Why does the drum drop when we put water in? It doesn't revolve during the wash cycle.
    Top Expert:
  • Washing Mach... Master
  • 35,748 Answers
There could have been bearing failure.
Posted on Mar 31, 2015
3 Suggested Answers
beltronic205
  • 1466 Answers
SOURCE: drum dose not turn belt is ok no smell or dust
Fit new motor brush kit if well worn cost about £25 ...
Posted on Nov 13, 2009
  • 3 Answers
SOURCE: my washing machine don t do the fast spin the
it may need a new beelt on the drum as it might have buckled
Posted on Apr 25, 2010
Water runs out of soap box during rinse cycle
Hi there, given this a lot of thought. I had same problem. Could be that you are in a hard water area. Soap is not dissolving properly and building up in the rubber tube between soap box and drum. How I resolved this. Turn off power remove top cover of washing machine and massage the rubber pipe between soap box and drum to soften and cause undissolved saoa to drop into drum. This should rectify problem. Also consider using every month some descaler powder called Descaler cheapest from Axxxxn best wishes.
Feb 26, 2014 | Amana Tandem 7300 Washer and Dryer Stack...
Hotpoint WDL520P Washer dryer Filling up with water as it should during the drying phase untill the end of the cycle when it fills up entire drum with water constantly during this cycle it is constant
The other logical point is that it can be related to a faulty output or error from the program controller output. In some cases choosing an alternate program cycle can confirm this case of faulty cycle patterns.
Feb 12, 2013 | Washing Machines
Dirt like substance coming out from the washine during wash cycle
Possible that there is dirt in the drum that comes up when the drum revolves. This can be due to dirt that had accumulated within and needs to be removed. Please try to watch this link and get some tips to clean the drum.
click on : cleaning the drain
Jan 01, 2013 | Washing Machines
Bosch WFL 2050 the water level during washing is too low
id try another pressure sensor off another machine.........
might help...
cheers
May 27, 2017 | Washing Machines
I have a brand new front loader and the drum is not turning during the cycle....it turns freely if I do it by hand
If you hear the motor running and the console doesn't put out an error code during the cycle, it sounds like your drive belt may have come off the motor / drum pulley. You should be able to access it by removing the back panel. Be careful- and unplug the machine first.
Good luck.
May 14, 2011 | Bosch Washing Machines
The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
May 18, 2010 | Whirlpool LHW0050PQ Front Load Washer
The water will not drain from my drum. The spin
Check the filter, which is located at the bottom front right of washer behind a flap or drop down cover.
Unscrew anti-clockwise to remove and clean.
Please rate my solution.
Thankyou.
Jan 28, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Not enough water in the drum during the washing cycle
If its a High efficiency washer it doesn't use much water. Usually the front load washers are HE washers
Aug 30, 2009 | Samsung WF203ANW Front Load Washer
Water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
Indesit Washing Machine not proceedding with the cycle programme after filling with water.
Cant understand how the machine will revolve on the 'spin cycle' & yet you can hear the motor on the 'wash cycle' but yet it doesnt revolve!!
Nomally if the water fills, & the tub revolves without the programmer advancing, its because the heater is not working. ie faulty thermostat, heat element, or maybe a wire burned off in the 'heater circuit'. Check if you have 240 volts at both ends of the heat element, with a meter or 240 volt bulb
                         !! BE CAREFUL OF 240VOLTS!!
Oct 29, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
