Dexter stack dryer..top dryer not heating over 110?.
  • Washing Mach... Master
  • 5,323 Answers
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Posted on Apr 13, 2015
  • Anonymous Apr 13, 2015
    Thank you very much for your help.
  • Jorge Rendon
    Jorge Rendon Apr 13, 2015
    yOUR WELCOME LET ME KNOW IF U NEED MORE HELP
shaggyrat
  • 1224 Answers
SOURCE: Whirlpool LTE5243D Top Load Stacked Dryer heats sometimes and not others
couple things this could be lets start obvious
faulty door switch even though door latches doesnt mean its working properly
bad guages easy to check dont have to run dryer just guages
turn on setting let run threw cycle if it stops on cycle and dont move for a length of time this will be the problem
these 2 things are main causes of why a machine wont work or partcially works at times everything else is easy
Posted on May 29, 2008
aborcass
  • 2651 Answers
SOURCE: Can you convert a 220 dryer element to a 120 ellement
no that machine is wired for a 220v. has 220v components in it. no way to change that sorry
Posted on Feb 23, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have a Kenmore 97912 / 97922 Top Load Stacked
Symptom: Electric Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
Double check the input power for your dryer FIRST. You should have 220VAC at the receptacle and terminal block.
The dryer will STILL tumble and the timer will still function with a portion of the input power missing as these circuits only require 110VAC.
The heating circuits, however, require 220VAC to function. If one leg of the receptacle voltage is missing the dryer may exhibit "No Heat" like symptoms.
This could also be an indication of a burned or failed power cord.
Continuity checks performed with the dryer UNPLUGGED should indicate a short between the prong end of the cord and the respective lugs at the terminal block.
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer.
Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason.
You need to ask yourself when the last time you cleaned the dryer ventilation.
If you can't remember, or if it has never been done, this can contribute to the dryer failing.
All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail.
This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH.
When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home.
It should be clear with no kinks or clogs.
If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect.
RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER.
After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer.
This will prove that your blower fan is working properly or not.
Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it.
If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely.
I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires.
These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step.
If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits.
If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips.
They will be located along the seam in the front about 2 inches in from each side.
If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel.
(HINT: placing a block of wood under the front feet of the dryer can make access much easier).
If your dryer has no lower kick panel, you have to remove the entire front panel on these models.
This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) - remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component.
NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time.
They are often sold as a set. Without doing so, these components can cause potentially fail again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for asswering your FREE question.
Posted on Sep 18, 2010
blueextc3221
  • 15935 Answers
SOURCE: F11 code dryer stacked on top of washer can not ...
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^!^!
Posted on Sep 29, 2010
badfrankie
  • 92 Answers
SOURCE: i have a frigidaire glet1142cs0
UNPLUG THE MACHINE. Take the back off the dryer, usually 4 to 6 screws. On the backside of the panel you just took off should be a schematic showing where the thermo fuses are.
Take an ohm meter and check across the prongs sticking up, you may have to unplug them to get good contact. They should show 1, open, if they show 0, short. they need replaced. There are online parts companies that can help you get the right part.
It is unlikely that the element is bad, but if the thermo fuses show open, then you should be able to see the element, and replace it.
Posted on Mar 27, 2011
No heat for my frigidare fex831cs top load stacked washer dryer
ELECTRIC Dryer no heat or little heat:
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Feb 17, 2014 | Frigidaire FEX831CS Top Load Stacked...
Does this combination unit need both a 220 volt for the dryer and a 110 volt for the washer?
yes in that way work. Is o.k the power for dryer will be more strong that the washer, The reason is heating elements fro dryers.
God bless you
Sep 28, 2012 | Whirlpool LTE5243D Top Load Stacked...
Hello.. I have a 220v stack washer and dryer unit. I live in hawaii and never use the dryer and electricity here is at a premium. I would like to run just the washer on 110 and disconnect the dryer and run...
Hello Troy, I have checked the schematic which should be located behind the sloping front panel above the washer lid. The washer portion is powered by 110 vac supplied from the dryer's L1 connection (black) and the neutral (white). It should be quite simple to make an adapter with "hardware store" parts like a standard 20 amp plug and an appropriate 220 volt receptical. Please verify that the neutral lead goes to chassis ground and make use of the 110 plug's ground to the receptacal ground (green headed screws) with a seperate lead, for your safety. When the machine is plugged into the adapter, only the washer should function.
As a final note, I see that the dryer motor and timer are also 110 volt but are connected from the other hot lead, L2, to neutral. Only the heater is powered by 220 vac. Therefore if you should connect to L2 by mistake, only the dryer drum would operate. Unfortunately, I do not see a simple way to make both the washer and dryer run on a single 110 feed.
Jun 04, 2012 | Kenmore 94812 Top Load Stacked Washer /...
I bought a used stacked washer /dryer. I hooked it up likea standard 220 dryer. Has the standard dryer plug in. Would not run start or hum in 20 mode. Checked the wiring. looks like it was wired for 110,...
All standard dryer motors run on 120V. Its the heater that uses 240. Its possible to wire a dryer for 120V operation and it will appear to run ok but it won't heat efficiently and it will take several cycles to get the clothes dry. Sounds like you have a mechanical problem with the motor.
Jul 14, 2011 | GE WSM2700W Unitized Spacemaker Washer and...
Its about my washer/dryer combo whirlpool model lte6234dqs: -the dryer don't produce hot air and therefore don't dry. -Anybody please?
check your breaker to the appliance you must have 220 volts before it will heat if you only have 110 volts it will run but not heat otherwise it could be a thermostat or heating element which is hard to say with out me being there to check it out with a meter
Nov 19, 2010 | Whirlpool LTE5243D Top Load Stacked...
Dryer will not heat
if the unit turns on anf the drum tumbles you may have a bad heating element or thermosta sensor
Sep 16, 2009 | Frigidaire FEX831CS Top Load Stacked...
Where can I locate the blown fuse/s of a frigidaire dryer?
There are no user servicable fuses in the machine, I believe they are talking about your breaker box.
A 220 dryer requires two 110 volt circuits to run the 220 volt heater
The motor and control circuits only require 110 and are run from only one of these two lines. If the other line blows the dryer will still run but there will be no heat.
Good Luck
Quentin
Jul 06, 2009 | Frigidaire FEX831CS Top Load Stacked...
The heating element won't get hot? Each wire to the element is getting 110v, but when checked together i am not getting 220v to the element?
Hi: 220 volts to a dryer are two 110 volts combined. Two separate wires. Did you check the heating element? See if it's broken. If so replace it. FIRST, Another thing to check is your circuit breaker. If it has only one side blown you will show 110 volts but that's all the dryer will get and dry slowly. The washer will still work as it's only 110v. I hopes this helps, Jeff
Jun 07, 2009 | Kenmore 88752 Top Load Stacked Washer /...
Dryer dosn't heat up.
The heating element most likely failed and needs to be replaced. It cost about 25 dollars for it and you can do it yourself just remove the back panel unplug the machine and the wire have a adapter that can be removed by hand
May 22, 2009 | Kenmore Dryers
It runs, but no heat
i dont believe at this time its anything mentioned at top most people dont realize that dryers are split cuircuts
is this a 220 setup
and if its a 220
the cuircuit breaker for this is set by 110 each one for the heating element one 110 for the guages and motor
goto circuit breaker and flip the breakers this should return your dryer working ability
other thing is are the guages working properly
dryer doesnt have to run to test guages turn to the highest setting and let them run completly threw cycle if they stop on a particular setting for a long length of period then the guages are bad
May 29, 2008 | Whirlpool LTE5243D Top Load Stacked...
Washing Machines Logo
210 people viewed this question
Top Washing Machines Experts
