Question about Pioneer PDP-6020FD 60" 1080p KURO Flat Panel HDTV
Hi, I have a Pioneer Kuro Flat panel, PDP-6020FD TV that was working before I moved. It wont turn on.
I have tried several times to plug it in and same result. No power.
  • 93 Answers
SOURCE: Pioneer PDP-503PU
Very possible,but yet,this might be the manufacturer defect power supply which they will fix it for you free;but before we jump to this conclusion,you need to test it first:
-Unplug the power cords.
-Unplug the media video cable from the box to the tv.
-Check all the pins on the video cable are in place as well as the connectors both behind the TV and the media box.
-Reconnect the media box and TV with the video cable(DVI+VGA in one) and have at least a video component hook up to it(ex. dvd player/VCR or comcast box) be sure this video player is turn on and running,at the same time,be sure it is under the right video input.
If you have tried the above steps but still doesn't work,call 1-800-pioneer Tuesday-Thursday at7amPST and address your issue to them.
Let me know if you have any additional questions!
solutiondoct
Posted on Nov 05, 2008
SOURCE: my brandnew Pioneer PDP-5020FD won't turn on.
Check page 9 of this document:
http://www.pioneerelectronics.com/StaticFiles/Manuals/Home/PDP-5020FD_OperatingInstructions0610.pdf
You will see that there is a power button on the bottom right corner of the back of the unit (item 25). Turn the unit on using that first.
Posted on Aug 10, 2009
SOURCE: Pioneer Plasma TV-PDP-4270HD won't turn on. TV
Try this! There should be a power button on the bottom of the panel that has to be depressed for the television to power on. It is the main power supply button and without it there is no power going into the TV.
Posted on May 11, 2010
toolkits
  • 1099 Answers
SOURCE: my pioneer pdp-4270hd television wont turn on. i u...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Posted on May 23, 2010
info33
  • 72 Answers
SOURCE: Pioneer PDP-42A3HD - TV turns itself off...is
Here is the link for the manual - c ould be a remote set up issue or this could be puffed caps in the power supply - have a qualified tech check that out
http://tv.manualsonline.com/search.html?q=PDP-42A3HD&submit.x=49&submit.y=15
Posted on Jul 03, 2010
Find activation code for pioneer
My pioneer 5020FD Kuro tv. when I plug power to the unit, a blue light blinks 8 times pause 2 sec. and blink 8 times repeating this and if i press power button it clicks red light and makes a clicking sound and goes back to the blue light blinking again, it did this once before and the picture came on fine until i turned it off and now it just blink the blue code.
Dec 10, 2014 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Internal circuits
Maybe the TV speaker "cable" is shorted.
May 19, 2017 | Pioneer PDP-5020FD 50" 1080p KURO Flat...
Panasonic Kuro pdp-5020 8 blinks of red led
Is power voltage going to the Panel screen?Can you measure that?
Check power supply voltage distrbuition line.
Nov 04, 2012 | Pioneer PDP-5020FD 50" 1080p KURO Flat...
Want come on
is the tv still under warranty? make sure that where ever the tv is plugged in that that outlet is working. if your tv is under warranty they should fix it for free. if not you will either have to open it up and figure it out or get a repairman to fix it. From a guess I'm going to say that the fuse could have blown on the tv which can be replaced if you know what your doing. Def. make sure your tv is under warranty first.
Mar 11, 2011 | Pioneer PDP-6020FD 60 in. Plasma TV
When should the cooling fans come on on my pdp 6020fd
There is an internal temp sensor within the set itself. If the tv is warming up and you hear no fans then the sensor will need replacing before you run the tv long-term. If you fail to replace the sensor your tv IS overheating and can lead to a dead tv very quickly!
Please rate if this has helped you :)
Mar 08, 2011 | Pioneer 60" Plasma Tv Kuro Krp600m...
Mar 16, 2010 | Pioneer PDP-4270HD 42 in. Plasma...
Black bars on top and bottom when watching movies on plasma will it hurt tv
Your refering to the widescreen cinema mode.This will not affect plasma.Only still pictures with colour retention will do it but even then it would take many hours to take effect if at all.
Jan 01, 2010 | Pioneer PDP-6020FD 60 in. Plasma TV
My brandnew Pioneer PDP-5020FD won't turn on.
Mar 17, 2009 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Broken plasma
The screen will cost more than a brand new set.. Scrap the boards and sell them on ebay to recover some funds. A new panal is just way too much money.
Sep 06, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Pioneer PDP-6020FD 60" 1080p KURO Flat Panel HDTV Logo
54 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
