Question about Sanyo DP46849 46 in. HDTV
How to fix a sanyo 46 lcd model DP46849 with a half screen distortion
    Sergeant:
    Habit-Forming:
  • Sanyo Expert
  • 198 Answers
Defective LCD panel, it is not worth to replace it.
Posted on Apr 02, 2015
SOURCE: Wanted: 32" Sanyo LCD replacement screen (compatible)
take apart the lcd and find the lcd panel number then email patel150@gmail.com to buy a new panel from a factory in china
then put it all together
Posted on Apr 17, 2009
  • 102 Answers
SOURCE: Sanyo DP46849 composite video input malfunction
Sounds like a damaged port or related circuitry. You could take it to a repair shop if you really want to use that port, wouldn't cost too much
Posted on Feb 06, 2010
  • 63 Answers
SOURCE: I have 1 37" Sanyo LCD TV. The screen is split
bad screen driver boards, it can sometimes be corrected by tapping it on the side that is affected NOT ON THE SCREEN I MEAN ON THE TOP. The only way to cure the problem is replacing the panel.
Posted on Nov 14, 2010
  • 63 Answers
SOURCE: my sanyo dp46849 screen is discolored with red and
common issue with this model. if im correct not only is it red but it also has a ghosting affect this is caused by bad controller boards connected to the tv screen itself it is not any easy fix the only real option is to replace the whole panel which can cost between 200 to 1500.
Posted on Feb 22, 2011
caroldon
  • 17129 Answers
SOURCE: I have a 46" Sanyo
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section . Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly , the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
Posted on Jul 08, 2011
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
How to do you fix a sanyo 46 lcd HDTV with a half screen distortion?
Shouldn't have bought a Sanyo. It's not the same company it once was. It's toast.
Mar 31, 2015 | Sanyo Televison & Video
Why my 42" sanyo DP42841 HDTV LCD SCREEN GOES BLACK ON THE LEFT SIDE?
That sounds like a faulty LCD panel tab. The only true fix is to replace the screen. This usually isn't cost effective.
Jan 19, 2013 | Sanyo DP46849 46 in. HDTV
How do I fix a A black screen on the left side of
Hello; I do a lot of Sanyo repairs and have seen this problem several times. The left side may be black always or sometimes. In either case the LCD panel is bad. the part from Sanyo was last $1000.00. There seems to be some refirbs or knockoffs for $400. Time for a new set. John
Jul 08, 2011 | Sanyo DP46849 46 in. HDTV
DP42647 On half of our 47 inch screen it is black and distorted when we first turn the TV on but after 30 or 40 minutes it finally just lights up and is fine.
Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish board that call the T-CON board for the replacement.This board sit in the middle at the bottom of the LCD screen panel.This T-CON board only job are to decodering picture pixels dots only before it show up to the LCD screen panel.
Jun 10, 2011 | Sanyo DP46849 46 in. HDTV
I have had a dark distortion on half the screen for some time now but it would snap back to a regular picture after half an hour or so . But now the dar and distortion won't go away. Any help out...
Their is most likely a problem with the pixels in your display. the reason why it dose this is that after the television warms up (about half and hour) the pixels adjust and start to work properly the only fix would be to replace the entire screen
Mar 05, 2011 | Sanyo DP46849 46 in. HDTV
My sanyo dp46849 screen is discolored with red and black, any wisdom is appreciated
Feb 22, 2011 | Sanyo DP46849 46 in. HDTV
Sanyo DP46849 46 in. HDTV Logo
157 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
