Water drains, but drum does not spin. What is the process for removing the washer bottom and replacing the motor coupler?
  • robert Mar 31, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? How about make and model?
  • Anonymous Mar 31, 2015
    Kenmore Laundry Center Electric Washer Model 98802/98804
  • Washing Mach... Master
  • 932 Answers
Anonymous,
Some washers do have a coupler that drives the transmission. If you can give us the model and brand, we can better help you. If it is from the Whirlpool family and is at least 15-17 years old or newer, it will have a coupler that drives the transmission. You would need to remove a couple of screws that hold the control panel to the top and then pull forward on the control panel only about a half inch then left up and swing the panel back over the back panel. There are two metal clips that hold the outer shell to the back panel and you need to remove them by putting a screwdriver into the front slot and push the screwdriver handle away from you until it pops the clip up out of the hole. Unplug the connector that is at the back of the washer and then pull forward on the shell and it will come off showing you the drum and frame it is mounted on and the pump, motor and transmission under the frame. You will have to remove the pump first by taking out two screws that are a 5/16 nut driver and then pop the clips that those two screws go through. You can then pull your pump off to the side and remove the motor behind it by popping the clips that hold it in place. The coupler is on the back side of the motor and there are two matching parts of the coupler unit. You will have one on the motor and one on the transmission and there should be a rubber union that joins the two. More than likely, either the rubber has worn out and snapped several of the pegs on the two coupler halves or the hub on one side has split. Either way, the best solution is to replace the entire coupler assembly and you can only get it as an entire assembly anyway. After replacing the coupler, just re-assemble in reverse order. You can probably find a you-tube video online if you need help. Hope this helps.
Posted on Mar 31, 2015
    Hi John. Its a Kenmore Laundry Center Electric Model 98802/98804.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
There isnt a motor coupler the drum spins on a belt connected to the motor the pump has its own motor seperate from the drive motor
    Must be the "belt - washer. part # 131686100.
A load goes through a complete cycle but the clothes are still wet. i can see the drum turning during spin but in my opinion not fast enough. what could be the problem?
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 21, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
How come after we wash our clothes there is water that comes at the bottom but inside the washer??
Jan 15, 2010 | Washing Machines
Towels come out soaking wet, too wet to put in dryer. When placed back in dryer, noticed the spin cyle runs slowly, never spinning fast. The drum itself isn't solid, but oscillates when spinning.
Jan 01, 2010 | GE WSXH208A Front Load Washer
Clothes are sill soaking wet after sin cycle
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Aug 18, 2009 | Maytag EPIC MFW9700S Front Load Washer
My clothes are always soaking and the machine always has water in the bottom i take the filter out and drain it at the bottom but it always fills up again
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
May 05, 2009 | Whirlpool LHW0050PQ Front Load Washer
Bosch classixx6 1200 express - brand new
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Mar 14, 2009 | Bosch Classixx WFC 2465 Front Load Washer
My Kenmore 80 series washer just started making a loud Aihaiha electrical or motor type noise. This happened during a heavy load cycle. Noise was very loud. When I click to regular, delicate or hand wash....
The following are the reasons for the drum not spinning :-
* Test the lid switch
* Test the timer control
* Test the centrifugal switch
* Test the water level switch
* Inspect the motor coupler
* Inspect the drive belt (belt drive only)
* Inspect under the washer for soot (clutch)
* Test the motor
* Inspect the pulley
* Test the transmission
In the case of loud noises in the machine, the drum bearings might have been damaged and might need a replacement. Also do check the leveling of the machine. Good luck.
Feb 28, 2009 | Washing Machines
Hoover Saver 1300 Washer Dryer - drum not emptying fully
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 18, 2009 | Washing Machines
Washer does not remove water in final spin
If washer hums when it should spin, and the washer will not drain, you may have 2 issues.
First check that the drain pump, drain hose, and wall drain are free of debris.
The washer may not spin properly if the drain system is not operable.
Once you are sure the washer drain pump, drain lines, wall drain, and drain hose is okay, run a test wash.
If the washer hums but now drains, you fixed one issue.
If the washer still hums, you may have a bad belt, motor coupler, motor itself, etc...
Check parts for wear and replace as necessary.I pulled the drain impeller and found a sock from my little guy stuck in there. Fixed!
check all water outlets to make sure there is nothing blocking the pipes.
you could also go to this link it might help you out..... Washer does not remove water in final spin Google Search
Oct 24, 2017 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
