Question about Plumbing
Manual says 'lower the buttonhole lever all the way down and push it away from you. What exactly is the buttonhole lever!?
I get the stoppers, but nothin seems to describe the lever
3 Suggested Answers
  • 26 Answers
SOURCE: Kohler bathtub drain seems to be disconnected from
Okay, remove 2 phillips head screws at lever handle/overflow.
Pull firmly with much effort and bowing the connecting rod a bit.
Up will come a heavy duty spring on the end of the rod.(prolly a big slimly hair ball too!)
Hope you get the spring, cause that's what works the drain stop.
If spring doesn't come out you'll have to "fish" it out.
Clean everything up real good and flush drain good also now.
The "Secret" now is to put the Lever,rod and spring assembly back in and replace screws and get the lever flipped to the left BEFORE you put the Drain Stop in.
Posted on Jan 01, 2010
Testimonial: "The info was very helpful and thanks for the "secret"!"
SOURCE: Direct push-type Kohler bath drain won't drain.
Spring loaded chrome stopper will not stay down to fill tub with water.
Posted on Jan 16, 2010
How do you use the buttonhole foot on a babylock companion 1550
1.Mark position and length of buttonhole on fabric.
2.Set button on the base and slide base forward to secure button.
* If button does not fit on the base, adjust slide on base to diameter of button plus thickness of button.
a= Length of button + thickness
3.Pass upper thread through the hole of buttonhole foot and attach buttonhole foot to machine.
Bring upper and bobbin threads to the left under foot.
4.Position fabric under presser foot so that the center line mark is in the center of the needle opening in the buttonhole foot. With the main part of the foot pushed to the back, lower the presser foot lever.
5.Lower the buttonhole foot lever so it is positioned behind the raised finger on the foot (see step 5 illustration). a
Note:Machine will not start to sew if buttonhole lever is not lowered properly or buttonhole foot is not positioned correctly.
Note:If machine does not reset for second buttonhole, be sure the presser foot raised finger is pressed against the lever.
6.Hold upper thread lightly and start the machine.
Ref. :babylock.com/downloads/manuals/
Oct 05, 2017 | Sewing Machines
I have a 9960 singer machine and am trying to use the buttonhole presser foot for the first time and I can not get it to sew T
the buttonhole foot snaps on to the presser bar, there's a little lever at the back of the presser bar that releases the foot, then put the buttonhole foot down on the needle plate & use the presser foot lifter (number 11) to lower the presser bar down onto the buttonhole foot & you'll hear a click sound when it snaps on & make sure to use the buttonhole lever(number 31) because the machine won't sew a buttonhole unless that lever is pulled down.
Apr 26, 2012 | Singer Sewing Machines
My machine has a one Step Buttonhole Feature - having problems
Try an Even Feed Walking Foot for more control on thick and quilted type layers
Dec 10, 2011 | Brother CS6000i Computerized Sewing...
My buttonhole is not working I hear a beep when i press down on the foot to go, what am I doing wrong
I get the same beeping when I forget to pull down the buttonhole lever
if you have the automatic buttonhole & the buttonhole foot that you have to put a button in,,check & see if there is a buttonhole lever that has to be pulled down, it will be a lever to the left of the needle bar
Aug 07, 2011 | Singer 7436 - INGENUITY
I have temporarily misplaced the instruction manual to my White 979 sewing machine. I need to put this shirt in todays mail and I have forgotten the direction to make a buttonhole. I s there a place I...
Automatic BUTTONHOLE making with 979:
  1. Carefully mark the position of buttonhole on your garment.
  2. Slide the button carrier and insert the button.
  3. Attach the buttonhole foot.
  4. Place the garment under the foot so that the needle pierces the fabric at the beginning of buttonhole.
  5. Lower the buttonhole lever and the presser foot lever.
  6. Push the buttonhole lever away from you.
  7. Start machine to complete entire buttonhole.
NOTE:
  • While making buttonholes, maintain an even sewing speed for uniform buttonholes.
  • When buttonholes are completed, be sure to push up the buttonhole lever as gar as it can go.
Feb 11, 2011 | White Sewing 979
I am trying to make a buttonhole using the buttonhole foot and everytime i go to sew the machine beeps and will not let me sew?
if you have a automatic buttonhole , then you should have a buttonhole lever that you have to pull down, before you start to do the buttonhole,, my machine will not let me do a buttonhole unless I pull down the buttonhole lever
Nov 16, 2010 | Singer 7436 - INGENUITY
I have a Singer model 9910 and am not able to make a buttonhole on the setting for #61. The buttonhole seems to be inserted properly and the foot is lowered but the machine just beeps and will not sew.
Re your buttonhole foot - please note the following:
- This foot comes with a metal underplate.
- Place the fabric between the foot and the underplate.
- I am assuming that you have the buttonhole lever pulled down.
-Note: The silver coloured buttonhole lever is directly behind the needle threader. Pull it all the way down.
-When u have all the above in place, start the buttonhole. When it finishes the first side, gently push the foot back, so it reverses. I know this sounds strange, but if you have slightly bent the underplate you will need to do this.
- The directions are in the manual on page 60.
May 15, 2010 | Singer Quantum 9910 Computerized Sewing...
Buttonhole instructions needed for Singer 7422 Advance
These are the exact instructions from the Manual. 1. Select one of buttonhole patterns.
2. Replace the presser foot with the buttonhole foot. (Install presser foot with little red mark towards the front)
3. Insert the button into the buttonhole foot. (the part located in the back crescent shaped)
4. Lower the buttonhole lever (to the left of the needle) so that it drops down vertically between the stoppers A and B.
5. Carefully mark the position of buttonhole on your garment.
6. Place the fabric under the foot. Pull out the bobbin thread underneath the fabric to a length of about 4 inches to the rear.
7. Align the buttonhole mark on the fabric with the mark on the buttonhole foot, and then lower the buttonhole foot.
8. While holding the top thread, start the machine.
*Sewing will be completed automatically.
9. When sewing is finished, use a buttonhole opener to open up the frabric in the center of the buttonhole. Be careful not to cut anyt of the seam thread.
I hope this helps.
Mar 28, 2008 | Singer 7422
Janome JD1818 Automatic Buttonhole Not Working
If everything appears to be working correctly for the first side and stops and bunches up when it should reverse - Make sure you have pulled down the stopper arm (this is not clear in the manual) when the button hole foot contacts the stopper arm gently push the foot against the stopper arm and the direction will reverse and finish the button hole. **Stopper arm pulls down from above - Check the pictures in you manual carefully.**
Mar 16, 2008 | Sewing Machines
One step button Hole V for Singer Sewing Machine
Hi, I had the same problem, but I finally found my manual. The solution is that you have to use the presser foot for buttonholes but the most important part is that you have to lower the buttonholer lever. It is located right next to the needle to the left. It is a metal lever with a little square white plastic end. You need to pull that down in order the the buttonhole feature to work. My button was too big for the buttonhole presser foot, so I had to use the regular presser foot, but hit the buttonhole lever with my had to make it go up or down.
Aug 30, 2007 | Singer 7422
Plumbing Logo
364 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
