Question about Casio MTP Watches
Why is my watch not working?
The battery was checked and replaced by watch repair shop. The watch was also dusted and still not working. Could this be mechanical issue. Is there a shop in Huntsville Alabama, I can take to?
    Top Expert:
  • Casio Master
  • 6,702 Answers
The electronics in a watch sometimes stop working, because something is defect. Special when around the battery was "dust" is is oxide coming form a leaking battery. The batteries are not supposed to leak, but some cheaper brands do. The oxide can have damaged the circuitry in the watch. Not worth cleaning, because the oxidation already started en can go on on any place in the watch. If it is a good watch and you are attached, ask if they can replace the electronics, but also ask what it will cost you.
For a Casio certified repair store close to you, check here:
Authorized Service and Support Service Centers Support CASIO
Posted on Mar 31, 2015
Frenzy watch #FRZK1103 light up function no longer works, even after replacing battery. Is there a simple fix?
No simple fix, you will need a watch repair shop to fix this, but make sure you get a repair estimate, it may shock you.
Dec 07, 2014 | ACCUTIME WATCH CORP. Frenzy Ladies Watch...
Put new battery in pulsa chronograph 100m watch how do I get it working Plz help
You might need a jump start the watch, or cleaning. I usually try using a air dust blower ball to get all the particles that is invisible to the eye, you can do this on the movement and around the battery area. Aftwards try inserting the battery again then pull out the stem and move it clockwise at least 10 times passing the 12'o clock marker. If the watch is not brough back to life you can try one last thing before buying a new movement or taking it to the watch repair shop. If you take it to watch repair shop they might charge you a few bucks to jump start the movement. I hope this helps. Marcelo
Oct 22, 2013 | Pulsar Chronograph Watch
How to change the battery. I can't get the back off to get to it.
You need to take the watch to a watch expert. Most watches are not designed to be serviced by the owner. There are a couple of national chains of watch repair stores that specialize in battery replacement as well as a vanishing number of full-service watch repair shops. Most jewelers are not trained nor do they have the tools to do a proper battery replacement. Since this is a water resistant watch, make sure the place you take it to can re-seal the back and pressure test it to ensure the water resistance. The best place I've found is Precision Time. They are located in most major cities in major shopping malls and can service the watch while you shop. Check out www.precisiontimeco.com for nearest location. There are also a lot of FastFix locations around, but most are not able to reseal the watches.
Feb 11, 2011 | Armitron 165 watch
Need to replace battery of lorus mickey mouse pocket watch
Try to find a watch repair shop (sometimes called clock & watch shops). Also, many jewelers replace batteries and do watch repair.
Jan 13, 2011 | Lorus Watches
I have a big tic watch but after a battery change the digital number display on watch face no longer works,why?
Who changed the battery, you or a watch repair serviceman? Did you replace the battery bar after you replaced battery? Did you check and see if there was a second battery (some watches have two)
You may need to have it serviced. Or try Fossil at :
http://www.fossil.com/en_US/shop/customer_care/static/fossil-Instructions.html
Aug 23, 2010 | Watches
How do I change battery.
mcdevito75 here, You:d need a couple of watch tools to change the battery, the cost of these tools and the cost of a watch repair shop to change the battery for you are similar. Look for a small watch repair shop in your area to save on the cost of replaceing the battery.
Jun 17, 2010 | DKNY Leather #NY1328 Watch for Men
How do I replace the lithium battery in a Casio Privia PX-100?
mcdevito75 here, I've also riuned a number of Casio watches replaceing the battery, extra, extra care is needed, first remove the back cover screws, then you:ll have to remove another cover for the battery, after replaceing the battery the work begins, very carefully reverse the removal procedure, any un do pressure will cause the movement to break and the face of your watch will turn Black. Best with your casio is to let a watch repair shop change the battery, look for a small shop to save some money.
Jun 14, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
My Esquire watch doesnt work anymore
Open the watch and get the battery out. Take a watchmakers screwdriver or hardened steel pin and clean (scrape) all battery related contacts till they are clean and shiny. Use dust blower to get rid of any scrape-offs. Replace the battery and contact.
If all this do not work, then you will have no option, but to bring the watch in for repair (professional cleaning).
Rate me, please.
Mar 15, 2009 | Nixon Esquire Dial / Band Watch for Men
Tag Heuer Tiger Woods watch stops regularly
You should go back to the watch repair shop and ask for complete check-out of your watch. No watchmaker can return the watch to the customer without properly checking all the gearwork, timekeeping, battery power and all the features the watch has.
As your watch was serviced and the battery replacement took place, the executives of all the work done are responsible for all the faults your watch is having right now.
As watch repairs are quite expensive and time consuming, they (probably) will argue with you about this issue, but DO NOT give up, as these are YOUR consumer rights to ask for the job to be properly done (under warranty or paid by you). In case if you will be turned down, ask for FULL refund and find another shop.
If the repair shop is ready to undertake the job again, do not rush them, as the complete watch overhaul and check may take up to 6 weeks (this MUST be done at no any cost to you if you have the warranty or allready paid for the job).
P.S. I suspect that there is some fault in your watch geartrain, because if it is shooked or moved, the watch works, but when idle-it stops. That means the service of your watch was NOT DONE properly, and some failure or even dirt in geartrain was missed by the watchmaker (sometimes it happens- nobody is perfect!). This doesn't mean you have to agree with it, so, go and get your watch properly serviced and checked out.
Do not forget to rate, please.
Mar 08, 2009 | Tag Heuer Tiger Wood Golf WAE1111 Watch
Watch new battery installed still wont work
First you have to check if the battery is on full power, as sometimes even brand new batteries are underpowered. Good battery should have 1.54 - 1.57 Volts of charge.
If battery is ok and watch still not working - get the battery out and clean (scrape) all battery related contacts with steel needle untill they are shiny. Use the dust blower to get rid of cmall dirt particles.
Replace the battery. Now the watch should work.
If the watch doesn't work after cleaning contacts, then this is mechanical fault and you will need watchmakers help.
Feb 03, 2009 | Bulova Watch
Watches Logo
78 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
