Question about KitchenAid Kitchen Ranges
My oven has stopped working. When I touch the touch pad nothing happens. Why is the digital readout displaying F2E1?
    Top Expert:
  • KitchenAid Master
  • 51,143 Answers
Google it that is the error code .
Posted on May 14, 2015
SOURCE: touch pad
Update - Turned the Circuit Breaker off to stove and turned back on. The second time I did this, it "fixed" the touchpad. Clock resumed flashing the time and all buttons work. Thank goodness no service call this time!
Posted on Jun 10, 2008
SOURCE: F2E1, F3E0 Error Codes
Believe it or not, but on my Whirlpool Estate (Model: TES400PXHQ0)....after reading about this error, I looked at the sensor, and I noticed it was touching the metal on the inside of my oven. I moved the sensor away just by pulling on it to the center of the hole that was cut out for it, plugged the oven in....and didnt get a code at all....not even the PF code. So, I tried the oven out....expecting for it to beep at any second, and it didnt!!!!
So, in conclusion.....I guess by the sensor touching the metal on the inside, it couldnt get an accurate reading, so the computer threw out the infamous F3E0 error.
I've had this oven for 4 months and always had to stare at the F3E0 display (it was donated to me). Thanks for all who had done the research on this to point me in the right direction, as Whirlpool wanted someone to come out at $60 just to come out, then $80/hr!
Thanks again
~Luke
Posted on Oct 14, 2008
huuum
  • 750 Answers
SOURCE: electronic touch pad not working on my oven
Hello beachlady80,
Welcome
You said, It was working fine last night but when you woke up this morning the display has 3 vertical lines and none of the electronic touch pads work. The burners on top of the stove still work.
What is the model number and how old is the range ?
Try turning the breaker off for 10 minutes and then on again after this allotted time.
This may reset the system.
Let me know how it works.
Waiting for your answer.
Huuum
Please remember to leave a rating.
Hopefully it will be a solved!
Let me know
Posted on Oct 16, 2008
jumptrout51
  • 3361 Answers
SOURCE: GE Profile gas range - stove works, oven doesn't heat
Set the oven for bake. Wait a couple minutes and look in the oven. If you see a orange glow the ignitor is working, but, may need to be replaced.
If you see no orange glow the ignitor definitely needs to be replaced.
Posted on Feb 21, 2009
SOURCE: Kitchenaid Superba Gas Oven Touch Pad not working
We have a gas kitchenaid KGST307HBL9 and the touch pad is blank, but we discovered that you can still touch the buttons and it will work. (example touch bake; temperature; start). It will beep when the target temperature is reached.
Just so we don't forget and leave the oven on, we turn the oven light on as our signal. A little work, but not wanting to "fork" out the money at this time to repair.
Also, if you are handy RepairClinic.com has many items and can also answer question. We've used them for several of our appliance repairs.
Posted on Jul 02, 2009
No digital display and nothing works, like there is no power, however there is power going to oven What could be the issue?
Bosch HBL5450UC information from Consumer Reports
www.consumerreports.org > ... > Ratings
Consumer ReportsThis Bosch 30-inch electric wall oven has the following: ... We have had problems with it not working properly numerous times and have had it serviced directly ...
Aug 05, 2015 | Bosch Ovens
Operation manual is lost, how do I set the clock?
The manual for the Magic Chef MCD1311ST Microwave can be downloaded in pdf format from the following site (follow the link then click the "Manuals" tab):
http://www.mcappliance.com/mwodetailpage.aspx?ModelName=MCD1311ST
If you don't have time to download, here's what the instructions state:
SETTING THE CLOCK
When the oven is first plugged in, the display will flash ":0" and a tone will sound. If the AC power ever goes off, the display shows ":0" when the power comes back on.
1. Touch CLOCK pad.
This is a 12 hour clock system.
2. Touch CLOCK pad once more.
This is a 24hour clock system.
NOTE: This oven has multiple clock system. If you want 12 hour clock system, omit this step.
3. Enter the correct time of day by touching the numbers in sequence.
4. Touch CLOCK pad.
The display stops blinking, and the colon start blinking. If you selected 12 hour clock system, this digital clock allows you to set from 1:00 to 12:59. If you selected 24 hour clock system, this digital clock allows you to set from 0:00 to 23:59.
5. Touch STOP/CLEAR pad.
NOTE: If you attempt to enter an incorrect time, the time will not be set and a error signal tone will sound. Touch the CLOCK pad and re-enter the time.
Jun 28, 2010 | Magic Chef MCD1311ST Microwave Oven
Touchpad is not working
Hello :
If touch pad has gotten wet, then allow to dry for several days. Avoid spraying cleaning liquid near touch pad.
Check for insect infestation. Insects (cockroaches most frequently) will appear under clear surface of touch pad or under readout window; they like the warmth of the circuit boards.
Place window mesh over vent to keep insects out.
good luck .
please rate !
Mar 29, 2010 | GE Microwave Ovens
F2E1 message on range
I have a repairman coming to check it out.
Jan 25, 2010 | Kitchen Ranges
Display showing F2E1
HI. This code will appear if the key pad becomes unstable. This may be a loose cable, or faulty control board. Use the procedure to isolate the issue.
1. Check The keypad connector, which will be located on the backside of the control board, for a firm connection. Pull off the connector, and re-attach. If the code comes back, after the re-attaching method, move on to the next step.
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models may incorporate the keypad and control board as one unit. In this case, replace the control board (also referred to as the ERC or clock).
Dec 25, 2009 | KitchenAid Kitchen Ranges
Touch pad does not work, clocke does, nothing else works
Hi this will happen when the touch pad circuits become unstable and damaged, due to abundant usage or , old age.
simply replacing the touch pad will fix this issue.
May 30, 2009 | GE JVM2070 Microwave Oven
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Oven on our electric kitchenaid stops working and f2e1 error message comes on. It does this frequently
F2E1 is a fault code that indicates the keypad my be unplugged or has failed.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Jun 22, 2008 | Kitchen Ranges
Thanks again
~Luke
Dec 21, 2007 | Whirlpool SF367 Gas Kitchen Range
Kitchen Ranges Logo
169 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
