Question about Home
The base is cracked and leaks. Can I replace just that part? The tank seems to be fine.
  • 2,160 Answers
Nope. all new much cheaper
Posted on Mar 31, 2015
Gas seems to be coming from the top of plastic gas tank and running down the left side of the tank and dripping on the ground
I know it sounds a bit difficult but fuel leaking is serious danger so with this id siphon tank dry (don't use a drill pump ) and undo fasteners and hoses/wires that hold it too truck , lowering it to ground , a carefull inspection of approx. area of leak will tell the problem , your looking for cracks in plastic or rubber hoses , these might be very small and fine look closely
if cracks are in the tank , unless you know someone with a ultrasonic welder id replace the tank
Oct 30, 2015 | 2003 Ford Explorer Sport Trac
Why water leak between tank and faucet forest river flagstaff classic 625d?
You will not find a plumbing diagram since they are not published. Were you connected to the city water or were you using the fresh water tank? You will basically have to start at the input point and follow the water lines until you locate the leak. Identify what is leaking and replace. It is possible that a water fitting has either popped loose or cracked from freezing.
Jun 08, 2014 | Forest River 2008 Flagstaff Classic 625D
My eljer toilet leaks between base and back. it has a built in overflow. there is no overflow tube. i change gasget but still leaks.
Look for cracked ceramic at gaskit joint might need to replace tank..I did after weeks of trail and error.
Nov 28, 2010 | Eljer & Savoy& Toilet Tank With Lid
My shark steam iron is leaking when ironing
It is quite possible that this is a defect in the shark G1490F... I had the same problem and it was a crack in the water holding tank caused by tightening the two front screws (hidden) that hold the tank to the base... It seemed fine at first but after a full heating it developed a crack where it had been weakened when it was assembled... I suggest returning it or if warranty is up , throw it away and get something else..
May 23, 2010 | Euro-Pro Shark GI490 Iron
Ryobi 700r gas trimmer. Leaking fuel from the fuel return line...what is the best way to fix this?...seems to be leaking where the tube goes up into the fuel tank. thanks.
There is no nipple. The fuel line is just pushed through and holds itself tight against the hole in the tank.
This is the return line from the primer bulb, right?
Just replace the line and you should be fine. I think that some of these Ryobi lines are 3/16 OD and 3/32 ID, but I just picked up a Ryobi fuel line kit at Home Depot today, and the black line seems to fit nicely here. (My trimmer still won't start, but at least it doesn't leak gas any more.) Be careful to note which line comes from where on the orimer bulb.
Steve
May 12, 2010 | Garden
1990 f 350 7.3 liter runs fine until fuel tank
install clear plastin line in the return from the injector pump, any air in the fuel means trouble, somewhere in the fuel system its drawing air , usually neat the tanks, but not leaking enough for fuel to leak
Dec 08, 2009 | 2004 Ford F250
Yr 2000 thundercat, won't idle unless choke fully on
When you cleaned and balanced what did you do and how? Did you clean out tank? Tank filter? Any petcock debree. If this does not work please get back at me for further info.
Jul 07, 2009 | 1999 Yamaha YZF 600 R thunder cat
Remove rad tank on y-reg se s-type
The radiator tanks develope cracks in the base and leak under pressure, to replace remove plastic cover across body under windscreen to get access to tank then removal is easy you might have to remove plastic inside mudguard
Apr 12, 2009 | 2001 Jaguar S-Type
Water Tank leaks all over the floor
This happened to me the second night of use.  Water all over the carpet and a dripping vent. I called customer service and they told me to remove the tank and filter, and run unit dry for an hour or so. Then restart it.  Worked fine after that.  I think we may have bumped it which is said to be the cause of most leaks.  Bummer is that after 5 night of use the grip on water tank slipped and the tank is in pieces.
Nov 12, 2008 | Honeywell HCM-300T Humidifier
LEAKS
Try to just fill the tank with water and set it upright on a table. If it leaks, the tank is cracked and needs to be replaced. Order one at kaz.com (search using model#). I have had this tank leak if the special cap is not sitting properly on the base. Make sure that the steam tower is properly locked in place before you place the water tank in the reservoir. The cap on the tank has a spring release that has to be correctly lined up so it only releases water when the water level in the reservoir drops.
May 08, 2008 | Vicks Warm Mist V745A 1 Gallon Humidifier
Home Logo
66 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
