleaning. sometimes when you take remotes apart it will look like somthing got spilt in it. I would start there first.
Mar 17, 2008 | Sanyo DS27910 27" TV
Fluctuation in sound output on Cambridge Soundworks 5.1 speakers
Hi Paulus
A lot brand of speakers, like Sound Blasters, Logitech, Cambridge, has this (strange) kind of volume problem, sometimes, is the resistor, in the volume control, sometimes in the modulator for the board on the sound speakers, Subwofer.
I use a general tip is let the volume in one setting and don't move in the intermediate low volume say....9 .
from other thing, be change the speakers.
Nov 25, 2007 | Cambridge Soundworks Movie Works 108...
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
