Question about Frigidaire Dishwashers
How to fix a squeaky dishwasher door
Door makes loud squeaky noise when opening and closing
  • Frigidaire Master
  • 473 Answers
You may need to slide the dishwasher out slightly. On both sides at the floor level are the door springs, pulley, and cables. The cable is usually attached to the door hinge--then goes around the pulley wheel and goes back to the spring system. Most noise comes from the hinge pivot point or the pulley axle. You can spray all those parts with something like WD40 or if you don't like that smell try a silicone spray. Do both sides and work the door up and down.
Posted on Mar 31, 2015
GE pdw9980lss dishwasher makes a horrible squealing noise when not in use.
The dishwasher control panel must be defective, nothing else would cause this.
Apr 04, 2017 | GE 24 in. PDW9980LSS Stainless Steel...
When dishwasher is draining it makes a very loud noise but it does drain
May be solenoid valve makes a thud noise. It is normal.
But if it was silent during earlier days usage and the noise is notice now, then check it's mounting. For this you have to open the back door of your machine.
May 17, 2010 | Dishwashers
Makes a loud squeaky noise
hi do one thing that at the right side do you have any thing stuck whih is causeing this problem..open the rear door of the printer and try to clean the rollers..close every thing if its working then grt! else its causing this problem because the encrouder srtip is gone bad...so you need to replace that ..in order to resolve this issue..
Jan 25, 2010 | Brother MultiFunction Center MFC-440CN...
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
Kitchenaid DW Door is very squeaky and loud
most likely the hinges are partially rusted through. resulting in all of those sounds. i doubt that you could get anyone to replace the hinges for less money that the cost of a new dishwasher so I recommend replacement.
Aug 16, 2009 | Dishwashers
Squeaky door
wd will not work order and replace the door link assembly installe all parts in the bag, youll be fine easy repair part number 8194001
Nov 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Squeaky noise when open door
petroleum jelly rubbed on the nylon cord and all parts that it touches...it does the trick
Jul 13, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Squeaky door
On our KitchenAid dishwasher we had the same problem--a REALLY loud squeak as it opened. The sound comes from the nylon rope slipping along the plastic pulleys. We've had the DW for about 3 years and the noise has gotten worse over time. I was determined to win the war against the noise and am happy to say I fixed it today.
The trick is to use a dry lubricant on the cord and on the pulleys. I used Dry Graphite by Gunk. It comes in an aerosol spray can and once the stuff dried the squeak was gone. I'll let you know if it comes back...
May 16, 2007 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwashers Logo
194 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
