Question about Laser Computers & Internet
How does the PROLINE 1D LASER TERMINAL 4MB BATCH, INCL CRADLE work or is there a manual
We must use it with Pastel
2 Suggested Answers
Yogger
  • 117 Answers
SOURCE: does itsupport 1D linear laser scanner
This device has an Digital Imager (instead of laser scanner) which supports 1D and also 2D barcodes.
Posted on Aug 26, 2010
What does must settle TSYS MEAN WONT TAKE CARD
This means that the batch file needs to be settled before more transactions can be made. Do a batch download and this should solve your problem. If you need more help call. Frank (775)338-6634
Sep 19, 2014 | VeriFone VX510
I need e-toll contact number
Bongiwe
Contact Motorola Solutions. portal motorolasolutions com
Mark
Motorola Mobility Support
Aug 15, 2014 | Motorola MC9090-K DEMO KIT CONTAINS UNIT...
Mc9100 does not have laser
Contact Motorola Solutions. http://www.motorolasolutions.com/contactus
Jul 16, 2014 | Motorola MC9100-G30SWEQA661 MC9190 HAZ LOC...
HOW DO I BATCH OUT
GETI CHECK SALE [F2]
PAYROLL/BUSINESS [F3]
MORE VERIFY ONLY [F4] Press the Purple key below the More option. GETI CHECK SCANNER MENU [F1]
BATCH MENU [F2]
REPRINT [F3]
MORE VOID [F4] Select Batch Menu [F2]. ERASE BATCH [F1]
CLOSE BATCH [F2]
HISTORY REPORT [F3]
BATCH REPORT [F4] Select Close Batch [F2]. KEY IN MANAGER PASSWORD
AND PRESS ENTER Press [1] and [Enter]. ARE YOU SURE? CLOSE BATCH [F3]
CANCEL [F4] Select Close Batch [F3]. DIALING . . . The terminal will dial in to close the batch. Once closed, the terminal will print the batch report indicating Batch Accepted.
See example below. BATCH ACCEPTED
EXIT [F4] Select Exit [F4] to return to the menu.
Oct 19, 2011 | VeriFone VX510
WILL NOT READ 2D BARCODES
That is correct this LASER scanner does not read 2D barcodes. It contains a long range 1D laser engine.
Light source: 650 nm visible laser diode
Datasheet can be found:-
http://www.motorola.com/staticfiles/Business/Products/Bar%20Code%20Scanning/Bar%20Code%20Scanners/Rugged%20Scanners/LS3578-ER/_Documents/Static%20Files/LS3578ER_SS_1208.pdf
If you want to read 2D barcodes you would require an imager. For long range try the Intermec SR61 it contains an EX25 imager.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Dec 01, 2009 | Symbol MOTOROLA LS3578-ER EXTENDED RANGE...
Replacement USB charging cradle for Logitech Mouse
It sounds like you are talking about a wireless unit, and I am going to assume that it has stopped charging.....Try this first before you purchase a new cradle for it....Take a pencil eraser and clean the terminal prongs on the cradle, just as if you were erasing on paper, then do the same to the terminal plates on the mouse....
Sep 27, 2009 | Computers & Internet
Memory card
Approx. number of recordable images
SHQ HQ SQ1 SQ2
Internal memory Approx. 1 3 4 7
4MB 6 12 16 29
8MB 12 24 33 58
16MB 25 49 66 110
32MB 51 99 132 221
64MB 102 199 265 442
128MB 204 399 532 887
http://olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=696
Here is the link to the Olympus website where you can download a copy of the instruction manual for the camera.
Apr 08, 2009 | Olympus Camedia C-100 Digital Camera
Nurit 2085
This is most likely cause by a crupt transaction or a transaction that is not aloud stuck inside the terminal. Once you batch out contact your processing comapnyask them if they see you current batch you jut settled. If so they will need to clear the the terminal and up the batch number. Just make sure all of your sale are settled with your processign comapny before you go ahead and clear the terminal.
May 14, 2008 | VeriFone (M19755014US1) Magnetic Card...
Does itsupport 1D linear laser scanner
Feb 04, 2008 | Symbol MC9060-K Portable Terminal
Symbol barcode scanner, handheld, cordless, yellow
error code communication error the scanner is not communicating with the cradle. It is important that the synapse cable is plugged into the cradle before the cradle power suply is pluged into a outlet. also could be the scanner did not pair up with the cradle correctly try rescanning the barcode on the cradle.
May 29, 2007 | Symbol Batch Barcode Scanner P360/460...
Computers & Internet Logo
116 people viewed this question
Top Laser Computers & Internet Experts
Robin Hill
Robin Hill
Steve Sweetleaf
Steve Sweetleaf
Are you a Laser Computer and Internet Expert? Answer questions, earn points and help others
