Is there a fix when all the functions of the remote control do not work?
    New Friend:
Sounds like the batteries could be dead or not properly installed in the remote control make sure positive and negative ends of batteries are lined up in correct position in the remote.
Posted on Mar 31, 2015
  • 696 Answers
Hi Roberto.
This is usually caused by batteries that have gone bad OR a poor connection. Test or replace the batteries as necessary and clean the battery connections with a Q-tip and rubbing alcohol.
Good luck
-Steve
How to get this remote control to turn the 2004 Sylvania TV on/off
There is a fault with the remote control and it is not worth trying to fix it and not worth replacing the stock remote control unit even if the manufacturer could still supply one for that TV.
The best option is to just buy a very basic generic remote control (quite inexpensive) from an electronics store which will work with many TVs and use that remote to turn the TV on and off. Use your stock remote for all other functions if it is still working well on those functions.
I had a friend with the exact same problem with her stock remote a while back. I purchased a simple generic remote control on special for around $20 which she now uses to turn the TV on and off. .
Nov 21, 2015 | Sylvania Televison & Video
Volume stuck on 0
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
If all other functions, except the Volume + / - button on your remote control works properly, the fault is with the remote controls' keypad. If no buttons on the remote control works, it might be due to a non functional remote control, or with a faulty infrared sensor inside your TV.
Aug 14, 2014 | LG 32LG30 32 in. LCD HDTV
N3235w remote control not working
EXACT remotes are often VERY expensive... I would recommend a NEWER "Universal Remote" that will not only empower your TV, but enable you to use FEWER remotes!
Here is a EIGHT FUNCTION REMOTE Starting at $7 from Target!
GE Universal Remote Control 8 Device Fully Backlit DVR Functions Black
Anthony
Dec 29, 2017 | ViewSonic Televison & Video
Apex k12b c2
If only one button do not work, it might be set right by cleaning it. But to clean it, you must open the remote control If you check the link given below, you can get the procedure about how to clean , repair and check a remote control http://electronicshelponline.blogspot.com/ Pull up older posts there.
May 25, 2013 | Apex Digital APEX K12B-C2 Remote Control
Volume control on reciver isn't working. Only using remote control for volume works. So I must need a volume control for the receiver. Is this an easy fix or not worth the time to fix
Hello
You haven't specified if all the other functions are working with the remote control or not. If no functions are working with remote control, either there is no infrared emission from your remote control handset. Check it with the help of a cellphone with camera option. Cellphone digital camera can detect the infrared rays comes out of the remote control. Just put the cellphone to camera mode, and place the remote control just about 1 feet away from its camera lens and push each button on the remote control and see whether there is any image of infrared rays indicates at your cellphone camera screen. If not, be sure that the remote control is not working, and should be replaced or repaired. Replace the cells first, and check. If this does not helps you and still the remote control is not working, replace it.
If the remote control works, and the all the other functions of your device can be set with it, the motor of the volume control or it control circuitary has damaged. To check this, you must have through knoledge in electronics and is a time taking service work. OK.
Apr 24, 2011 | Sherwood RD-6500 Receiver
VOLUME WON'T WORK USING REMOTE, BUT CHANNELS ARE TURNING. HOW CAN THIS BE FIXED?
First hit the TV button again and try and change volume, if that doesnt work try a different code as many codes can do some functions and not otheres.
Apr 16, 2010 | Universal Remote Control Remote Control
Remote control stopped working. no signal
I apologize if I am stating the obvious. Replace the batteries with NEW ones and be sure they are installed with the correct polarity. Also, assuming this is a multi function remote, press the TV function button on the remote. Often a remote gets inadvertently set for dvd, or tuner control and then will not control the TV. My Samsung remote for example can control a stereo, vcr, cable box, and dvd plater in addition to the TV. If none of these simple fixes solve the problem you will most likely need to replace the remote. Try partstore.com
Nov 16, 2009 | Vivitek V37835 46 in. LCD Television
Sanyo tv
037,082,083,124,268,274, Some functions (depending on your tv model) may not work. For an original remote 1-800-877-5032 Sanyo. Give them the model # and they can fix you up with a remote that will preform all functions Hope I have helped.
Aug 28, 2009 | Televison & Video
DirectTV HD-DVR & Yamaha RX-v1500
The types of remotes are as follows
- Single item, or fixed. This unit will only operate the unit it came with
- Multi function, this type can operate the unit it came with and a fixed set of other types. Normally the remote comes with a list of supported device it could work with.
- Learning, the combine both a predefined list with the ability to learn functions by sensing input from the original remote.
- Programable. These are the newest remotes that work like multifunction but the list is maintained by the manufacturer and down loadable from the web.
I would guess that the DVR has a multi function remote.
If you can't find the specific Yamaha in the list, then
try another brand, this could take a while.
Some multi function remotes have an option that allow a semi automatic configuration.
You turn on the item and then using a special key sequence try to turn off the device. once the item turns off you should be able to control it.
If you can't the Yamaha has a learning remote. If you really want an easy solution try looking at a programmable remote. I just got a Logitech, (Harrmony). Life has never been so easy.
Mar 08, 2008 | Yamaha RX-V1500 Receiver
No input channels
Universal remote control are normally programmed for basic functions, ie. chennel up down, volume up down, numbers, etc. This is even written in the manual that they do not guarantee that all functionality can be used. Here are your options: 1. Try all the codes that match your TV, there is a slim chance that the other code have the functionality that you need. 2. Buy the original model remote control. 3. If you know of someone that have the same TV, buy a universal remote control with 'learning' function and copy the signal from the original remote control. I have the same problems before. Now I use my Casio wrist remote control to copy the special functions such as A/V so that even if the original remote control is lost, I can still use these functionality
May 23, 2007 | Symphonic ST419E TV
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
