Windows cannot start DVD drive because its configuration information is incomplete or damaged. (Code 19)
  • 17 Answers
SOURCE: optiarc ad 7530a dvd rw drive
I have seen this problem many times. 99% of the time this will fix it for you. The first part of this fix is to backup the current registry just in case you need to go back.
Try this. I really think it will fix your problem :)
1. Click Start.
2. Click Run.
3. In the "Open" field type REGEDIT.
4. Click OK.
5. Click "File" in the menu bar.
6. Click "Export" from the drop down menu this will open a new box.
7. Click the down arrow beside "Save In" and select "Local Disk (C".
8. In the File Name field type BACKUP.REG.
9. Verify that under the “Export Range”, that the radio button is beside "All".
10. Click Save.
11. Click the plus sign (+) beside HKEY_LOCAL_MACHINE.
12. Click the plus sign (+) beside System.
13. Click the plus sign (+) beside CurrentControlSet.
14. Click the plus sign (+) beside Control.
15. Click the plus sign (+) beside Class.
16. In the left hand window pane click on {4D36E965-E325-11CE-BFC1-08002BE10318} to select that key.
17. In the right hand window pane select the UpperFilters registry key and press the delete key on the keyboard.
18. Confirm with an OK.
19. In the right hand window pane select the LowerFilters registry key and press the delete key on the keyboard.
20. Confirm with an OK.
21. Click the "X" in the upper right hand corner of the Registry Editor window to close it.
Restart your Computer in order for the registry - fix to work.
Posted on Mar 20, 2008
hardkiss69
  • 43 Answers
SOURCE: UNABLE TO DETECT CD/DVD ROM
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Your registry might be corrupted (code 19)."
You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Posted on Sep 28, 2008
  • 192 Answers
SOURCE: dvd rw or cd-r/rw not being reconized by computor
Uninstall the drive via Device Manager, restart your system and let Windows install it.
Update to the latest Windows Service Pack.
Download the most up-to-date Chipset drivers.
If none of these work, clean your registry.
http://onecare.live.com/site/en-us/default.htm
This is free, and will fix. Choose Clean Up if you have XP, or choose Beta version if you have Vista.
Hope these solve your problem
Regards,
Tim
Posted on Dec 10, 2008
  • 13433 Answers
SOURCE: CD Rom and DVD Rom won't work
you need to delete lower and upper filters from registry to fix the problem instructions CLICK HERE
Posted on Dec 28, 2008
tbirdfan1
  • 3051 Answers
SOURCE: Windows cannot start this hardware device because
Hello there:
First i would double check to make sure that the device is windows vista compatable and is compatable for your system next i would uninstall the device using device manager and than select view and select scan for hardware changes and let the computer reinstall the device and it will let you know that your device has been found and is installing than it will let you know that your device is installed and is ready to be used or it wil give you a error message if so than i would contact the manufacturer of the device and see what they say about the message ok?
best regards michael
Posted on Sep 10, 2009
Cd rom drive
Replace your CD drive with a DVD drive. The old one is dead.
Sep 03, 2013 | Intel DG41RQ (4505235) Barebone
ATAPI DVD A DH168BSH configuration incomplete or damaged
Try uninstalling the DVD drive in the Device Manager in the Control Panel, then do a graceful shutdown of the PC. Power the PC back on and see if it finds "new hardware" and installs the driver. I take that you have an Acer Aspire PC.
Aug 11, 2012 | Acer Computers & Internet
My dvd/cd rom is not working on my eMachine. When I open My Computer, it does not show an e drive.
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
Jul 17, 2010 | E-Machines emachines (emachinees) CD-ROM...
My cd/dvd drive has stopped working it says- Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)- what can i do to fix it...
Click Start
Click Control Panel
Click System
Click Hardware
Click Device Manager
Expand the CD/DVD branch of the tree.
Right-mouse click on the CD-ROM, and choose "uninstall" or "remove".
Restart your computer, and Windows should "find new hardware", and should load the correct device-drivers for your CD-ROM.
Dec 10, 2009 | HP Computers & Internet
CD drive wont work - code 19 showing - Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
Hello
Ok, i had the same error a couple of months ago, i dowloaded this tool from the link below and it works perfectly.
http://microsoft.pcerror.info/errorcode/code%2019.html?gclid=CPLh-vrVwZ4CFYIA4wodvCy5nw
Just click on the link above and you will be directed to the page where you can downoad the tool.
Kind regards
Andrea
Dec 06, 2009 | LG GSA 4163B DVD±RW Dual Layer Burner
Dec 28, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Computers & Internet Logo
182 people viewed this question
David Payne
David Payne
