When the unit powers up, the display goes from 88888 to "Lo" and does not change. Need help to troubleshoot the unit.
Fujitsu AH532 White Color Or Black
Posted on Apr 01, 2015
    Top Expert:
  • Computers & ... Master
  • 22,715 Answers
Make and model of laptop please.
Posted on Mar 31, 2015
After a power outage my maytag model MFI2569DEQ1 fridge display panel won't light up. Pushing any button lights up everything and 88888 across fridge and freezer temps...
Unplug it for a couple of minutes, Try again. It may have been hit with a surge. IF that is the case, you are looking at main control board and some money. Contact your homeowners insurance if a surge has damaged it.
Jul 31, 2017 | Maytag Refrigerators
Why is my Bose radio is too dim?
The Bose Wave Radio has two brightness levels: Bright Hi (with a range of 8-15, and default of 10) and Bright Lo (1-8, default 4). The radio automatically goes from Hi to Lo when a room is darkened so the display doesn't interfere with sleep.
On recent models you can reset the defaults to make the display brighter or dimmer in both Hi and Lo levels.
1. Press and hold the Alarm Setup (Menu) button on your remote until -setup menu- appears in the display.
2. Then press the Tune/MP3 button until Bright Hi- appears. Use the Time - or Time + buttons to change the settings.
3. Go to Bright Lo- and adjust that setting too if necessary.
4. Press Alarm Setup (Menu) again to exit setup, or simply wait 10 seconds.
You're done! Note that if you set both Hi and Lo to 8, the brightness will stay the same all day and night.
Aug 21, 2014 | Bose Wave Radio
I have a DigitZ DZ3-600 and when I turn it on the word FULL in the display screen . What can I do to clear this and start using it?
My search is telling me that this is a scale. Is this correct? If so - this is the manual. \'FULL\' is not an error, but this is the correct model. If this is not a scale, please write again and provide more information:
The manual is short and PASTED after link to same here:
http://digitzscales.com/index.php?option=com_content&view=frontpage
Digitz DZ3-600 Manual
I. Operation
1. Place the scale on a flat, level surface and press the ON/OFF key to turn the scale on.
2. Once the start-up process completes and the scale goes to zero you are ready to weigh.
3. Place the quantity to be weighed onto the weighing platform.
4. Wait a couple seconds for the display to stabilize before taking a weight reading.
II. Changing the Unit of Measure
1. Press the MODE key to change the scales displayed unit of measure.
2. If the scale is turned off then back on, it will default to the last unit used.
• DZ3-100 Units: g (gram) oz (ounce) ct (carat) gn (grain)
• DZ3-600 Units: g (gram) oz (ounce) ozt (troy ounce) dwt (pennyweight)
III. Using the Tare Feature
You can use this scale\'s tare feature to subtract the weight of an empty container or vessel for net weight determination. NOTE: The weight of the container will subtract from the available capacity.
1. Place the empty container or vessel on the weighing platform.
2. Press the TARE key once. The display will then reset to zero. If the container is removed, it\'s weight will be displayed as a negative number.
3. You may now fill the container with the quantity to be weighed. The display will show the net weight of the contents.
4. To return to normal weight display (gross weight), remove any items from the weighing platform and
press the TARE key again to re-zero the scale.
IV. Calibration / Adjustment
1. Turn the scale on by pressing the ON/OFF key.
2. Wait for the display to show "0.0g" or "0.00g" then press and hold the MODE key until the display shows "CAL", then release.
3. Press the MODE key again. The display will flash "CAL" followed by the required calibration weight.
4. Place the required calibration weight on the center of the platform. The display will show "PASS" then return to normal weighing mode. Calibration is complete! You may now turn the scale off.
V. Error Codes
1. OUTZ - Zero range has shifted. Perform calibration adjustment. If the problem persists, the load cell may be permanently damaged due to overloading.
2. 88888 - Maximum capacity exceeded. Remove the extra weight to avoid damaging the load cell.
3. L - Batteries are low. Replace the batteries.
VI. Specifications
DZ3-100 DZ3-600
Max. Capacity 100g 600g
Readability 0.01g 0.1g
Min. Weight 0.03g 0.2g
Power Two (2) AAA Batteries
Dimensions 3.0 x 5.0 x 0.8 in.
Platform Dimensions 2.5 x 3.0 in.
For warranty and support, please email
warranty@digitzscales.com
Aug 20, 2014 | Office Equipment & Supplies
IE on screen what does that mean?
The codes these displays usually show that are hard to trouble shoot are:
88888 - This means the unit has suffered from dirty power or power surges and should be unplugged and plugged back in about 60 seconds later. This should reset the unit.
OF- Means the unit is in a Cooling OFF Mode, This is a power saving feature used by Retail locations. Some call it a DEMO mode.
PC-ER - unfortunately means your unit needs service.
IE - is a tough one, I would like to see it first hand but if everything is working correctly might possibly be a display error and it should be saying ICE - I have not come across this one in person.
Aug 06, 2013 | Samsung RF4287HA
I have a GE JVM2070 microwave oven that runs for a few seconds and then shuts down. I was told by a repair person that it was the smartboard. I replaced it ($200) and same problem. When it shuts down...
Sorry you found an ignorant repair person!
You have a failing (noisy) magnetron.
You should first return the unneeded circuit board.
Then see this FixYa solution even though your model number is different.
Jan 16, 2013 | GE JVM2070 Microwave Oven
Bat lo flashing periodically
You need to change batteries. The bat lo light flashes when you have about 10% battery life left. Rus
Dec 05, 2009 | Honeywell CT3200 5-2 Day Electronic...
CCFL OK but no display
LCD panel. i have several Toshiba laptop with bad LCD.
Nov 04, 2009 | Toshiba Satellite LP154W01 Notebook
"LO" error code on new H400FDN heater
it is low water pressure sensed, unit will not start unless pump is working
Jun 07, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Microwave Key Pad stopped working
buy a new one they are not expensive wal-mart has 1000w for about 80 bucks
Jan 25, 2009 | Sharp R-1874 Convection/Microwave Oven
Phone rings to loud and everyone can hear my conversation please help
why don't u get a new one there only 79 dollars but if i was you i would keep the volume like that i rekon its good
88888
8
88888
8
8
88888
888888
8
888888
8
888888
8 8
8 8
8 8
8
8 8
8 8
Oct 21, 2008 | Samsung SGH-E630 Cellular Phone
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
