Question about Garden
What kind of blade do I need for a 22 murray hp quantum 6.5 push mower?
  • Eugene Rounds May 03, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What the model number on the serial number decal in the your picture?
  • Garden Master
  • 2,540 Answers
Take the old blade with you when purchasing a new one and compare them. That's what I do if I don't know.
Posted on May 03, 2015
  • 57 Answers
SOURCE: Changing blades on riding mower
Must be able to get to underneath side of deck obviously. If you do not have access to impact tools, it is usually easiest to remove the deck as you must keep the blades from turning. Place a block of wood to where it will jam the blade while attempting to turn the nut. (7/8" socket or wrench). Usually very tight, try some penetrating oil to help.
Posted on May 18, 2009
tmandink
  • 30 Answers
SOURCE: What spark plug should be used for a Murray Quantum XNP 6.5hp mow
Home Depot has the plug you need for briggs 6.5hp engines. Don't worry about it being a Murray. Buy a Briggs 6.5hp plug.
Posted on Jun 26, 2009
  • 93 Answers
SOURCE: murray quattro ultra mower
Murray for the Mower and I imagine its a Briggs engine, go to Briggs.....If any other engine go to the maker of that engine.
Posted on Sep 15, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I can crank my murray gas lawn mower 6.5 quantum
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
  • 29 Answers
SOURCE: I have a Murray 6.0 hp 20 inch push lawn mower. Ho...
If there is a dip stick add some oil check the level till you get to the full mark. It should take a little more than a quart. If there is no dip stick then there is an oil fill plug down low on the engine. Fill slowly until the oil reaches the threads in the engine housing (almost overflowing). Be sure to replace the plug or you will have oil everywhere when you start it.
Don't just dump the oil in, check the level as you go!
Posted on Jun 04, 2010
Murray select 22" mulching deck part
from the sounds of what you talking about that part is part of the deck and not servicable
Jun 25, 2012 | Mtd Garden
Need owners manual for murray 22 inch push mower model #22526X92A
There is no corresponding manual for model no. But here is the manufacturers site, you may be able to use a different manual.
http://www.murray.com/la/en/support/manuals/
May 19, 2012 | Oregon Scientific Gator Mulcher 3-N-1...
WHAT KIND OF OIL DOES THE MACHINE TAKE? I HAVE A MURRAY 22" POWERED BY 5.0 HP QUANTUM
SAE 30 W motor oil is what is called for in the instruction manual for the engine. For your engine size it will be about 20 oz. of oil.
Aug 25, 2011 | Garden
I RECENTLY BOUGHT A PUSH MOWER AT A FLEE MKT..NEVERNHEARD OF A QUATTRO MOWER...IT HAS A 22 IN BLADE..I HAVE AN OLD 21 IN BLADE FROM A L-BOY..CAN I USE THAT ON THIS MOWER OR MUST I BUY NEW 22 IN BLADE ???...
i just looked up Quattro mower they are a 4 stroke engine and yes i would buy a 22 inch blade but be sure it fits this mower PS go to wall mart and check out their blades they are reduced now.
Sep 09, 2017 | Yard Machines 158cc Push Lawn Mower #11a...
Where is oil plug to change oil, how much and what kind. It is a 6.25 hp 22 inch self propelled Murray Select Quantum.
They do not have a drain plug. You need to remove the dipstick and tip the mower dipstick side down while putting a container under it. After it has drained right mower and refill to full mark on dipstick with sae 30 engine oil. It will take approximately 600 mls. Regards Phil
Apr 17, 2011 | Garden
Murray ridinglawn mower will not start..everything is new
sounds like you have a safety switch issue, i am the proud owner of 3 different Murray mowers, you have a seat switch, a blade disengage switch, and a clutch pedal switch, depending on model and year, unplug one at a time and re try, need anymore info, email me, niteman87@aol.com :) hope that helps,
May 23, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Have a murray model 226111X92B 22
go to this website http://www.ereplacementparts.com/murray-226111x92b-2234-lawn-mower-parts-c-17887_17944_19048.html and find the part your looking for. i went to the site and found what you are looking for..good luck
Apr 05, 2010 | Mtd 22" Yard Machine Push Mower
Looking for a parts supplier to source Murray push mower 22'' deck
Well I have looked at my suppliers and they are showing it no longer available. So you may have to search around and find an old murray mower that no one is going to fix but has a good deck. good luck.
Sep 29, 2009 | Garden
Jun 26, 2009 | Garden
Garden Logo
122 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
