Question about Electronics - Others
My memory is too low so I added an SD card but how do I switch to that to download on
    New Friend:
    Problem Solver:
  • 14 Answers
Your memory is too low? Or your storage capacity is low? Two totally different things. Memory is not what an SD card is, it's strictly storage.
Make sure your computer recognizes it. Start, computer, then plug it in. It should pop up, that's your drive letter to use.
Posted on Jun 04, 2015
3 Suggested Answers
  • 21 Answers
SOURCE: SD as hard drive--windows XP download
An SD card isn't usually used as Hard Drives as they don't contain enough space. Although they are getting bigger and bigger capacities all the time!
I think what your after is booting your computer off the SD card which will have Windows on it? Some computers can boot straight from the SD card, my old laptop used too!
What needs to happen is that you need to go into your BIOS settings (which are your motherboard settings) and in ther you can set boot sequence, so by default most are set to Hard Drive first. The computer looks there first for the operating System. So you need to tell your Motherboard to boot from your SD card 1st. Now your motherboard needs to be able to support this feature, my guess is that it probably wont.
Go into the BIOS and find the boot sequence and scroll through the available options, if SD is in there, set it. If not your motherboard wont support booting from SD.
Posted on Mar 23, 2008
SOURCE: my mobile memory card has been locked i want to
cannot read for psp memory stick pro duo 4gb
Posted on Feb 21, 2010
I constantly get phone storage space is low. I've added a SD card, it says there is 1.02GB available. I've deleted stuff and everything.
Your cell has TWO memory locations. One is the removable memory card and the other is the internal, permanent type. The messages you are seeing are about the internal memory. You should make sure / move all your pictures, videos, music & downloaded files are on the removable card - NOT the internal memory. You will find some applications are perfectly happy on the removable card - and some are not. If you need more room - try moving as many apps as you can to the removable card. Once you've done this - you should be in good shape!
Oct 27, 2015 | Blu Quattro 5.7 HD Mobile Phone
I added a 16GB SD card to my tablet because it was low on space. Transferred everything to SD card that could be transferred but now updates needed for games will not download stating lack of space.
Move some of the items from internal memory to you we card. I had an issue moving an ad card from one device to another and had to reformat the ad card in the new device.
Sep 21, 2014 | Nextbook Tablets & eReaders
How to unlock a sd card on a hitachi dz bx 35a
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects photos on the memory card and prevents photos from being deleted or added to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts and you can save photos on the memory card.
Apr 03, 2013 | Cameras
What do it mean when it says card is locked
Apr 02, 2013 | Cameras
SD memory card is locked. How do I unlock it?
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Jan 20, 2013 | Sony Alpha DSLR-A290L Digital Camera
I HAVE A SYLVANIA NOTEBOOK 7 I GET NOT GET ON FARMVILLE YET I GET GET ON DIFFERNT GAMES I EVEN INSTALLED A 8GB SD CARD IT SAYS MEMORY LOW TO CLICK ON RESERVE MEMORY BUT IT WILL STILL NOT LOAD
That sounds like a java problem, uninstall java in ad and remove programs and re-download here.
http://www.java.com/en/
An SD card will not help the system becuase the computer does not know to use it as RAM. To see the amount of RAM installed in the computer, go to the control panel and look at the system properties.
Mar 01, 2011 | Computers & Internet
Canon sx10 when i put in a sd card card error comes on the screen i have tried new card makes no difference. williamberry25@hotmail.com
I don't know if you are aware of an SD card having a protection lock on the side I'll give you a diagram for the proper positioning of this little switch. Also adding that all "New" memory cards need to be formatted to the camera they are being used in. Formatting prepares the surface to properly accept new picture files from your camera also after each download the memory card needs formatting. I'm talking formatting not the delete or delete all buttons, formatting option should be found in your camera set up menus, takes only a few seconds and you are good to go.
Switch Lock Diagram
Jan 30, 2011 | Canon Cameras
SIR my sndisk 2GB mamory card is locked .i forgot the password .how can i unlock my mamory card ?
Hi!
SD cards (or MicroSD, using ad adapter) are locked using a mechanical switch on their left side, and not using password! Simply, take the SD card (or the SD adapter) and change the switch position.
Usually the UP position is the Unlocked position...
Best regards,
Pelu.
Sep 18, 2010 | SanDisk 2GB microSD Memory Card
Downloaded ds games onto sd card. did work on ds then added a few more games and now won't play on ds, says loading. i tried to delete games from sd card and it won't let me.
First have you determined if you exceeded the Memory Capacity for the SD card? If so load SD into your computer Memory card Reader slot, It should pop up on the Screen. Look for Options to View, or Edit the SD card, you should be able to open the Memory stuff and delete some of the games. It sounds like you overloaded the Memory Card.
Mar 09, 2009 | Nintendogs: Dalmatian & Friends for DS
WHAT IS SD CARD FOR??
Hello TRICOUNTY,
Your Garmin GPS has an SD card slot. You can use this slot to insert a removeable SD memory card into the unit SD memory cards for used for storage by many portable devices. The most common useage for the GPS is to view pictures taken by a digital camera (which also uses an SD card) with the GPS's picture viewer function.
I am not sure what the ads you are referring to are. Where are you seeing the ads? On the GPS screen? After inserting a SD card into the GPS?
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 22, 2008 | Garmin nuvi 200W GPS Receiver
Electronics - Others Logo
235 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
