Question about Polaris 2009 RMK 800 Dragon 163-Inch
What could be the problem snowmobile Polaris Dragon 800 2009?
At idle speed the snowmobile works well, but in the snow at full throttle turns on the check engine and snowmobile reduces the speed is bad. If you keep going at full throttle, dies right cylinder. The first failure was replaced piston group and the oil pump after running-in the engine broke again for the same reason
3 Suggested Answers
Hobbit_who
  • 2044 Answers
SOURCE: polaris troubleshoot
If I was a betting man, you should do a compression Test on your Engine. What you are going to find is the PTO Cylinder has a lower compression than the Cylinder on the Right. Doing a Top End Repair on your Sled will only take 4 hours to do correctly. You can do RINGS ONLY but you may want to replace the Piston if the SKIRT has marred the Cylinder Walls to ensure a longer life. It is also recommended that you make sure your Oil Injectors are not clogged and functioning correctly.
Posted on Feb 12, 2014
  • 10 Answers
SOURCE: Why does my 2009 polaris dragon 800 idle fine then die when I give it gas
That sounds like either the throttle position sensor or exhaust temp sensor has issues. The throttle position sensor have had issues with wires breaking off. The best way to find out is to have a dealer check with their computer. If itis the throttle sensor they can adjust proper upon installation.
Posted on Feb 21, 2015
Start up idle is slow below 1050 rpms and sounds like going to stall while idling. Runs fine otherwise.
How to adjust your Polaris Snowmobiles TPS. - YouTube
? 6:05
https://www.youtube.com/watch?v=aEPx7OsywNk
Dec 11, 2009 - Uploaded by PolarisRich
A quick video on how to adjust your Polaris Snowmobiles Throttle ... TPS cause this? it seems like it hits top rpm, it runs flawlessup to the ... Would this work on a 2011 Polaris pro rmk 800?? ... I have a 2006 Polaris Fusion 600 h.o. It seems to bog out when u first start ... Sounds like its a carb or clutch issue!
2011 Pro RMK 800 Top End Bogging [Archive] - SnoWest Snowmobile Forum
www.snowest.com/forum/archive/index.php/t-298871.html
Jan 30, 2012 - 52 posts - ‎33 authors
[Archive] 2011 Pro RMK 800 Top End Bogging Polaris: Pro-Ride. ... Sled is a 2011 ProRMK 800 155, 1700 kms, MBRP can. ... problems with bogging at every rpm and roughidle, I am running 91 from .... fuel filter yet?...almost sounds like your fuel pump can't keep up with ..... I am running a 2010 660 CFI-4. 2010 dragon 155 RMK electrical problems
Feb 3, 2013
Polaris update
100+ posts
Nov 15, 2009
~~The Official Phazer Thread~~
100+ posts
Sep 12, 2009
M1000 Hiccups on the Bottom
100+ posts
Jan 28, 2008
More results from www.snowest.com
Jan 12, 2016 | Polaris 2010 RMK 800 Dragon 163-Inch
Feb 21, 2015 | Polaris 2009 Dragon SP 800
Polaris troubleshoot
Feb 11, 2014 | Polaris 2004 EDGE Touring 340
It idles but when I pressthe throttle it kills out
throttle safety switch little pin switch behind the thumb throttle hold it back bet it will let u open throttle..could be bad switch or carbs out of sync
Dec 14, 2013 | Polaris New Genuine Polaris Snowmobile...
I have a 1992 polaris indy 500, it won't start unless I hold the throttle wide open, it won't idle
THE THROTTLE SAFETY SWITCH IS NOT WORKING, YOU CAN EITHER CUT THE WIRES OR REPLACE THE SWITCH. I SUGEST REPLACING THE SWITCH
Dec 13, 2010 | Polaris New Genuine Polaris Snowmobile...
INDY XCSP 700 1 MINUTE IT IS RUNNING FINE THE NEXT WILL NOT IDLE AND CAN'T GET TO 50 MPH ON FULL THROTTLE
cdi box on top of air cleaner not making proper contact to check keep wiring clips tight with zip ties should work for quite a while cdi box cost $300+
Feb 11, 2010 | Polaris New Genuine Polaris Snowmobile...
My 97 600 triple revs to about 4500 rpm's when starting if you half choke it kicks back down
haha, this happend to me. your idle speed screw is turned in too far, back it out and she will idle down
Jan 31, 2010 | Polaris New Genuine Polaris Snowmobile...
How can i tell if the oil pump is working// blown piston /550 polaris
Pumps are bad on 2003-2008 550 fans, they get air bubbles with consistant throttle positoins-speed. Contact Polaris they will pay for the parts, not labor.
Jan 04, 2010 | Polaris New Genuine Polaris Snowmobile...
Polaris 2009 RMK 800 Dragon 163-Inch Logo
609 people viewed this question
Top Polaris Winter Sports Experts
Todd Arndt
Todd Arndt
Lawrence Oravetz
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
