Question about Sanyo Televison & Video
How to do you fix a sanyo 46 lcd HDTV with a half screen distortion?
The problem is always present.It has a clear picture for hours and then half the screen gets darker. You can still see the picture but not clear as the other side
  • 774 Answers
Shouldn't have bought a Sanyo. It's not the same company it once was. It's toast.
Posted on May 29, 2015
  • 50 Answers
SOURCE: TV Screen Dims during dark Scenes
Most likely you have the opc feture on. go to the menu under picture setting first option should be to turn on or off the opc. turn it of and should solve the problem.
Posted on Mar 18, 2009
  • 8457 Answers
SOURCE: Black shadow boxes on 46 in Samsung 46 in LCD HDTV.
Ur backlight video board is dying,must replaced to solved this problem.Part and labors about $500.
Posted on Dec 15, 2009
  • 68 Answers
SOURCE: I have a 46in lcd Vizio and the picture on it has
replace circuit board that lights up screen....a lot of little tiny transformers on them...u should have two(2) circuit boards that look alike ... 1 of them is bad!! replace ckt board.
Posted on May 19, 2010
  • 131 Answers
SOURCE: Our sanyo lcd tv is a couple of years old and
Hello; I am John at J. D. Electronics, Poland Maine. This problem is caused by a defective LCD panel. This part is very expensive! Aprox $ 1000.00 from Sanyo and less than $400.00 from Encompass Parts Inc.
Posted on Oct 09, 2010
welcomejee
  • 10594 Answers
SOURCE: When I turn on the
Symptom shows problem with lcd panel (screen) however, t-con board that is part of lcd panel could be defective and cause of these symptoms.
T-Con board is located at top center of cld panel at rear and would be covered with metal shield. There are three type of t-con board utilized according to lcd panel and are available in shopjimmy.com
Please check what t- con board is similar with your tv board to order it. If you are not handy with electronics stuff repair then local tv repairman will help you to replace t-con board that might solve your tv picture problem.
Thanks.
Posted on Jan 29, 2011
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
My 46 inch samsung has a picture distortion, it's like it has a mirror image , how can i fix this?
Anthony, you did not list a model #. If you would it makes it eassier to determine what may have happened with your Samsung TV. An LCD would start with LN46----.
I have had screen issues with some samsung product. As well as other makes of televisions that use Samsung 46 inch dislay lcd.
Mar 02, 2013 | Samsung LN-T4661F 46 in. LCD HDTV
DP42647 On half of our 47 inch screen it is black and distorted when we first turn the TV on but after 30 or 40 minutes it finally just lights up and is fine.
Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish board that call the T-CON board for the replacement.This board sit in the middle at the bottom of the LCD screen panel.This T-CON board only job are to decodering picture pixels dots only before it show up to the LCD screen panel.
Jun 10, 2011 | Sanyo DP46849 46 in. HDTV
I have had a dark distortion on half the screen for some time now but it would snap back to a regular picture after half an hour or so . But now the dar and distortion won't go away. Any help out...
Their is most likely a problem with the pixels in your display. the reason why it dose this is that after the television warms up (about half and hour) the pixels adjust and start to work properly the only fix would be to replace the entire screen
Mar 05, 2011 | Sanyo DP46849 46 in. HDTV
I got a new Sanyo Vizion 46" LCD tv as a present about 2 weeks ago. I noticed since the first day when I change channels I can still see some images of the previous channel I was watching. Should I...
Return the tv for another one for the replacement.This tv have a problems,call a delay prograssive scan.That why u see the jet trails of the previous pictures.This problems,will not go away,but will getting worse and even might have a permanent pictures screen burn of the previous pictures in LCD screen panel too.
Nov 29, 2010 | Sanyo DP46849 46 in. HDTV
I have a Sanyo 46 inch flat screen hdtv purchased from walmart aug. 31rst, 2008. Sure enough, 13 months later my tv is having picture problems and getting worse. It started having portions of the screen...
I have the same problem, my television is faded black on the left side with lines on the left top side. I have had the 46 inch unit for 1 year and 7 months. I am planning to write a demand letter to Sanyo and then taking them to small claims court woth evidence that this is a common problem with their units that they know about and is not trying to remedy. Also the Attorney general in Texas should have an interest in them (Walmart and Sanyo) selling these defective proucts in the state.
Nov 01, 2009 | Sanyo DP46848 LCD TV
Televison & Video Logo
91 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
