Question about Radio Communications
Can u tell me why my LCT-760 CAR 4.0, won't pair with my phone, iPad or won't show up after I scan ? It comes on then after 30secs.beeps and flashes red/blue??!!!
  • 32 Answers
SOURCE: headset does not flash red/blue so I can pair it with my phone
To get it into pairing mode (flashing red and blue) turn the headset off.  Hold the main button down until the light goes red and then off.  Then push and hold that same button and keep holding it even after the blue light comes on.  It will now go into pairing mode, flashing red and blue.  Set your cell phone to find it and it should work.
Posted on May 22, 2009
  • 32 Answers
SOURCE: 925 Plantronics will not pair with cell phone.
You are holding down the main button too long.  When it flashes blue and red it is now in pairing mode.  To turn on the headset hold down the main button until you see the blue light come on, then let go.  If you hold it any longer this is when it goes into pairing mode.
  • 7 Answers
SOURCE: old phone quit and blue tooth won't pair with new phone
Hold the volume buttons on the side while holding the call button for 10 seconds. It will reset the bluetooth and remove any other devices it may have been paired to. Then turn it off, back on and it will eventually stay lit blue and then you need to set it up through your phone. I hope this helps, I had the same problem and mine is working fine!
Posted on Sep 22, 2009
SOURCE: I have an Explorer 210 series. It will no longer pair
Just this morning I was able to pair this headset with my phone. Before, it was paired to my PS3. The key is to hold down the big round button on the outside until the light flashes red/blue (this is quick-pair mode) then just have your cellphone search for bluetooth devices and you're done!
Posted on Nov 05, 2009
Testimonial: "I tried that but I bet I didn't do it long enough. Thank you so much (I exchanged it already but will keep in mind). Thank you again!"
SOURCE: Head set not pairing with sony erricson k750i
The solution for paring the explorer 240 is found in the bottom of the product page for the embedded link on the User Guide Link. I have also provided the instructions below. I hope this helps
How to Pair Your Phone With Your Headset for the First Time
1 Turn on the Bluetooth feature on your phone.
For most phones, select Settings/Tools > Connections >
Bluetooth > On. See your phone’s user guide for more information.
2 Turn the headset on.
Turn on your headset by sliding the Power Switch toward the microphone. Wait until the indicator light flashes red then blue.
If you don’t see the red then blue flashes, turn the headset off, then turn it on again. Press and hold the Call Control button until you see the red then blue flashes that indicate pairing mode status.
3 Set your Bluetooth phone to ‘discover’ to locate the headset.
This usually involves going to ‘setup’, ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add a device’.
4 Once available headsets are listed, select your headset (for example 2XXPlantronics or 3XXPlantronics). If prompted for a passkey, enter 0000.
When pairing is successful, the indicator on your headset flashes blue. Your phone will also confirm when pairing is complete.
John M
Posted on May 07, 2010
How do i play music from my phone on my philips micro music system btm2180
1. On the Philips music system, press FM repeatedly until [BT] (Bluetooth) is displayed on the display panel. The Bluetooth indicator flashes blue.
2. On your phone, go to Settings and turn on Bluetooth. Press Scan. Your phone will start searching for nearby Bluetooth-enabled devices.
3. Select 'PHILIPS_BTM2180' on your phone and, if necessary,
enter '0000' (no quotes, all zeros) as the pairing password/key.
After successful pairing and connection with the phone, the Bluetooth indicator on the Philips system will turn solid blue and you will hear two beeps coming from it.
4. Start playing music on your phone and enjoy hearing it from the speakers on your music system !.
Dec 20, 2014 | iSymphony M50 Micro Music System with...
How do I pair my I Pad with my new Philips portable speaker using bluetooth ( can connect fine using a cable)
If your portable speaker is Bluetooth-enabled, here is the general procedure:
1. Press and hold the function control button on the speaker until you see red and blue lights flashing in rapid succession on the speaker (the speaker is now in "pairing" mode).
2. Turn on Bluetooth on your iPad and then tap on Scan. iPad will begin scanning for nearby Bluetooth devices. When you see a name similar to that of your speaker, tap on it . You will be asked for a passcode/passkey to pair the iPad with the speaker. Enter '0000' or '1234' (without the quotes).
3. Once the passkey is accepted, the two devices are now paired. The light on the speaker should become a steady blue.
4. On the iPad, tap on Connect. If the iPad connects to the speaker, you will see Connected. You are done. Play some music from the iPad to see if you can hear it coming through the speaker.
You should have this procedure detailed in the set up guide that came with the speaker. Please note that pairing is required only for the first time you try to connect the two devices, to get them "acquainted" to each other. After that, all you need is to connect the iPad to the speaker every time you want to listen to your iPad through the speaker.
Nov 30, 2014 | Philips Audio Players & Recorders
My iPad won't find my Bluetooth speaker
Go to settings, General, blue tooth and remove any "other" previous paired BT devices & Turn off BT, then go to Sett. General, scroll down to reset and reset network settings, this will not delete anything. Power off BT speaker. after iPad re-boots turn on BT Speaker First, make sure BT is off on iPad as well as WIFI-wait like 10-15 seconds and then turn BT on in iPad it should see your speaker now and let you pair it up.
Jan 14, 2013 | Harman Kardon JBL Flip black
IPHONE 4 WON'T RECOGNISE BELKIN F82498 TRANSMITTER
some of the off brand chargers dont work in the car.
http://www.shopjimmy.com/
Sep 06, 2012 | Apple Belkin F8z498 Fm Tunecast Fm...
What is the passcode for the LG HBM 760?
Turn it on by holding the power button for four seconds, Then go to your phones bluetooth setup screen, search for new devices, and pair it. The blue led on the HBM-760 will turn solid blue during pairing. It is always discoverable. The default passkey is 0000. Hope this helps.
Good luck and please rate 4 thumbs for the free answer
Mar 27, 2010 | LG HBM-760 Bluetooth Headset
I can't pair my Samsung mobile with my Mazda 6 Bluetooth hands free connection. Why. I have followed the car verbal instructions, but when I come to pair the phone with the car. It tells me to add a 4...
2010 Mazda 6
x4 0's ie. oooo worked for me but had to keep trying 3 to 4 times, pailring shows as mazda in cookie bluetooth screen
pairs ok except won't tranfer telephone numbers from phone to car -- music plays but constant gaps so useless other MP3 cowon connects nicely
PJC
Jan 15, 2010 | Samsung SGH-G600 Cellular Phone
Hoe do i put the lg hbm-760 in pairing mode????
Jun 22, 2009 | LG Car Charger For HBM-710, HBM-760...
How do i disconnect my HBH PV703 Headset from a damaged phone and connect it to another Phone
Step 1 - To reset your Bluetooth headset:
  1. Press and hold down the volume keys "+" and "-" on your headset at the same time, until your hear a beep and the light flashes red and green alternately.
  2. Press and hold down the volume keys on your headset until it is turned off. The headset is now reset as it was when purchased.
Step 2 - To pair the headset with your phone:
  1. Make sure the headset is turned off.
  2. Turn on the Bluetooth function and Bluetooth visibility in your phone (This makes the phone visible to other Bluetooth devices).
  3. Place the phone within 20 cm (8 inches) from the headset.
  4. Press and hold down the call handling key on the headset until it beeps, shows a steady green light and then flashes red and green alternately. If the indicator light only flashes red or green, simultaneously press and hold down both volume keys until the headset beeps and flashes red and green alternately.
  5. If your phone supports auto pairing, press "Yes" when you are asked to add the headset to the phone. If not, check your phone User Guide on how to pair the Bluetooth device. If required, the headset passcode is 0000.
  6. The headset beeps and flashes green when successfully paired.
Jan 21, 2009 | Audio Players & Recorders
I need a instruction maual for a itrax bluetooth device
Pairing With A Bluetooth Enabled Cell Phone
1. The BTCK06 and the Bluetooth enabled cell phone should be within a distance of 3 feet
(1 metre).
2. With the BTCK06 OFF, press the MULTI-FUNCTION Button (The bottom button) for 6 seconds.
The Red & Blue LED's will flash alternatley and the speaker will make a long BEEP sound.
3. The Bluetooth cell phone will search for nearby Bluetooth devices. The cell phone will display the
BTCK06 in the list of Bluetooth devices. If you are using a "dongle" type Bluetooth adaptor,
follow the manufacturer's instructions for that device.
4. Select BTCK06 to add this Bluetooth device into the list of the paired devices.
5. Enter in the PIN Code "0000" and your mobile phone will show that pairing is complete.
6. If Pairing is successful, user will hear a long BEEP and the Blue LED will flash about every
3 seconds.
Nov 24, 2008 | Cell Phones
Radio Communications Logo
41 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
