Question about Ariston Technologies Washing Machines
My front loader Ariston A1636S. Is washing and pumping water out very quiet, but when it comes to spinning has become noisy, and perhaps describe as a grating noise. But no strange smells.
I have had this machine some years.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    New Friend:
  • 61 Answers
Most common causes of noisy spin are something has found its way between the drum and its casing or the heater has come adrift from its fixing and is rubbing on the drum
Posted on Mar 31, 2015
My washing machine although washing and emptying quietly. When it goes into spin and slowly gone very noisy, perhaps like a grating sort of noise, but no strange smell. I have tried spinning slower but it...
maybe a under wire from bras stuck in drum.when machine is empty look in drum holes and see if anything is poking through the holes.keeping turning the drum as you look,sometimes hard too spot has the tips are often white.
Mar 31, 2015 | Ariston Technologies Washing Machines
Why are my clothes dripping wet after the spin cycle I have a ariston front loader avxl129
sounds like the pump could be unable to get the water out after the wash. check the door into the pump, at the bottom front of your machine
Aug 12, 2014 | Ariston Technologies Washing Machines
Smelly water & not going into spin
Try cleaning out the pump access port. It is at the front of the machine.
All sorts of stuff gets into these pumps on front loaders. A partial clog will go what you describe.
If you use a mesh laundry bag it will keep this from happening
Mar 23, 2014 | Bosch Washing Machines
I have a noisy ariston front loader washing machine and
From the front of the washer, spin the drum by hand, and if it feels rough, or is noisy, or rumbling, then the main drum bearings have failed..
If no noise, then problem is elsewhwere.
Hope this helps.
Jan 27, 2010 | Ariston Technologies AW149NA Washer
We have an Ariston A1636S Washing Machine. When
COULD BE SOMETHING IN THE DRUM UNDER THE CROME PIECE THAT THE CLOTHES GO ONE
Dec 30, 2009 | Ariston Technologies Washing Machines
My Ariston A1636S Is making a very loud crackling or rattling noise when it spins. Almost like something is loose inside it. I've checked and nothing has fallen into the drum. Can someone help?
Remove the dive belt, and spin the drum by hand, if it feels rough or is noisy, then the main drum bearings have failed, if no noise, then look elsewere.
Please rate my solution.
Thanks.
Sep 08, 2009 | Washing Machines
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
Whirlpool wfs1285aw noisy spin cycle
Hi..
If you washer is noisy,
  • Check that the water supply valves are turned on
  • Inspect the filter screen
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve
  • Test the motor
General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Good luck !!!
Regards
PCmania
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Ariston Margherita 2000 "AL109X" very noisy when spinning
To start ensure that machine is well balanced, and that the load is well distributed inside the drum.
If the problem is not balancing, then the most common is a broken drum bearing spider or a bad drum bearing. A symptom of drum bearing problems is the drum having excessive play when you spin by hand.
Also struts and springs must be checked.
Apr 18, 2009 | Ariston Technologies Ariston AWD12 Front...
Washing Machines Logo
106 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
