Question about LG Washing Machines
I've tried all suggestions from other posts but still can't get Tub Clean Function to work.
I've tried all the suggestions from other LG WM posts on tub clean function not working and I still can't get it to work. It had worked for a couple years and now I can not get either SPIN Sense or Tub Clean Function to activate. LG Customer service was useless and frustrated that nothing seems to get it functional again. All other features work correctly. Ugggh!!Trying to turn on or OFF Spinsense does not work. Trying to do a Spin Rinse then wait the 5 secs after start and hold Tube Clean does not work. Ugghhhh!
  • LG Master
  • 2,342 Answers
Only suggestion I have is to try these old reset solution that work on some older lg washers: unplugg and wait 5 minutes or so, or unplug an d hold power button for 15 seconds, or unplug and the plug back in holding power button down for about 15 seconds then release. Good luck. (LG makes great products but their customer service and repair are horrible).
Posted on Mar 31, 2015
Tub clean cycle
this is not tub clean..its child lock..kindly remove child lock frist,,,
Feb 16, 2014 | LG WM-2277HW Front Load Washer
I have an LG WM-0532HW Front Load Washer. upon trying to fix a diffierent problem, something popped. I couldn't find anything broken. However, the inside metallic tub is not longer stable. During the...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Jun 26, 2011 | LG WM-0532HW Front Load Washer
LG Washer WM2455H Tub Clean Problem
Yes, it's normal. It is a safety feature because of the hot water used during the tub clean cycle. It prevents the machine from opening while the tub clean cycle is in process.
Jan 02, 2010 | LG WM2455 Front Load Washer
Clothes stink after washed in lg front loading machine
You may have already found a solution, but I had this exact same problem. I ran the tub clean cycle with bleach and then switched to a powder HE detergent. I found some other posts that said that liquid HE detergent has some thing in it that causes that smell and the tub build up (not sure what?). I was hesitant that that could really make a difference but it has. It has only been a week, but so far everything smells great. Definitely worth a try.
Jul 20, 2009 | LG WM-2277HW Front Load Washer
LG WM-1832 C
the spin tub
or the entire tub itself?
if its the spin tub inside, it would be caused by serious issues
the whole tub is just a replacement of the suspention. access is through the rear.
May 28, 2009 | LG WM-1832C Front Load Washer
Lg wm2277hw. Shortly after wash cycle begins a loud brrrring noise starts from the front of the machine. It seems to be coming from just above the clean out on the lower left front of the machine. I have...
Try just manually turning the wash tub to see if you have the noise at that time. There may to an object rubbing on the tub. Look around the very front edge of the tub, right near the rubber door gasket. (note: if you spin the drum quickly, the control will light for a few seconds, due to the fact that you are actually using the motor to generate a little electrical current. This is not harmful to the machine.) Let me know what your results are, and if we will have to look further / elsewhere.
May 17, 2009 | LG WM-2277HW Front Load Washer
When I try to run the TUB CLEAN feature on my LG WM2455HG, it err
Actually, that is not an error code. It is telling you to add bleach to the dispenser for the tub clean feature.
All you need to do is add bleach at this point (or Whirlout which works even better). Make sure you do not have any clothes in the machine when doing the tub clean cycle.
Hope this helps, please rate my answer.
Jan 05, 2009 | LG WM-2277HW Front Load Washer
Tub clean function
Found this answer in Fixya.com and it worked for me.
The Spinsense option has to be turned off in order for the Tub Clean option to work!
Aug 10, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
103 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
