Question about Vizio P2 42 in. HD-Ready Plasma Television
THE POWER BUTTON IS COMING ON BUT THE SCREEN DOESN'T COME ON
Frozen startup screen & power button doesn't work
hmm it might be lock from pass code?
try to plug it into a computer oh but you'd have to install drivers to be reconize and you'd have to set printer to PC mode to reconize.
Mar 30, 2013 | Sony Up - Cr 10l Snaplab Digital Printer
HP dv6704nr power button doesn't work but quickplay/dvd start laptop, completely turns off if screen is beyond the cut off point no matter if it is in POST or in windows, and speaker doesn't w
i would take the button bar of and check to see if the cable is off to one side its a flat ribbon cable sounds like it is a little sideways that will make that happen there is a little clip be gentle undo it a little bit and straighten it out
Feb 25, 2013 | HP Pavilion dv6704nr Notebook
Window doesn't come on
That question does not reference what exactly is going on. Please step through from plugging in power adapter to power from wall outlet and pressing the power button.
ie: 1) plug in power adapter (i see charging light)
2) pressing power (i see boot screen logo)
3) next screen (i see windows boot logo)
.... and so on...
Jan 16, 2013 | Fujitsu LIFEBOOK NH532 Notebook
My 3ds xl screen has frozen
Hold down the power button until the screen goes black. Then press the power button to turn it back on. If this doesn't work, you'll have to remove the battery. If it still won't work, send it to Nintendo to fix; your limited warranty should still apply if it's the XL.
Oct 19, 2012 | Nintendo 3DS XL
Show me where the power button is
http://www.insidemylaptop.com/replace-broken-display-hinge-in-acer-extensa-4620z-laptop/
Scroll down to the photo under Step 1.
On the cover that is being lifted in the air, look at the button at the bottom/right.
Circle that is open at the top, with a line coming through the opening, halfway.
Power On button.
Doesn't work? Perhaps you have a bad Power On switch.
(Located under the Power On plastic button)
For additional questions post in a Comment.
Regards,
joecoolvette
Jan 29, 2012 | Acer Extensa 4620 Notebook
X7170 not powering up
Try this approach:
1. Remove the power adapter from the printer. The power adapter is the black box where the power cord is plugged in at the back of the printer.2. Disconnect the power cord from the power source.3. Reconnect the power cord directly to the power outlet in the wall. Bypass any surge devices or power outlets.4. Re-plug the power adapter into the printer.5. If the printer won't automatically power on, press the power button on the printer operator panel.
I hope this helps.
Should the problem continue, please contact Lexmark Technical Support Center for additional assistance.
Nov 28, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Neo Notebook model no. LC89-black screen only.
  1. All Operating Systems
    • 1 Remove any discs in the computer.
    • 2 Hold the power button down until the computer turns off.
    • 3 Press the power button to turn the computer on. If this doesn't work, proceed to step four.
    • 4 Remove the battery and unplug the netbook. Wait 30 seconds.
    • 5 Reinstall the battery and plug in the netbook.
    • 6 Press the power button for ten seconds. If this doesn't work, proceed to step 7.
    • 7 Insert the end of a paperclip into the reset button to reset the netbook. The reset button is a small hole that usually appears next to the USB and other ports.
    Windows 7
    • 1 Create a new Notepad file.
    • 2 Type this code:
      taskkill /F /IM dwm.exe
    • 3 Save the file as displayfix.bat in the following location: C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Startup
    • 4 Restart your computer.
Sep 20, 2011 | Computers & Internet
When i on my pc then the lg screen show me message analog power saving mode and then screen turns black. how can i overcome this problem
I would say that it doesn't see any signal coming from the computer. Check your output. Check the video drivers. Try another video display.
Aug 10, 2011 | LG Flatron L1951S-SN 19" LCD Flat Panel...
My screen doesn't work, it is sleeping. What can I do ? After I took a rest my screen dit nothing. Whatever I trie, it doesn.t light up.
Try restarting your computer, If it happens again, try to find a pattern in the problem. If you can't restart, hold down the power button for a few seconds to do a forced shutdown.
May 12, 2011 | Acer Aspire One PC Notebook
Vizio P2 42 in. HD-Ready Plasma Television Logo
78 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
