Question about SCi Moulinex Food Mincer. White Plastic with metal roller blades
Plastic gear is warn and need to be replaced - SCi Moulinex Food Mincer. White Plastic with metal roller blades
1996 ford conture shift cable adjustment
if you have replaced the shift cable and everything is working other than the dash indicator, that is adjusted by turning a small plastic nut on the right lower right side of the column (it's on a plastic bolt portion of the string leading up and around to the actual pointer)
if you need to adjust it because the vehicle is not shifting out of park correctly or through the gears correctly, something is warn out, usually the cable mounting portion of the column, the actual shift points are set inside the transmission and you can not easily fix any of that
Apr 08, 2017 | Ford Cars & Trucks
1998 nissan frintier 5 speed standard shifter has a lot of slop can i fix it
The shift handle has a plastic bushing and metallic locks that holds it firmly and allow you shift the gears smoothly, so when this bushing or the has warned out, so the shift handle will develop a lot of slop, you may need to consider replacing it that kit.
Feb 20, 2015 | 1998 Nissan Frontier
I have a 93 ford escort that won't shift out of 1st gear if you go thru the gears manually it will go into high gear momentarly then go quit pulling if you shift into nuetral and back into high it does the...
the gate in the gear stick needs either replacing or is has come lose or warn. they are made of plastic. you need to take the cover off and remove the plastic ring to remove it. also check that the ball joint has not split as this will need to be replaced to.
Jan 17, 2014 | Ford Escort Cars & Trucks
I drive a toyta estima lucida Diesel 4WD 1992 model. There is a small orange symbol on the extreme left of the odometer. It just appeared after I engaged the auto gear shaft. What is this orange symbol?
Does it look like a tank with a drain at the bottom of it? If so it could be the fuel filter water level warning light. This means there is water accumulated in the bottom of the fuel filter. Open the drain on the filter and catch the contents in a container. If water is present it will be noticeable as it will be separate from the diesel fuel. Replace the drain and pump the button on the top of the filter housing while starting the engine. Keep pumping until you notice the pump going hard.
Another possibility is that it is the brake light warning light, if it looks like a car with lights shining out the rear then it is possible that when you put your foot on the brake to engage the gear shifter, it picked up that there is a blowen brake light bulb. Check the bulbs. To replace them you need to pop the cover off the rear door, it is quite tight and held by many plastic clips. Some models have a provision that allows you to remove small plastic covers to access the bulbs.
Feb 18, 2011 | 1992 Toyota Previa
Exploded diagram of manual transmission to find plastic gear part
1995 neon wont find a gear is a5 speed with 2.0L just stoped no warning sing or noise checked cluch cabel and shift linkage
Nov 11, 2009 | 1996 Dodge Neon
My Hamilton Beach Food processor model # 702-1 has a BROKEN plastic gear that attaches to the motor drive shaft (it threads onto the shaft). It meshes with another plastic gear that turns the spindle that...
my suggestion is that watever spare part u replace, get it replaced by the original manufacturer to avoid future problems. take it to the shop you have bought it from, ask them where u can get one. they may help u better with contacting the manufacturer. i know its time consuming! good luck!!
Oct 14, 2009 | Food Processors
Replacement plastic gear for a Royal 150MX shredder
For parts call Royal at 1-800-524-0799; they should be able to help.
Don't forget to lubricate the cutting shafts on x-cut shredders.
Apr 02, 2009 | Royal 150MX Cross-Cut Shredder
2003 Buick park Avenue Driver Seat Adjuster...
After months of looking I found a shop who was willing to make me some brass gears. I put the brass gear in both my 2002 Park Ave seats. They work great. I sell them for 100 apiece. claygear@hotmail.ca
Aug 23, 2008 | 2003 Buick Park Avenue
FE 170 OLYMPUS digital camera
The lens need to be replaced or repaired. It is not fully extending. It may be that one or more of the plastic gears or plastic rods that hold the gears in place, are broken. I repaired two plastic rods in my lens, by drilling holes for new plastic rods,(I cut plastic rods from a plastic toilet bowl chain!!! It fit inside the gears perfectly), and super glue the rods in place. Replaced gears, put camera back together and BAM in worked! Nothing like a perfectly working refurbished rig job. Camera takes great pictures to this day.
Nov 27, 2007 | Olympus FE-170 Digital Camera
SCi Moulinex Food Mincer. White Plastic with metal roller blades Logo
307 people viewed this question
Top SCi Sport & Outdoor - Others Experts
Are you a SCi Sport and Outdoor - Other Expert? Answer questions, earn points and help others
