Question about Danby DWM17WDB 22" Portable Top Load Washer with 11 lbs. Capacity, 4 Water Level Settings, 8 Wash
My washer would not dry the cloths after it washes them. is there something to be done, it just makes a noise but its not turning inside
  • Danby Master
  • 5,323 Answers
Test the door switch and look for a blown fuse
Posted on Apr 16, 2015
During spin cycle the washer makes a loud thumping noise. Not a clanging/sharp noise. When I manually turn drum it sounds like something is loose inside. Like a ball may sound inside drum as it turns.
Is it a front loader? You may have something stuck between the tubs or it may be a broken "paddle" One of the plastic baffles that move the clothes around in the tub. they should all be tightly against the tub.
May 26, 2015 | Washing Machines
Can you tell me what nf means
No fill error. The washer thinks it's taking too long to fill up with water
Dec 14, 2014 | Kenmore Elite 45986 Front Load Washer
I want to know that on my washing machine lg-80BKF21P model the time(min) 10 minutes was remaining and the washing process is done,it ends but after drying all is done but 10 minutes were remaining and...
tumble driers and combination washer driers have a 10 minute safety margin, where the heat fior drying is dispersed, to avoid people grabbing very hot clothing.. especially if it is not quite dry as this would make them, hotter to the touch.
Tumble driers usually continue to tumble, but blow cool air through the clothes to get rid of the heat, before stopping.
Oct 02, 2017 | LG Washing Machines
My Bosch Nexxt 100 washer is making a clanking noise. I checked to see if anything was in the pockets of the clothes I was washing. It sounds like something is loose inside of the washer but not in the...
By your description of the noise<it sounds as if the bearing in the "agitator"is defective or "wornout". Or at times anymetal object could some out of pockets and get lodged under the drum of the agitator.you can check this by taking a long flat object,such as a rule,and slide it around the inside of the the machine.
Feb 12, 2011 | Bosch Washing Machines
My beko condenser tumble dryer is drying fine but is making a loud scraping noise. When I took out the clothes there was a strip of white felt in the washing
Looks daunting to start with but just done mine,
remove top and all rear covers and rear panel after removing drum split washer, pump hoses, belt and elec connection, remove the drum and you will see where the felt seal goes. i had some felt i cut to 12mm wide and siliconed it in place, left to dry for 6 hrs, now runs fine.
Feb 07, 2011 | Dryers
Makes scratching noise
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth  is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth
Nov 19, 2008 | Maytag PAV2300 Top Load Washer
Washer making buzzing sound during spin cycle,then stopped during wash still has water in tge clothes,buttons light up as if going to work but nothing happens jusy buzzing noise
If I understand correctly, the washer made a sound in the spin cycle but didn't actually spin the clothes dry?
If so you may have something in the pump that is not allowing it to pump out. Disassemble the pump and make sure it is clear of any debris.
Jul 21, 2008 | Frigidaire Washing Machines
In the rinse cycle the washer is making a squeeking noise
check whether there is something inside the washing drum ..
by mistake some thing might have fallen inside..
else the bearings would have worn out making the squeeking noise..
thankyou..
Mar 13, 2008 | Frigidaire GLWS1233A Top Load Washer
F-H Error
We just had the same problem. We disconnected the water hoses in the back (after turning the water off) and cleaned the sieve. Usually it works again after that. Unfortunately after a couple of washes the problem reoccurs...
Sep 04, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Danby DWM17WDB 22" Portable Top Load Washer with 11 lbs. Capacity, 4 Water Level Settings, 8 Wash Logo
102 people viewed this question
Top Danby Washing Machines Experts
shaun taylor
Jim Y
Jim Y
Samyfam
Samyfam
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
