Question about Garden
Leaks water from trigger unit , even when trigger not depressed.
  • 5 Answers
SOURCE: Water & soap spray constantly even when trigger is not depressed.
The connection for the hose to the cleaner is also a valve assembly. There is a white plastic spring- loaded sleeve that the hose must push in for water to flow into the hose. Part # is 43523004. This is a rather flimsy part, mine cracked and cleaner continously leaks out the backside of the valve housing until the tank is empty GRRRRRRR!
www3.sears.com there are diagrams and parts lists for similar model F7452-900.
Posted on Jan 14, 2008
rowdy45176
  • 2176 Answers
SOURCE: Air leaks arond trigger when depressed, but no nail fires.
Where does the air leak out from? If it leaks from the trigger DeWalt makes a trigger valve assembly part # 641006-00 list 8.89 BUT if it leaks from other areas we have to look into it deeper. If it is just the trigger valve let me know and I will give you instructions how to remove and install the new one.
Posted on Feb 06, 2009
rowdy45176
  • 2176 Answers
SOURCE: Dewalt 51488. Air leaks around trigger and won't fire nail.
Go to Dewaltservicenet.com and download a breakdown of the tool before starting. I would recoment changing all the O rings and make sure that you get a good grease to lube them first. Its not that hard.
Posted on Jul 17, 2009
  • 48 Answers
SOURCE: The unit will not release water.
you do not state wich model it is , check to see if water comes out of the hose ,If water comes out of the hose the pump is working ,either the heater is clogged or the spray tips
Posted on Jul 19, 2009
  • 78 Answers
SOURCE: The unit isn't pumping water or solution when the
you might have a blockage in the heater its very common
Posted on Nov 03, 2009
I have a Bostich coil roofing nailer #RN46-1 leaking air at trigger area when depressed. Replaced trigger assy but same results. Anything else it could be?
Sounds like your gun needs servicing. normally strip, clean and usually fit new O rings to head valve assy, piston & usually sleeve.
Mar 29, 2014 | Stanley Bostitch Rn461 Gun Coil Roofing...
Hitachi 45ab blowing air out of trigger
If air leaks thru trigger as soon as you connect airline, replace the vinyl ball under the trigger stem. If air leaks when you depress the trigger, replace the small oring on the trigger stem. If air leaks slightly from plunger in front of the trigger valve, problem is inside of the gun. Remove the head and pull the large circular plate. Replace the large outer oring. Good luck
Feb 10, 2014 | Hitachi NV45AB2 Roofing Coil Nailer
Blowing air out of trigger
Leaking under trigger could be the ball seal part # 875645 if leak starts as soon as you connect the air hose. If no air leaks when you connect hose but begins to leak when you depress the trigger then replace the oring on the plunger which is part # 874820. If air leaks when you connect the hose and the ball mentioned above is good then most likely is leaking from oring # 876161 installed on cylinder plate (remove head and pull out the plate). Good luck.
I have the 2 1/2 Hitachi for nailing siding. The nail gun had not been used for a couple of years, but now will only drive the nail half way in. Sounds like an air leak when driving the nail. I have...
Remove the nails and air supply. With side door open notice position of driver. Driver should be at top position with tip not visible. If driver is down and it moves within cylinder when you tilt nose up then down again, time to replace orings. If driver is down, it should extend past the nose about 1/4 inch (if driver is broken at the tip the end will look rough and nail will not drive in all the way). If driver extends past the nose more than 1/4 inch then lower bumper may be breaking up /cracked. Easy test for proper function. With nails removed and side door open, connect air to gun and dry fire gun against hard rubber or old coiled air-hose (with air connected and trigger depressed, no air should leak from trigger area, if air leaks when trigger is depressed, look for fault at trigger pin). Feeder should move back then forward in quick motion almost matching speed of driver and driver should not creep down between shots. No air should leak from nose of the gun (push nose against hard rubber and depress trigger and hold in this position, driver should stay down with very little or no air leaking out of nose, when you release trigger, driver will return). If air leaks out of nose while holding in this position, replace lower bumper. If a quantity of air leaks from valve in front of trigger, cylinder orings may need replacing or outer part of cylinder has fine scratches (remove scratches with 400 grit paper). Parts are available at www.toolpartsdirect.com. Good lucki
Apr 16, 2011 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
The water release probably has the hose pinched shut. Storing it with the trigger depressed will eliminate this. You'll have to find the spot, where the hose gets pinched, to shut off the flow and turn it 90°.
Jul 03, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Mi TM 2700 pressure washer has no pressure.
With the water on, to the washer and the unit running. Does the water come out at the same rate before the trigger as at does after the trigger (run test with spray nozzle removed). Its not impossible for unloader valve to be bad but it usually is a dependable component. Make sure the unit has the air purged from it properly before start-up, make sure there are no obstructions before the trigger, then the nozzle. The unloader valve just puts the pump into by-pass until the trigger is depressed.
Apr 10, 2009 | Mi T M WP-2700-4MHB Pressure Washer
Feb 05, 2009 | Dewalt Round Head Framing Nailer D51845
D51844 Framing Nailer won't fire
Adjusting the depth of the nail also changes the amount of pressure that is applied to the trigger pin. This is not actually a problem with the adjustment, however indicates that the orings in the gun are not completely sealing or is lacking lubricant. Adjust depth so that maximum pressure is asserted against the trigger pin. The trigger pin must be pushed all the way in very quickly to fire the gun. Test by removing the trigger and depressing the trigger pin by hand all the way in quickly. Enjoy
Dec 05, 2008 | Dewalt D51844 Framing Nailer
Nov 15, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
