Question about Xerox Documate 3920 - Document Scanner
How to scan to computer via USB?
-Scanner have Ethernet ,usb& copy port for printerlike PC USB. no driver found on CD or website just management tool for scanner throw the IP number. My question is how to scan to computer via USB port not Ethernet?
    Welcome Back:
    Visited the website for 2 consecutive days.
There are hand held scanner available in the market by which you can finish a bit of work in minutes and you can also use microSD card. You can check for such electronic devices available in budget price.
Posted on Mar 31, 2015
  • Anonymous Mar 31, 2015
    sorry i can`t under stand what you would say
If the scanner has a USB connection cord connect it directly to the PC and reboot the PC. It may then recognize the scanner and have a driver for it. If it is not recognized then you should download a driver for it from the manufacter's web site. Good Luck.
    I know that but the problem as I think that the scanner default is Ethernet so no driver attaced with scanner box or on website just management tool whic connected throw IP (Ethernet)
I've downloaded the scanner software onto my computer, and I am able to make photo copies, but when I try to scan something the screen on the printer says "preparing," and nothing happens. Additionally,...
For that first go to device manager then uninstall all usb drivers.
Right click on my computer then click on property then hardware ->device manager.
Then you can see all driver list first uninstall all usb drivers 1 by 1.
Then also uninstall scannner driver from there.
Then again reinstall scanner driver.
then restart computer then check.
Make sure usb cable and usb ports works fine.Try usb cable in another ports.
If you havewn't driver disk you can download from below link.
click here
Select your operating system and download driver.
Let me know if you need more assistance.
Thanks.
Oct 18, 2009 | Canon Pixma MP480 All-In-One InkJet...
I have a MF7100 multifunction unit. I can not get it to connect to my PC as a scanner or to deliver. Any ideas?
for add. clarification; what Operating System you are using right now... did you make sure that all connections are correct and the driver was properly installed on your unit..
also since when you have this problem. did you experienced this problem before,?
let me know
thanks
Oct 10, 2008 | Canon Office Equipment & Supplies
C4388 scan through wifi?
This is happening because the system doesn't have Network Twain Port drivers installed.
Try installing the twain port drivers and assign the IP address of the printer to scan
Oct 12, 2009 | Xerox DocuColor 12 Printer
Usb device not recognised
HI,
Is this the first time you connect your printer on that computer? This can be the USB port does not support a 2.0, or your data cable/printer cable is damage.
Hope this helps
Aug 29, 2009 | HP LaserJet 1020 Printer
The computer recognizes the hardware, however scanner is not scanning. Have windows XP. How can I tell if the scanner is broken, there are no lights on it?
your scanner is ok.
But there is communication problem from computer to scanner .
For that
Check your usb cxable and usb port of computer working fine.
Try in another usb port.
If you have other port like parallel port then check it.
Check drivers of scanner are instaled proeprly.
Ig already installed then uninstall it and install again.
Also uninstall all usb drivers then restart the computer then it automatic install usb drivers .
you can uninstall usb drivers from computer with device manager.
Press windows key + Pause break key to see system proeprty then go to hardware then you see device manager then uninstall all usb drivers.
Jul 31, 2009 | Syscan TravelScan 662
,i reinstalled xp pro. then discovered i have no internet connection , when i check the advice manager there are 3 yellow question marks. (1) Ethernet Controller. (2) PCI Communications. (3) Universal...
You will need to find out what drivers you need for your computer by checking the manual. Then download and install the drivers and you will be up and going in no time!!
Jun 28, 2009 | Computers & Internet
I like to download ethernet controller driver but not from driver detective as this require an internet connection to complete what i want to do.
you nedd to go to a website and download an updated ethernet controller driver are useless because you can't even access the internet without the ethernet controller, unless you have a second PC already hooked up to work with the internet, then make a copy of the ethernet driver, and then copy it onto the original PC to get it acces the intenet. Most people may have to go to a computer repair store and ask if they can buy the ethernet controller driver for their OS and PC on a CD or flashdrive, or instead, but an external Ehternet controller device and connect it to your PC via USB.
Jun 19, 2009 | Compuware DriverStudio (dd-rstd-np/nm31)...
SCAN to pc useing Copystar 1820
please specify how the machine communicates with computer (network, USB cable, or parallel cable). once this is known I'll be able to tell you how to setup the scanning.
As for the 2nd question, yes this machine does support vista, both 32 and 64 bit
May 14, 2008 | Kyocera Copystar CS-1820 Black and White...
Scanner & Software function - cD does not load fully
When trying to reconnect the device, don't expect Windows' plug and play to help you.
To uninstall the hardware itself, locate on your CD "x:\util\ccc\uninstall_l1.bat". Disconnect USB cable as it says before continuing. When finished, restart your computer.
REinsert the CD, and choose "Add a device"... that'll ask you to connect the USB cable so it can configure the scanner portion and not only the printer portion.
Oct 30, 2007 | HP Officejet Pro L7680 All-In-One Printer
Xerox Documate 3920 - Document Scanner Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
