Question about Sewing Machines
What is the normal tension settings for normal 4 thread overlocking
  • Sewing Machines Master
  • 12,296 Answers
Depends on the Brand and Model. On my Bernina 1150, if the tensions are set in the middle, it is usually a good tension setting. Each machine is different though and with use, those settings may change. You should be able to start with all 4 tensions set in the middle and then, looking at how it stitches, you can adjust each tension as needed.
Posted on Apr 01, 2015
What tensions should I set my White Speedylock 234DE Serger on, please?
Manipulating the tensions on a serger creates the different stitches. Therefore, it depends what stitch you want to make that determines how you set the tensions. For a basic 4-thread overlock, usually setting the tensions at the midway point is standard, however, some tweaking of each may be required to get them balanced. What helps is to thread with four different colors making it easier to see which thread's tension needs adjustment.
The Anatomy of The Best Serger Tension My Tips Bonus Unpick it Serger...
How to Adjust Thread Tension on an Overlocker Singer Australia
You can download the Bernina serger workbooks that may help you set up your machine for specific overlocker stitches:
Bernina Mastery Workbooks
May 12, 2018 | Sewing Machines
NEED TENSION SETTINGS ON ELNA OVERLOCKER F4 PLEASE
The tension settings on an overlocker are meant to be changed depending on the stitch your are trying to make. For the basic overlock stitch, it is usually recommended to start with the tension dials set at the midway point. However, machines differ, so those may even need to be tweaked. The tension is correct when all the threads meet in the middle of the fabric. It helps to test your machine using the 4 colors of thread so you can better see what is happening with the threads and you will be able to adjust each as needed.
overlocker tension Google Search
Feb 20, 2018 | Elna Sewing Machines
Tension settings on empisal overlocker 754d, pulse ?
The standard tension for a 3 or 4 thread overlock is to set each tension dial at the midway point and then tweak it from there. It helps to use different colors of thread so you can distinguish what each thread is doing.
Make It Handmade Perfecting Serger Overlocker Tension
Mar 13, 2017 | Sewing Machines
How do I get a balanced tension with my Elna 624 overlocker?
The best way is to thread with 4 separate colors of thread and then studying the stitch result. With the 4 colors, you can easily tell which thread tension is "off" and whether it should be tightened or loosened. However, a serger is not like a sewing machine where you can set the tension and use that setting for most projects. With a serger, a change in one or a couple of thread tensions will create a totally different stitch.
For most machines, there is a mark at the midway point on each tension control that is the "optimal" tension for a 4-thread overlock. HOWEVER, every machine differs, so these settings may need to be tweaked.
Different Serger Stitches and How to Use Them
You may want to download the serger workbooks at this site (Bernina), and work through each of the stitches. Make notes in the workbook as to how you have set up your machine to get the best of each stitch. This will be a great reference manual for many years.
Feb 23, 2017 | Elna Sewing Machines
How do I get the correct tension on my Elna 792D 4 thread overlocker?
ALWAYS Raise the presser foot when threading the machine. Give each thread and extra little tug when threading the tension disks so it seats completely. The midway point on the tension disk is the standard factory setting when using the standard thread weight, however, with use, age, and thread weight that setting may change. So, the user can use the midway point as a starting point for the basic overlock stitch but will need to make adjustments to get the correct tension. When testing your tension, it works best to use the 4 thread colors so it is easier to identify which thread is misbehaving. When you become familiar with your machine and how the stitch looks, it is easier to identify which thread is which.
Solving Serger Dilemmas
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=7&ved=0ahUKEwjjhv6Uw4PSAhXJrVQKHQrmCtgQFghBMAY&url=https%3A%2F%2Fwww.bernina.com%2Fen-NZ%2FExperience-NZ%2FSewing%2FSerger-projects%2FUSA-nz%2FSewing-Embroidery-nz%2FTensionHeadaches%2FBERNINA-Serger-StopTensionHeadaches-nz.pdf&usg=AFQjCNEAPID5FKBVa_amKfVmrTKgadlmRw&cad=rja
Remember that the tension settings will also determine the stitch you are trying to create. A basic overlock will generally have the tension set around the midway point, however, when changing to a rolled edge or some other stitch, certain tensions will be increased or decreased in order to create that particular stitch.
Feb 09, 2017 | Elna Sewing Machines
How can I set the right tension on an overlocker globe lock m-34?
The right tension on an overlocker will vary depending on the result that you want. The standard tension for just a plain 4-thread overlock stitch would generally have all the thread tensions set at the halfway mark between the high and lower number. From that point, you may need to tighten or loosen each thread tension to get all the threads to stitch evenly.
Probably the best advice would be consult your owner's manual. It should have instructions on adjusting the tensions and what to look for.
Another suggestion would be to search YouTube for a video that shows how to adjust overlocker tension.
Nov 14, 2015 | Sewing Machines
What is the standard elna lock f4 thread tension settings
five on all tension dials and stitch length between two and three for a normal 'marrowing' 4 thread overlock. at factory tension dials would all be set to five.
May 13, 2011 | Elna Sewing Machines
Trouble with my Huskylock 680D overlocker Tensions
You need to re-thread the serger.
Refer to the manual or open the front of the serger to see if the threading diagram is there.
With most sergers, you begin with raising the presser foot, then set the tensions to zero.
Begin the threading with the upper looper (curved looper), then the lower looper and the needles last.
Pull the thread under the presser foot and to the left side of the serger.
Set the tensions back to normal 4 - 5 usually.
Lower the presser foot and hold onto the threas tails as you stitch a chain. If the chain of the four threads is ok, you are ready to serge fabric.
Feb 21, 2010 | Husqvarna Sewing Machines
Janome 134D Overlocker
Set you differential at 1.0 and your loopers at about 3-4 the needle thread tensions are usually around 5 to 6.
 I would also suggest that you place four different color threads on machine to make it easier to adjust all. Now if you are using only 3 threads the same applies.
 Also------patience.
Oct 09, 2007 | Janome MyLock 634D Mechanical Sewing...
Sewing Machines Logo
108 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
