Question about Ozeri Scale. Touch Digital Bath Scale in Black ZB13
I have lost my manual. I just changed batteries and my scale will no longer show the BMI, etc. I think I have put them in wrong but I don't remember how to change them. How do I fix this? Also, how can I get another manual?
I changed batteries in my producx scales and they last about two days. This scale has the BMI Age HT etc stuff but we have always only used weight. I have done this at least three times. What am I doing...
Are you using the giant packs of cheap batteries from Amazon or some similar place? Try using a set of high-quality batteries from a trusted source.
Aug 04, 2014 | Health & Beauty
Seca 769 error code e.10.11
showing error code " Seca 769 error code e.10.11" how can i solve this problem.pls help me.
Oct 07, 2013 | Seca 769 Digital Scale 400 Lb with Bmi and...
I changed the new batteries but still digital display is not shown
if the batteries are new and the battery terminals are clean and not corroded or broken, and the battery polarity is correct when they were installed. There must be a fault in the internal circuits of the scale, and a technician with the right tools, training, and experience will be needed to repair it.
Maybe time for a new scale.
Oct 05, 2017 | Health-O-Meter Health o Meter BFM681DQ-63...
I don't have a manual. My scales have been very variable, like this morning showing that I had gained nearly 5 lbs in one day. I've been sick and am not eating much, so I know that can't be...
I don't have a manual. The readout is in kilos rather than pounds some of the time. How can I get it to read in pounds all the time? Also I replaced the batteries. Are they supose to be both with + up? I have a replacement heart valve so I don't want to know body fat. How do I make sure it is off?
Jun 23, 2011 | Taylor & Digital Scale Lithium Scale
It is not showing me my BMI or BMR! How do you get that to show?
BMI + BMR do not show up when the scale is set in child mode. It's possible you have it set on child, instead of male/female. I have the manual uploaded on photobucket if you needed it.
http://s1125.photobucket.com/albums/l587/landofnarnia/Taylor%205568%20Scale/
Amy
Dec 29, 2010 | Taylor 5568 Fat Scale Stainless Steel ()
What is mean by body mass index?(bmi)
Is a measurement to determine a persons weight over height the formula is weight(KG) / height(METRES), a normal healthy person should have a bmi of 18.5 to 25 anything above this means the person is fat to obese
Aug 15, 2010 | Taylor Body Mass Index BMI Scale Black...
Lost instructions for bmi and special feature settings
Conair Support – Online Tech Help to Troubleshoot Problems
by: Guest1223497 in Conair Weight Watchers WW-87 Body Fat Glass Scale | 9 months , 28 day(s) ago | 10 ... Manual or Instructions for Conair CID502 Phone ...
livesupport.maybenow.com/Conair
Oct 04, 2009 | Conair Weight Watchers WW-87 Body Fat...
Instruction manual soehnle scale I need to rest the scale so it shows the bmi, hydration and weight.
I have looked and maybe you have the model number wrong the scale you are talking about 63700 Calando Quattrotronic scale is a simple digital scale and does not provide bmi, and hydration.
here is a link to the manual, http://www.leifheitusa.com/manual/63700.pdfit is in several languages including english as the company is european and sells to many countries. If you look english is there it is a very simple manual as the scale is only desinged to weight in either lbs or kgs nothing more. Sorry. If you would like a bmi chart you can get that here http://www.healthdiscovery.net/links/calculators/body_massindex_chart.htm and figure out your bmi based on height and weight in the chart.
Apr 23, 2009 | Soehnle 63700 Calando Quattrotronic Scale
Lost manual, need instruction on how to reset Taylor 5700 BMI
personalcare.owneriq.net/manuals/mfg/taylor/5571.html
go to that address and you can download the manual.
Feb 03, 2009 | Health & Beauty
Error reading on display "errAL"
"errAL" shows that some errors done related with overload, sensor may be open or damaged, check and replace.
Nov 29, 2008 | Detecto DR400C 750 Digital Visiting Nurse...
Ozeri Scale. Touch Digital Bath Scale in Black ZB13 Logo
182 people viewed this question
Top Ozeri Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Ozeri Health and Beauty Expert? Answer questions, earn points and help others
