Question about Singer Sewing Machines
My singer machine 2009 Athena's light turns on but the machine isn't pedaling to make the actions
Light turns on but it isn't pedaling to do the action
    New Friend:
  • 20 Answers
Is the motor working? If it is working than you have to check the belting. Also check to make sure the wheel is locked.
Posted on May 27, 2015
SOURCE: singer 1060
slide open metal plate, there is a little white finger button with a target symbol on it just to the left. Slide this all the way left, leaving plate OPEN. If your top needle is threaded correctly, you should now be able to push the foot pedal to sew adn the bobbin will refill. make sure not to go past the outer white line on the bobbin case. good luck. the target button will go back to the original position when you slide the plate closed.
Posted on Jan 05, 2009
  • 27 Answers
SOURCE: Singer Athena 2000 Sewing Machine
Most often this is caused by a faulty reverse button ,assuming everything else works well
Posted on Jan 10, 2009
  • 10865 Answers
SOURCE: How do I fill a bobbin on a Singer 2000 Athena
http://www.singerco.com/accessories/manuals.html
go to this site to obtain the manual.
please mark this answer as a fixya!
Posted on Feb 27, 2009
  • 5603 Answers
SOURCE: No number found on Singer Athena 2000
Free download here:
Posted on Nov 20, 2009
SOURCE: my singer athena 2000 won't
Yes, the hook timing is off. You need to either take it to a service repair center, or do the timing yourself. If you're mechanically inclined, go to youtube and look for a video by Nilsandkatrina about how to repair your sewing machine. He gives a very good example.
Posted on Nov 29, 2011
Where is the feed dog switch on the singer athena 2009 sewing machine
I'm not able to find a reference to a feed dog switch for your machine.
Singer Athena 2000 Instructions Manual Page 9
Could possibly be accomplished using a special plate? The instructions do refer to a darning foot, so the machine should be able to deactivate the feed dogs.
Nov 30, 2017 | Singer Sewing Machines
Singer 2009 Athena was fine until I pushed some of the buttons to see different stitches. Now there is a red light on instead of amber and it beeps and stops after a few stitches.
look in your manual for a factory reset button or menu, that should take it back to the condition it was bought in an then it should work for you
Oct 02, 2017 | Singer Sewing Machines
I have a Singer Athena 2000 that stops working randomly. I was able to start it again by turning the switch off and back on, but now it won't start.
Are you still having problems? If so try a different foot pedal. Make sure you use an original foot pedal for your singer. Just an idea.
Oct 28, 2016 | Singer Sewing Machines
How do I replace the light bulb on a Singer sewing machine Athena model 2009 ?
I'm not familiar with this model, but in some machines, the bulb is in a socket underneath the arch. On some machines, you open the side door above the needle mechanism and the bulb is in there.
If you can reach the bulb, depending on the machine, some have a small screw in lamp, just like a regular light bulb, But others use push in bulbs. Typically you remove it by pushing in gently, and turning it as you do so, so it pops out. If one way isn't working, turn the other way. Replace the same way, turning in the other direction.
Nov 19, 2014 | Singer Sewing Machines
How do I thread a Singer Athena 2000?
The user's manual for the Singer Athena 2000 is a free download from the Singer Sewing Machine site. It will show you how to thread your machine properly. A heads-up, though--the presser foot MUST be UP when you thread ANY machine from ANY manufacturer, going back at least a century!
Jun 21, 2014 | Singer Sewing Machines
Singer 2009 Athena ( came with singer Curvy instructions as the machines look Alike). The machine sews a few stitches and then beeps and stops. I have ruled out the auto buttonhole pulldown lever, and the...
sounds like the new top tension dial is not working either
there could be something wrong with the computer part of the machine
is the power cord plugged in correctly?
also is the foot pedal plugged in correctly?
have you had the foot pedal check to see if there is something wrong with it?
I would suggest having the machine check, there are lemons even in sewing
machines
May 31, 2012 | Singer Sewing Machines
Free athena 2000 Manual singer sewing machine
Singer Athena 2000 won't feed properly, feed dog ok, circuit board.
When top is removed there are four adjustments that have red dots, I think I need to adjust one of them. Can you give me advice.
Oct 07, 2011 | Singer 3343 Mechanical Sewing Machine
Trouble shooting a Singer Athena touchtronic 2000 Sewing machine I have a Singer Athena touchtronic 2000 Sewing machine. The light comes on but the needle will not move when you step on the foot pedal. ...
Yes it's true, most parts are not available for this machine anymore. You might try to push the red reset button on the bottom of the machine. Also make sure that the reset button is not being depressed by anything that the machine is sitting on, and that the reset button pushes in and out freelyl.
Apr 27, 2011 | Singer 3116 Simple
Sewing Machines Logo
41 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
