Question about Miscellaneous
What is this on my neck??? - Miscellaneous
    Top Expert:
  • 6,702 Answers
Looks like you have a inflammation a tooth? your troth? the glands look swollen I would visit a doctor if I was you. I'm not a doctor, so I'm not sure i'm allowed to give any advice.
Posted on Mar 31, 2015
  • Harrie Mar 31, 2015
    Troth should be throoth.
The neck of my guitar is not straight but i alreadyadjusted the trusrod
Edgar,
How are you determining that the neck is not straight? If you are thinking the neck is not straight because the strings are at different heights along the neck, the problem may be neck tilt or saddle and/or bridge height. You can raise or lower the bridge system or string saddles to add or subtract string height along the neck. In addition, neck tilt (particularly easy to adjust on bolt-on necks) refers to the angle that the guitar neck exits the neck pocket on the guitar body. This also effects string height.
Conversly, if you see a distict bow or bend in the neck when you look down the top edge of the neck, the truss rod may indeed be involved. Generally, most players like a little bit of "relief" in the neck. That is to say, a little bit of a concave bow. I prefer a relatively straight neck with very little relief. Just preference.
However, you mentioned you already adjusted the truss rod. Make sure the truss rod is functional. If you loosen the bolt or hex on the truss rod and the concave bow on the neck gets more pronounced, it is likely that you truss rod is ok. If you make adjustments on the bolt and there is little or no change on the neck relief, it is possible that your truss rod is not functioning or is broken. It is very possible to break a truss rod by over tightening but it would take some real effort to do. Still, it is possible.
Check out those points and see if it helps.
Confirm truss rod is working.
Check bridge height and saddle height.
See if adjusting neck tilt is possible on your model guitar.
Good luck.
Oct 17, 2013 | Fender Music
Neck pain
Swap sides with passenger and driver My 98 did that
Nov 01, 2012 | 2011 Nissan Altima 2.5
I need documentation to set neck adjustment and intonation for a Gibson ES-359 custom. It doesn't seem that Gibson has anything readily available.
Intonation is easy if you have an electronic tuner, and instructions for a Les Paul style guitar will be close enough. Same with neck adjustment, if it is a set neck, use the Les Paul info. If a bolt on neck, everything but the neck angle is still relevant.
Jul 01, 2011 | Gibson Guitar Gibson Custom ES 359 Semi...
Fret buzz on new fender david gilmour Nos strat
fret buzz can usually be cured by adjusting the tension rod, unless the neck is permanently warped from excessive heat/humidity (from, say, being left in a car on a summer day).
hold the headstock up to your face, and look down the neck. you should see that the neck is uneven around the frets that buzz. if the neck appears straight when viewed from the headstock, down toward the body, then the strings are just too low, and the bridge should be raised. if you see unevenness in the neck, however, when viewed this way, you should attempt to use the tension rod to straighten the neck.
the tension rod can be adjusted with the hex bolt that pokes out at the base of the headstock, right from under the top of the fretboard. use an allen key to gently turn the tension rod either way until the neck begins to straighten out. if the tension rod cannot straighten the neck, then the neck is warped from heat/humidity.
Mar 09, 2011 | Fender David Gilmour NOS
My celebrity deluxe was damaged a while ago. Neck separated from body. Was repaired but action(neck) not like before, strings farther from neck, harder to play. Can neck be reset with better action like...
Yes, a competent Luthier should be able to reset it... HOWEVER it may just need a truss rod adjustment. The truss rod bends the neck slightly to set string height in the middle of the neck.
Dec 21, 2010 | Ovation Celebrity Deluxe Guitar Acoustic
Which way does your neck go on this bolster
Your neck goes on the contuored part - head on the flat part.
Jan 20, 2010 | Earthlite Neck Contour Bolster
I need a replacement neck plate for the Washburn N4
Hello, I actually have two extra necks that I bought on Ebay a very long time ago. No idea is they are original or not. I will post one of them on Ebay. I bought them for a project which I finished. I had also contact Washburn a while back because I was looking for the neck but they will not sell the neck unless you send them the body. They explained that each neck is fitted to the body. I believe them because none of my 4 N4 have the same neck. I can not interchange them. I am starting the bid on Ebay for $400. If you want the other neck let me know. info@pmpincusa.net
Dec 14, 2009 | Washburn Music
Neck problem
Leaning into your computer or hunching over your workbench just makes its job more difficult. Poor posture certainly contributes to neck pain. Your neck contains bones, joints, tendons, ligaments, muscles and nerves, any of which can hurt. Neck pain also may come from regions near your neck, such as your jaw, head and shoulders. Conversely, problems in your neck can make other parts of your body hurt, such as your upper back, shoulders or arms.
Best Neck Pillow For Travel
Aug 27, 2008 | Conair Body Benefits Massaging Roll...
Neck Rest help
Amazingly, there is! This mp3 memory foam neck pillow comes with built-in speakers. Simply plug in your portable audio player, lean back, relax, and enjoy. The Memory Foam MP3 Neck Pillow is available from Amazon.com for $36.99 or from the Smarthome website for the same amount. You should be advised that because it plays your music on speakers, this thing might interrupt other people.
Aug 27, 2008 | Comfort Products 10motor Massaging Cushion...
Massaging neck rest question
The massaging neck rests usually offers you two relaxation therapies: variable speed vibration massage to customize massage intensity and heat. Some of this devices even have a "comforting sounds" option (which makes relaxing sounds). Besides that most of the massaging neck rests offers the same featurs. They wrap comfortably around your neck and shoulders, supporting your head in a comfortable position (Usually - memory-foam filling and a soft fabric cover). Hand-held control adjusts the vibrations to your specific comfort level, without having to stop the massage. Includes plug-in AC adapter, or you can use four AA batteries
Aug 27, 2008 | Comfort Products 60 2702 Fleece Pamper...
Miscellaneous Logo
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
