Question about Water Heaters
Boiler is about 25 years old no problems since we have had it however when we switch it on and it gets to temperature it starts to make loud whistling noises
    New Friend:
  • 24 Answers
Check that no wire makes a contact with the cover. check the water pump. does it vibrate when on. it not could be internal corrosion. close ioslator valves and remove to examine
Posted on Apr 13, 2015
How do I fix a problem with my boiler not coming on?
Ive just resolved this issue on my own boiler...... Its the programmer ,replace it as the micro switch has gone , when it comes on the lights only come on the internal switch does not ,so no sognal to boiler , replace programmer
Aug 01, 2016 | Water Heaters
Boiler not coming on, programmer constantly flickers on/off
if voltage from transformer ok check to pressure switch bad or loose wire
Aug 01, 2016 | Honeywell Water Heaters
Greenstar 24i junior
Replace the thermosts,signal not getting thro to boiler.
Jul 15, 2017 | Water Heaters
Vaillant boiler clock not working
your timer clock may need to be replaced.
Aug 12, 2017 | Water Heaters
Water to hot for gas boiler boiler gos off
It could be dyslexia, but I think you want to know what may be wrong with your boiler in this case!
This is a VERY old design. The diaphragm is on the water section, this operates a switch to turn ON the pump, and a further device causes the diverter valve to divert boiler water from CH duty to HW duty.
From your description it appears that the boiler is shutting down on internal boiler water temperature (too high), your 'briefly too hot' HW symptom may be caused either by the boiler side of the secondary heat exchanger being blocked/caked in sludge, OR the DHW side of it being scaled. Either way a new or replacement (descaled) secondary heat exchanger MAY inprove things. It's not easy on these old clunk-pots, and EVERY disturbed seal will subsequently leak, so get a good supply of o-rings and fibre seals before you start ("you" being the competant fitter you employ)
Dec 20, 2012 | Water Heaters
New Vaillant 360 eco plus boiler, takes almost 3/4s an hour for rads to come up to a decent temp. Hot water is fine. Called out install Engineer who is an excellent tradesman but he says everything
We have just had our old system boiler replaced with a vaillant ecotec plus 837 and sounds like a similar working operation to ours. At first I was a little concerned,but I was told by our installer that he was told by vaillant that these very latest boilers size the system on start up for about 10 mins, then take temperature to target flow which you set boiler at. So even by setting target flow temperature very high you still get the initial sizing cycle, which ours was about 30-35c temp. These boilers seem to run biased for efficiency as after a while they modulate the boiler burner down and the radiators run more on the side of warm than really hot like the old type boilers. You also get better efficiency as at lower temperature the boiler condenses better. You will also find you get a more constant temperature in your home rather than over shoots. I was concerned at first, shame there was no info/explanation in user manual as people do need to know that this is normal operation. We are used to ours now, took a month and by the way these boilers can make a creaking noise but was told this normal expansion/ contraction but annoying when sited in bedroom cupboard. Best of luck!
Oct 27, 2012 | Water Heaters
Vaillant ecoMAX 828/2boiler goes on & off when running hot water!
water must be set at 3lts a min ,check diaphragm valve move when hot tap is on, check microswitch ,best of luck
Aug 09, 2009 | Water Heaters
Water Heaters Logo
121 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
